Thanks, tracked the part number to be sold as LOHAS on Amazon UK
See how I get on with them.
can u share you config please
The setup I outline above is all in tasmota through the device interface. No special config is required in HA. The bulbs are auto discovered as a “light” and can be controlled using standard HASS interfaces. The trick is to setoption15, 30 & 19.
