Step1: Upgrade to 0.53
Step2: Shutdown HASS
Step3: Edit the zwcfg_0x…xml file in your config dir and find your Fibaro Swipe section
Step4: Replace the entire id=91 CommandClass section with the code below
<CommandClass id="91" name="COMMAND_CLASS_CENTRAL_SCENE" version="1" request_flags="4" innif="true" scenecount="4">
<Instance index="1" />
<Value type="int" genre="system" instance="1" index="0" label="Scene Count" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="4" />
<Value type="int" genre="user" instance="1" index="1" label="Flick UP" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="user" instance="1" index="2" label="Flick DOWN" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="user" instance="1" index="3" label="Flick LEFT" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
<Value type="int" genre="user" instance="1" index="4" label="Flick RIGHT" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="0" />
</CommandClass>
With this code you can use UP, DOWN, LEFT and RIGHT. I haven’t added the circular motions yet and can’t be bothered to be honest at the moment.
Step5: Start HASS
Step6: Add an automation using zwave.scene.activated as a trigger, for example:
- platform: event
event_type: zwave.scene_activated
event_data:
entity_id: zwave.swipe1
scene_id: 1
This uses scene id 1 which corresponds to UP. 2 = DOWN, 3 = LEFT and 4 = RIGHT
