Carrier Infinity integration
OK I am wondering if anyone else has installed this lately and if there are any hiccups on newer HA versions. I am wanting to do this to my Carrier thermostat (as shown above) also.
This still works today, using infinitude on Docker and then using the custom add on that MizterB wrote. I have it running on 118.4 without issue.
I’m on the newest version of HA and its still working very well. I dont think I’ve ever had an issue with it.
Is it still the case that these “smart” thermostats cannot be integrated into HA? https://www.carrier.com/residential/en/us/products/thermostats/smart-thermostats/systxccitc01-b/
It works. This thread is about the integration that works by having the thermostat go through the infinitive proxy
@countertokens, It’s only as smart as Carrier Corp lets it be. I have a number of guesses as to what’s driving them to keep such a tight grip on accessing their supposedly open API. Theoretically, having skimmed the API, it should be fairly straight-forward to code an integration with this stone age system. However, to date, I know of exactly one Carrier-sanctioned integration with their API - a Skill for Amazon Echo, which is absolutely atrocious. Feel free to read some of the reviews here: https://www.amazon.com/Carrier-Corporation-Infinity®-Touch-Control/dp/B01N1T72HY
All that being said, after having installed a Carrier Infinity system in my previous house, I had the misfortune on stumbling on another one (Bryant Evolution), in the house we upgraded to. For the time being I’m running infinitude, which although wasn’t that difficult to set up, is an absolutely cumbersome solution, by 21st century standards.
Although one can simply rip out the Infinity thermostat, change a few jumpers on the furnace/ac control module, and be able to run a “normal” thermostat of your choice; however, you do end up losing out on some of the finer configuration details, system information and control parameters. As of now, I’ve decided against it.
/rant_off
Big thanks to @MizterB for making my Carrier work the way it should! This is the whole reason I started using HA. I thought I would share my thermostat setup so any newbies can see what is possible using only the Visual Editors.
Hi
I would love to see how you created this. All I have is a simple one with no scheduling, which is something I have the HVAC currently preforming.
5310
You have to understand 4 essential parts of HA:
  • Events. Time is one of the events.
  • Automations. That’s how you get HA to trigger on events.
  • Helpers. That’s how you create the vaules. You can think of them as variables.
  • States. That’s how you get values. Every State you can use is under Developer Tools.
You can search the forum for more info on these. I made 2 automations, one for the daytime, and one for the night. Also, the automation I created in the visual editor didn’t work as I planned. I had to do some minor custom yaml code for the “action” to get the automations to work properly. Here’s my automation for the nighttime (my climate service is named “main”):
alias: Thermostat Sleep
description: Sets the thermostat to nighttime temperatures
  - platform: time
    at: input_datetime.night
condition: []
  - service: climate.set_temperature
      target_temp_low: '{{ states(''input_number.night_heat'') }}'
      target_temp_high: '{{ states(''input_number.night_cool'') }}'
      entity_id: climate.main
mode: single
The “input_datetime” and "input_number"s are Helpers you must create. The part that really had me scratching my head was how to get those heat and cool Helper vaules into the climate service. That’s where States come in. The schedule control is simply an “Entities” card with the Helpers.
Can you share how you got the schedule into the thermostat?
I never got the schedule to go into the thermostat. I have one of the cheaper models that doesn’t have a built-in schedule feature. I confirmed this through the Infinitude web interface. So instead, my scheduling is all internal to HA. Check out my post above on Apr 24. Basically I have automations running that will change the temperature setpoints of the thermostat when the time of day matches certain targets.
Guys and Gals - I’m new to the dance, but I had a Carrier Infinity integration in my old HomeBridge instance, which worked in HomeKit, and have since moved to Home Assistant. Would it be possible to reverse-engineer the HB integration? (I’m coming from a newbie / no coding knowledge whatsoever perspective).
I’m also new to communicating with the HVAC. I posted my problem in another thread. At this point, the data that I’m observing is gibberish.
Looking for ideas
OSD
Not sure if you guys managed to find solutions to integrate Carrier Infinity into HA, but this is what I do:
I’ve been using the G. Rivkees ‘Carrier Inifiniy’ Homebridge plugin for a couple of years, even had a few communications with Mr. Rivkees, and his plugin I would now consider very solid.
Note that you don’t have to be part of the Apple ecosystem to use this solution. You don’t need a Homekit hub, nor an iPhone, just a Homebridge instance running on any hardware you have at hand.
Works well with GitHub - nielsfaber/scheduler-card: HA Lovelace card for control of scheduler entities
