*** apologies, code copied instead of picture ***
Question on changing the value (state) of an entity for friendly readout in lovelace card.
I have a nuki lock that reports the battery status as an attribute of the entity lock.frontdoor as either battery_critical: false or true (see below picture):
Now I would like it to show up on my lovelace card as status being either ‘Good’ or ‘Charge!’, therefore I created this template sensor but I do not seem to be able to get the script right, I can only grab the value from the entity but not from the battery_critical attribute of the entity.
configuration.yaml :
sensors:
lock_frontdoor_battery_level:
value_template: '{% if is_state("sensor.nuki_frontdoor_battery_level", "battery_critical", "false") %}Good{% else %}Charge{% endif %}'
friendly_name: 'Frontdoor Battery Level'
Is there anyone that can help me write the correct script? I think the syntax in row 55 is incorrect… when I take out the attribute it works and takes the status of the lock.frontdoor entity, but when I try to add the attribute to grab the state from, it fails.
A bit more info, I also have a separate template.yaml with the following code, not sure if the template from the configuration.yaml should have the above template sensor or should I keep it in the template.yaml file?
template.yaml :
#Adding Nuki Lock Battery Status Entities
- sensor:
- name: "Nuki Frontdoor Battery Level"
device_class: battery
state: "{{ state_attr('lock.frontdoor', 'battery_critical') }}"
Thanks!
