šŸ”¹ Card-mod - Super-charge your themes!
Apply padding-bottom: 50px; to app-header.
I tried, but the only thing that changed is that if i scroll the page down the header scrolls down as well a few pixels. No differences regarding the header dimension unfortunately
margin-bottom? Try applying to app-header, app-toolbar, and ha-tabs.
What happens if you put * { color: red; } ? Can it even apply? What if you donā€™t use the shadow root selector and apply directly with the * with .: ?
Sorry, I donā€™t understand what this has to do with blurring the background. Did you mean to reply to a different person? If you were telling me how to add blur, can you please post an example?
Ok, the margin-bottom worked for the tabs, which are now in the position i want them! Thanks! The background of the header hasnā€™t changed size though, leaving me with the discrepancy seen in the attached picture!
Wait, undo what I previously said, and wherever it says 48px in your theme file change it to 96px.
Since about 5 days, in chrome, background image have stopped showing. It still works in Firefox fine. Is there anybody else experiencing this? Any idea?
Update: not sure this was the ā€œbest wayā€ but adding the top lines to the code below solved it.
kiosk-snow:
###Added the lines here to make it work.
# The BG image wasn't showing anymore in Chrome in the "ha-app-layout" below
  card-mod-theme: kiosk-snow
  # Background image
  lovelace-background: 'center / cover no-repeat url("/local/kiosktheme/snow.png") fixed'
##  End of added lines
  # Header
  card-mod-root-yaml: |
    paper-tabs$: |
      .not-visible {
        display: none;
      /*Uncomment this if you want the header on the bottom
      #selectionBar {
        bottom: unset !important;
    ha-app-layout$: |
      /* This corrects top padding for the view. */
      #contentContainer {
        /* Change this to 0px if you want the header on the bottom */
        padding-top: 48px !important;
    ha-button-menu$mwc-menu$mwc-menu-surface$: |
      .mdc-menu-surface {
        margin: 10px;
        box-shadow: var(--ha-card-box-shadow, 0px 2px 1px -1px rgba(0, 0, 0, 0.2), 0px 1px 1px 0px rgba(0, 0, 0, 0.14), 0px 1px 3px 0px rgba(0, 0, 0, 0.12));
      /* This hides the unused portion of the header. */
      app-toolbar {
        height: 0;
      /* This forces background-color and text-color. */
      .edit-mode, app-header, app-toolbar {
        background-color: rgba(0,0,0,0.5) !important;
        color: #FFFFFF !important;
      ha-app-layout {
        background: url("/local/kiosktheme/snow.png");
      app-header {
        background: rgba(0,0,0,0.5) !important;
      app-toolbar {
        background: none !important;
      /* Uncomment this if you want the header on the bottom
      app-header {
        top: calc(100vh - 60px) !important;
        bottom: 0 !important;
        transform: unset !important;
      hui-masonry-view {
        padding-bottom: 60px !important;
      /* This gives the header in edit mode a different look from the standard header. */
      app-header.edit-mode {
        border-bottom: 2px var(--primary-color) solid;
        padding-bottom: 10px;
      /* Make the color of the plus white instead of black. */
      #add-view ha-svg-icon {
        color: #EEE !important;
      /* Bring voice button back down */
      app-toolbar:not([class="edit-mode"]) mwc-icon-button[label] {
        top: 0;
        right: calc(48px * 1);
        z-index: 2;
        position: absolute;
      /* Bring help button back in */
      a[href="https://www.home-assistant.io/lovelace/"] > mwc-icon-button {
        right: calc(48px * 2);
        position: absolute;
        z-index: 2;
      /* Bring close button back in */
      mwc-icon-button[title="Close"] {
        top: 0;
        left: 0;
        position: absolute;
        z-index: 2;
      /* Bring add view button back in */
      mwc-icon-button#add-view {
        position: fixed;
        right: 48px;
      /* Bring edit UI overflow menu back in */
      ha-button-menu {
        top: 0;
        right: 0;
        z-index: 2;
        position: absolute;
        /*Uncomment this out to hide the overflow menu
        display: none;
      /* Hide the title */
      app-toolbar > [main-title] {
        display: none;
      /* Hide buttons that are taking up space, but invisible */
      menu-button[style="visibility: hidden;"] {
        display: none;
      /* Bring sidebar button back in */
      ha-menu-button {
        z-index: 2;
        top: 24px;
      /* Set margin on left to be smaller,
      and set the bar color to be the primary color
      instead of white */
      paper-tabs {
        --paper-tabs-selection-bar-color: var(--primary-color) !important;
        margin-left: 48px !important;
      /* When not in edit mode, shrink the left margin */
      app-toolbar:not(.edit-mode) > div > paper-tabs {
        margin-left: 6px !important;
      /* Color selected tabs */
      paper-tab[aria-selected="true"] > ha-icon {
      paper-tab[aria-selected="true"] {
      /* Styles for mobile */
      @media (orientation: portrait) {
        /* Hide sidebar button and keep room for the overflow menu button */
        paper-tabs {
          margin-left: 5px !important;
          margin-right: 48px !important;
        /* Hide voice button */
        mwc-icon-button[label="Start conversation"] {
          display: none !important;
        /* Hide sidebar button */
        ha-menu-button {
      /* Make help button have contrast */
      app-toolbar a {
        color: var(--primary-text-color) !important;
  # Badges and columns
  card-mod-view-yaml: |
    hui-masonry-view$: |
      mwc-fab[title="Add Card"] {
        bottom: 96px !important;
This doesnā€™t work:
    style: |
      ha-card {
        box-shadow: none;
        background:
          {% if is_state_attr('climate.living_room', 'hvac_action', 'heating') %}
            orange
          {% elif is_state_attr('climate.living_room', 'hvac_action', 'cooling') %}
            blue
          {% else %}
            grey
          {% endif %} ;
It doesnā€™t like the {% elif %}
I finally got what I wanted with:
    style: |
      ha-card {
        box-shadow: none;
        background:
            orange
          {% endif %} ;
        background:
          {% if is_state_attr('climate.living_room', 'hvac_action', 'cooling') %}
            blue
          {% endif %} ;
        background:
          {% if is_state_attr('climate.living_room', 'hvac_action', 'off') %}
            grey
          {% endif %} ;
Is there a way to accomplish the same with a single background line??
What does it show in the template editor in devtools?
I was curious whether the styling had the ability to apply at all.
This shows the desired string in template editor:
            orange
            blue
          {% else %}
            grey
          {% endif %}
Yes, this works in my cards:
    style: |
      ha-card {
        box-shadow: none;
        background:
            orange
          {% endif %} ;
        background:
            blue
          {% endif %} ;
        background:
            grey
          {% endif %} ;
Does it work without elif, but with else?
Hmm. Did not try that. Maybe this?
            orange
            {% else % }
                blue
              {% else %}
                grey
            {% endif %}
          {% endif %}
Will give it a whirl. BTW, the styling was NOT working. I still had other coding inside the button-card that was sort of working and I managed to fine-tune to work. Still, if I can get card-mod to work thereā€™s a little more styling Iā€™d like to do.
trying my first CH replacement now for the overflow option, Id like to see this back happening:
      content: "{{time}} - <div style='display:inline-block; height:32px; width:32px; vertical-align:middle;'><ha-icon icon='{{states('sensor.weather_icon')}}';></ha-icon></div> - {{states('sensor.temp_current')}}Ā°";
to have it show like:
Schermafbeelding 2020-11-19 om 23.17.25
but so far I am out of luck. would this in any way be possible?
this seems to work:
    mwc-icon-button[slot="trigger"]::after {
      font-size: 22px;
      height: 20px;
      width: 200px;
      margin-left: 0px;
      margin-right: 0px;
      content: "{{states('sensor.time')}} - {{states('sensor.temp_current')}}Ā°";
      position: absolute;
      top: 14px;
      right: 0px;
but the icon is still out of my css /html knowledge, returning:
Schermafbeelding 2020-11-19 om 23.27.45
thanks for having a look
HTML isnā€™t supported in CSS, and it shouldnā€™t. CSS is for styling, HTML is for layout. You could try using a special ligature font.
not sure how that would work? you mean trying to replace a weather icon with a ligature font somehow? seems not possible, since I simply want to show an mdi icon in the header, following this template:
      weather_icon_backend:
        value_template: >
          {% set mapper_icon =
            {'partly-cloudy-night':'night-partly-cloudy'} %}
          {% set mapper_br =
            {'pouring':'pouring',
             'lightning-rainy':'lightning-rainy',
             'snowy-rainy':'snowy-rainy'} %}
          {% set mapper_ds =
            {'clear-night':'night',
             'partlycloudy':'partly-cloudy'} %}
          {% set icon = states('sensor.dark_sky_icon') %}
          {% set buienradar = states('weather.buienradar') %}
          {% set dark = states('weather.dark_sky') %}
          {% set weather = mapper_icon[icon] if icon in mapper_icon else
                           mapper_br[buienradar] if buienradar in mapper_br else
                           mapper_ds[dark] if dark in mapper_ds else
                           dark if dark in
                             ['sunny','rainy','snowy','snowy-rainy','windy','fog','cloudy','hail','lightning']
                           else 'sunny-alert' %}
            mdi:weather-{{weather}}
:wink: guess will have to do without that beautiful CH feature, yet again.
This might help:
Youā€™ll have to settle on having the weather icon on the left or right side, not in the middle, and donā€™t try your fancy CSS inline styling.
that would be no problem at allā€¦
yeah, I thought as much, so already tried that, but since that was with the template sensor in place, had no luck yet.
not sure I grasp the direction the link you posted sends me, so I need some study time hereā€¦
Go download this:
https://github.com/google/material-design-icons/blob/96206ade0e8325ac4c4ce9d49dc4ef85241689e1/font/MaterialIcons-Regular.ttf?raw=true
Then see this:
Then test out this theme file:
slate:
  card-mod-theme: slate
            font-size: 22px;
            height: 20px;
            width: 200px;
            margin-left: 0px;
            margin-right: 0px;
            content: "oldhere";
            position: absolute !important;
            top: 14px;
            right: 0px;
        mwc-icon-button[slot="trigger"]::before {
            content: "done";
            font-size: 22px;
            height: 20px;
            width: 200px;
            margin-left: 0px;
            margin-right: 25px;
            top: 14px;
            right: 0px;
            font-family: Material Icons;
Increase the last margin-right if you need to.
