Change range of a dimmer for a light bulb
Ok, gotcha. So you might be able to use a Template Light for this. Basically you create a new light entity (light.scaled_light) that you would use directly, and it acts on the “real” light the way you define. Something like:
light:
    lights:
      scaled_light:
        level_template: >
          {% if is_state('light.real_light', 'on') %}
            {{ ((state_attr('light.real_light', 'brightness')|float-255*0.6)/0.4)|round }}
            0
        turn_on:
          service: light.turn_on
          entity_id: light.real_light
        turn_off:
          service: light.turn_off
        set_level:
          data_template:
            brightness: "{{ (brightness|float*0.4 + 255*0.6)|int }}"
