🔹 Card-mod - Super-charge your themes!
Appreciated the work here, but I am running into a few issues. With 0.116.4 I use this theme file to get this result:
But, with 0.117.1 (and using your latest code snippet above), it now looks like this:
Issues:
  • Sidebar header is really compressed on top
  • View container goes on behind the paper tabs bar
  • The top header in de main window has a very persistent 64px top padding that disappears with a hard refresh, but is back as soon as you change tabs once and go back to the previous tab.
Google Light Theme:
  # Card mod stuff
  card-mod-theme: Google Light Theme
  header-height: 0px # Change this to 0px for header on the bottom. You're 1/3 there.
  card-mod-root-yaml: |
    paper-tabs$: |
      /* Uncomment this for header on the bottom. You're 2/3 there. */
      #selectionBar {
        bottom: unset !important;
    ha-app-layout$: |
      #contentContainer {
        padding-top: 0px;
      ha-tabs {
        height: var(--header-height);
      app-header {
        --header-height: 48px;
      /* This moves the header up. */
      app-header {
        transform: translate3d(0px, -48px, 0px);
      /* Let's change the background. */
      app-header, app-toolbar {
        background: transparent !important;
        color: #A9A9A9 !important;
      /* We're still going to need a way to see that we're in edit mode. */
      app-header.edit-mode {
        padding-bottom: calc(var(--ha-card-border-width, 2px) * 2);
        border-bottom: var(--ha-card-border-width, 2px) solid var(--primary-color);
      /* This changes the color of the currently selected tab. */
      ha-tabs {
        --paper-tabs-selection-bar-color: #D2691E !important;
      paper-tab[aria-selected=true] > ha-icon {
        color: #FF8C00 !important;
      paper-tab[aria-selected=true] {
      /* This hides the help button. */
      a.menu-link[target="_blank"] {
        display: none;
      /* This makes the plus color the same as the background. */
      #add-view {
        color: var(--primary-background-color);
      /* This hides the title. */
      [main-title] {
        display: none;
      /* This hides the app-toolbar in edit mode. */
      app-toolbar.edit-mode {
        height: 0;
      /* This moves the edit mode buttons back in. */
      app-toolbar.edit-mode > mwc-icon-button {
        position: absolute;
        left: 0;
        top: 0;
        z-index: 1;
      app-toolbar.edit-mode > ha-button-menu {
        position: absolute;
        right: 0;
        top: 0;
        z-index: 1;
      /* This adds a bit more padding, mainly for unused entities. */
      app-header.edit-mode > div {
        padding-left: 5px;
      /* Uncomment this for header on the bottom. You're 3/3 there. */
      app-header {
        top: calc(100vh - 60px) !important;
        bottom: 0 !important;
        transform: unset !important;
#and everything of the original theme
NowI have this. Modified what I can. Only one thing what I don’t know how to solve.
# iOS Dark Mode Theme
  # This is MIT license because why not
# Hey there! Thanks for helping out in my Teletype!
# Things to do:
# Let's add a bottom padding to the edit mode header. ✅
# Let's hide the main title. ✅
# Let's make the plus color the same as the background. ✅
# Let's hide the help button. ✅
# Let's change the color of selected tabs. ✅
# Let's set the app-toolbar height to 0 in edit mode. ✅
# Let's move the buttons down in edit mode. ✅
ios-dark-mode:
  card-mod-theme: ios-dark-mode
  header-height: 48px
    ha-tabs$: |
      /* Styles for not mobile */
      @media (orientation: landscape) {
        ha-tabs::after {
          font-size: 20px;
          content: "{{ states('sensor.date') }} {{ states('sensor.date_hu') }}, {{ state_attr('calendar.magyar_nevnapok', 'message') }} névnap, {{ states('sensor.time') }}";
          text-transform: none;
          white-space: pre;
      /* Let's get going! */
      /* We still need this, because we need to compact edit mode. */
      app-header {
        background: url('/local/homekit-bg-4.jpeg') !important;
        color: var(--primary-text-color) !important;
      ha-tabs {
        --paper-tabs-selection-bar-color: var(--primary-color) !important;
        display: none;
      #add-view {
      [main-title] {
        display: none;
        height: 0;
      ha-button-menu {
        right: -25px !important;
        color: rgb(74, 27, 43);
        position: absolute;
        left: 0;
        top: 0;
        z-index: 1;
        position: absolute;
        right: 0;
        top: 0;
        z-index: 1;
        padding-left: 5px;
  # Global
  background-image: 'center / cover no-repeat fixed url("/local/homekit-bg-4.jpeg")'
  primary-color: "#FF9F09"  # from Apple systemOrange dark mode
  light-primary-color: "#B6B6C1"  # light gray (icons on left menu)
  primary-background-color: "#2c2c2e"  # systemGray5 dark mode
  secondary-background-color: rgba(25, 25, 25, 0.7)
  divider-color: "#98989d"  # from Apple systemGray dark mode
  accent-color: rgba(255, 159, 9, 1)
  # Text
  primary-font-family: "-apple-system, BlinkMacSystemFont, 'Segoe UI', Roboto, Oxygen, Ubuntu, Cantarell, 'Open Sans', 'Helvetica Neue', sans-serif"
  paper-font-common-base_-_font-family: "var(--primary-font-family)"
  paper-font-common-code_-_font-family: "var(--primary-font-family)"
  paper-font-body1_-_font-family: "var(--primary-font-family)"
  paper-font-subhead_-_font-family: "var(--primary-font-family)"
  paper-font-headline_-_font-family: "var(--primary-font-family)"
  paper-font-caption_-_font-family: "var(--primary-font-family)"
  paper-font-title_-_font-family: "var(--primary-font-family)"
  primary-text-color: "#FFF"
  secondary-text-color: "#d3d3d3"
  text-primary-color: "#FFF"
  disabled-text-color: "#555"  # XXX: https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/2
  text-dark-color: "#FFF"
  # Sidebar Menu
  sidebar-background-color: var(--primary-background-color)
  sidebar-icon-color: var(--light-primary-color)
  sidebar-text-color: "#F1F1F1"
  sidebar-selected-background-color: var(--primary-background-color)
  sidebar-selected-icon-color: "#FFF"
  sidebar-selected-text-color: var(--sidebar-selected-icon-color)
  # States and Badges
  state-icon-color: "#FFF"
  state-icon-active-color: rgba(255, 214, 10, 1)
  paper-item-icon-active-color: rgba(255, 214, 10, 1)
  state-icon-unavailable-color: var(--disabled-text-color)
  # Sliders
  paper-slider-knob-color: "#FFF"
  paper-slider-knob-start-color: var(--paper-slider-knob-color)
  paper-slider-pin-color: var(--paper-slider-knob-color)
  paper-slider-active-color: "#0984ff"  # from Apple systemBlue dark mode
  paper-slider-secondary-color: var(--paper-slider-knob-color)
  paper-slider-container-color: rgba(255, 255, 255, 0.5)
  paper-slider-font-color: "#000"
  ha-slider-background: none !important
  # Labels
  label-badge-background-color: "#23232E"
  label-badge-text-color: "#F1F1F1"
  label-badge-red: rgba(255, 159, 9, 0.7)  # from Apple systemOrange dark mode
  # Cards
  card-background-color: var(--secondary-background-color)  # Unused entities table background
  paper-listbox-background-color: var(--primary-background-color)
  ha-card-border-radius: 20px
  ha-card-background: rgba(10, 10, 10, 0.4)
  paper-card-background-color: var(--ha-card-background)
  code-editor-background-color: var(--disabled-text-color)
  # Toggles
  paper-toggle-button-checked-button-color: "#484848"
  paper-toggle-button-checked-bar-color: "#484848"
  paper-toggle-button-unchecked-button-color: var(--paper-toggle-button-checked-button-color)
  paper-toggle-button-unchecked-bar-color: var(--disabled-text-color)
  # Table row
  table-row-background-color: var(--primary-background-color)
  table-row-alternative-background-color: var(--secondary-background-color)
  # Switches
  switch-checked-color: "#30d257"  # XXX: remove when https://github.com/home-assistant/home-assistant-polymer/pull/4203 is in HA
  switch-checked-track-color: "#30d158"  # from Apple systemGreen dark mode
  switch-checked-button-color: "#FFF"
  # Other
  paper-dialog-background-color: rgba(55, 55, 55, 0.8)  # e.g., background of more-info
  paper-item-icon-color: white  # also should mini-media-player icon white (but doesn't work by itself)
  more-info-header-background: rgba(25, 25, 25, 0.5)
  lumo-body-text-color: var(--primary-text-color)  # see https://github.com/basnijholt/lovelace-ios-dark-mode-theme/issues/42
  app-header-background-color: rgba(155, 155, 155, 0.8)
  markdown-code-background-color: "#464646"
  # Custom
  mcg-title-letter-spacing: .15em
  mini-media-player-base-color: white
  mini-media-player-icon-color: white
  # mini-media-player-artwork-opacity: 0.7  # causing some bug
Need the time and date close to the right. Not need that unused space.
Do you still need a edit mode button?
Edit mode 3 dot is there close to the right but changed the color and not see.
ha-button-menu {
I need that yes. But dont need that unused space on red circle. Before 117 update it is working good with this I think:
/* This leaves space for the buttons on the right of the tabs bar.
         Change 112px to 56px if you don't use voice icon. */
      paper-tabs {
          margin-right: 20px !important;
But now it is not working.
So do I need to have to put this in the wiki?
paper-tabs
ha-tabs
Ok, I change it and nothing happend:
      ha-tabs {
Try
position: absolute;
left: 0;
right: 20px;
This is change now but too much. The time last character disappered.
Can you send a screenshot? You can increase the right variable if needed.
With this setup:
      ha-tabs {
          position: absolute;
          left: 0;
          right: 5px;
The 3 dot now on the left side.
Prior to 0.117 this:
  card-mod-card: |
    ha-card.top-level-card div.card-header {
      padding-top: 0px;
      padding-bottom: 28px;
Used to shift the card names up to be in line with my other cards. Now it has no effect. Can anyone see why?
Was changed from div to h1
Thanks Kendell. I couldn’t see the forest for the trees. I was looking at the class not the div/h1
I was ultimately able to solve this myself (by trial and error, not wisdom). This does all I need:
  # Card mod stuff
  header-height: 48px
    ha-app-layout$: |
      #contentContainer {
        padding-top: 0px !important;
        padding-bottom: 48px !important;
      ha-tabs {
        color: var(--app-header-text-color) !important;
      paper-tab[aria-selected=true] > ha-icon, paper-tab[aria-selected=true] {
      /* This hides the help button, menu button and title */
      a.menu-link[target="_blank"], ha-button-menu, [main-title] {
        display: none;
      app-header {
        top: calc(100vh - 48px) !important;
  # End card-mod, back to the original theme:
It is possible to hide the hamburger and The 3 dots?
Yes, it is. display: none; ha-menu-button ha-button-menu
Thank you Kendall!
The 3 dots hide, but the sidebar toggle no.
  card-mod-theme: slate
  header-height: 48px
    ha-app-layout$: |
      #contentContainer {
      ha-tabs {
        --paper-tabs-selection-bar-color: var(--button-card-background-color-on) !important;
        display: none;
      ha-menu-button {
        display: none;
      app-header {
        top: calc(100vh - 65px) !important;
Can you put your full theme file for testing? Also sorry for your spellcheck kendallkendell
Sorry Kendell :relaxed:
I will give a coffee or a beer for this!
My theme is here
# Slate
slate:
  # Main colors
  primary-color: "#3E80B0"
  accent-color: "#ff0000"
  dark-primary-color: "#e0e1e1"
  light-primary-color: "#e0e1e1"
  # Text colors
  primary-text-color: "#e0e1e1"
  text-primary-color: "var(--primary-text-color)"
  secondary-text-color: "rgba(224, 225, 225, 0.3)"
  disabled-text-color: "#777777"
  label-badge-border-color: "green"
  # Sidebar
  sidebar-icon-color: "#9e9e9e"
  # Background colors
  primary-background-color: "#222627"
  secondary-background-color: "#434b4d"
  divider-color: "rgba(0, 0, 0, .12)"
  table-row-background-color: "#292929"
  table-row-alternative-background-color: "#292929"
  # Nav Menu
  paper-listbox-color: "#777777"
  paper-listbox-background-color: "#222627"
  paper-grey-50: "var(--primary-text-color)"
  paper-grey-200: "#222222"
  # Paper card
  paper-card-header-color: "#252b2d"
  paper-card-background-color: "#222627"
  paper-dialog-background-color: "#2d3538"
  paper-item-icon-color: "#9da0a2"
  paper-item-icon-active-color: "#3182b7"
  paper-item-icon_-_color: "green"
  paper-item-selected_-_background-color: "#ff0000"
  paper-tabs-selection-bar-color: "green"
  # Labels
  label-badge-red: "var(--primary-color)"
  label-badge-text-color: "var(--primary-text-color)"
  label-badge-background-color: "#222222"
  # Switches update
  switch-checked-color: "#7a7d7f"
  switch-unchecked-button-color: "#3b4041"
  switch-unchecked-track-color: "#0c0d0d"
  # paper-toggle-button-checked-bar-color: '#009FFF'
  # Sliders
  paper-slider-knob-color: "#a4abb1"
  paper-slider-knob-start-color: "#a4abb1"
  paper-slider-pin-color: "#626a6f"
  paper-slider-active-color: "#626a6f"
  paper-slider-container-color: "#202020"
  paper-slider-secondary-color: "var(--secondary-background-color)"
  paper-slider-disabled-active-color: "var(--disabled-text-color)"
  paper-slider-disabled-secondary-color: "var(--disabled-text-color)"
  #paper-slider-height: '3px'
  # Google colors
  google-red-500: "#bf3838"
  google-green-500: "#5b8d47"
  # Changes to fix history/logbook menus
  lumo-primary-text-color: "#2980b9"
  lumo-secondary-text-color: "#2980b9"
  lumo-primary-color: "#2980b9"
  # Calendar day numbers
  lumo-body-text-color: "#e0e1e1"
  # Calendar/Date-Picker Background
  lumo-base-color: "#222222"
  # Month/Year header
  lumo-header-text-color: "var(--lumo-body-text-color)"
  # DayOfWeek Header
  lumo-tertiary-text-color: "var(--lumo-body-text-color)"
  lumo-shade: "#222222"
  lumo-shade-90pct: "rgba(34, 34, 34, .9)"
  lumo-shade-80pct: "rgba(34, 34, 34, .8)"
  lumo-shade-70pct: "rgba(34, 34, 34, .7)"
  lumo-shade-60pct: "rgba(34, 34, 34, .6)"
  lumo-shade-50pct: "rgba(34, 34, 34, .5)"
  lumo-shade-40pct: "rgba(34, 34, 34, .4)"
  lumo-shade-30pct: "rgba(34, 34, 34, .3)"
  lumo-shade-20pct: "rgba(34, 34, 34, .2)"
  lumo-shade-10pct: "rgba(34, 34, 34, .1)"
  lumo-shade-5pct: "rgba(34, 34, 34, .05)"
  lumo-tint-5pct: "#222222"
  # fix for device configuration screen
  card-background-color: "var(--paper-card-background-color)"
  # Cards
  ha-card-border-radius: "5px"
  #ha-card-box-shadow: None
  # Button Card
  button-card-icon-color-on: "#2c688d"
  button-card-name-color-on: rgba(37,37,37,0.8)
  button-card-state-color-on: rgba(37,37,37,0.8)
  button-card-lock-color-on: rgba(37,37,37,1)
  button-card-label-color-on: rgba(37,37,37,1)
  button-card-background-color-on: rgba(245, 245, 245, 0.96)
  button-card-icon-color-off: "#969696"
  button-card-name-color-off: rgba(150,150,150,0.8)
  button-card-state-color-off: rgba(150,150,150,0.8)
  button-card-lock-color-off: rgba(150,150,150,0.8)
  button-card-label-color-off: rgba(150,150,150,0.8)
  button-card-background-color-off: rgba(255, 255, 255, 0.14)
  scene-card-icon-color: "#969696"
  scene-card-name-color: rgba(150,150,150,0.8)
  scene-card-state-color: rgba(150,150,150,0.8)
  scene-card-lock-color: rgba(150,150,150,0.8)
  scene-card-label-color: rgba(150,150,150,0.8)
  scene-card-background-color: rgba(255, 255, 255, 0.08)
  # Graph Card
  graph-card-line-color: "#ec9600"
  # Markdown
  markdown-title-color: rgba(192,192,192,1)
  markdown-text-color: rgba(192,192,192,1)
  header-height: 48px
    ha-app-layout$: |
      #contentContainer {
      ha-tabs {
        display: none;
      ha-menu-button {
        display: none;
      app-header {
display: none !important.
