I recently installed Home Assistant and can control all the covers. Just the icon of the covers are not that fitting. In the state open it uses the mdi:window-open and in the closed it uses mdi:window-closed. In my opinion that is not a good fit, because there is mdi:window-shutter and mdi:window-shutter-open. I like to change this, but I’m not successful. Using customize I can just set the icon as permanent. So no state depending icons anymore.
Is there an option to get the cover using the shutter-icons?
