I thought I would post my solution here for others facing this:
- Create a header file (“e.g. text_utils.h”) which you include in the esp yaml file.
- In this header, define several overloads of the same function to calculate the width given different types: i.e. string, int, float, and time.
- Then, in all lambda calls, invoke
GetTextWidthwithout worrying about the type and it will be resolved accordingly
int GetTextBounds(esphome::display::Display* it, esphome::font::Font *font, const char *buffer)
int x1 = 0; // A pointer to store the returned x coordinate of the upper left corner in.
int y1 = 0; // A pointer to store the returned y coordinate of the upper left corner in.
int width = 0; // A pointer to store the returned text width in.
int height = 0; // A pointer to store the returned text height in.
it->get_text_bounds(0, 0, buffer, font, TextAlign::TOP_LEFT, &x1, &y1, &width, &height);
return width;
int GetTextWidth(esphome::display::Display* it, esphome::font::Font *font, const char* formatting, const char *raw_text){
char temp_buffer[80];
sprintf(temp_buffer, formatting, raw_text);
return GetTextBounds(it, font, temp_buffer);
... // overloads for int and float
// Calculate the width of time format
int GetTextWidth(esphome::display::Display* it, esphome::font::Font *font, const char* formatting, esphome::ESPTime time){
auto c_tm = time.to_c_tm();
size_t buffer_length = 80;
char temp_buffer[buffer_length];
strftime(temp_buffer, buffer_length, formatting, &c_tm);
Using it within lambda is quite trivial:
// Estimating total length of text
int day_size = GetTextWidth(&it, id(day_font), "%d", id(hass_time).now());
int icon_size = GetTextWidth(&it, id(font_mdi_large), "%s", weather_icon_map[id(condition_now).state.c_str()].c_str());
int temperature_size = GetTextWidth(&it, id(temperature_font), "%s°C", id(temperature_now).state.c_str());
