Change Tado password
Hi! I’ve changed my password for my Tado account. So now the integration no longer works. Where can I adjust the credentials for Tado in HA. I’ve configured the integration through the UI.
did you find a way changing your password? I am facing the same problem at the moment
Hi, I found a way Tado stopped working after upgrade. "Failed to login to tado" - access_token
