Cheapest and Most Compatible White Spectrum Bulbs
Hello!
I am looking to setup Home Assistant with adjustable color temperature bulbs. I want to do it as low cost as I can. I’m looking into the following bulbs:
I want to avoid a single-manufacturer or internet-connected hub if I can, but I’m unsure where to start. Which bulb should I get and which USB dongle or hub should I get? I’m going to start out with two bulbs. I will eventually get a smart switch, but I don’t want to be tied to one system/manufacturer.
Thanks!
DaAwesomeP
For a bulb: Hue dims to a much lower level than Tradfri. This is useful for wake up lights and for a nightlight.
USB hub could be Conbee/Raspbee or zigbee2mqtt. There is plenty of info on these. Just search :slight_smile:
Thanks for the response!
I’ll definitely go for the Hue bulbs then.
I think I will get the GoControl Z-Wave/Zigbee stick for the most flexibility. It’s a tad expensive, but I think it is worth it.
Thanks!
I personally use milight bulbs
http://www.milight.com/
cheaply you can find them on Aliexpress, e.g.
https://bit.ly/2WbfCT7
Milight also has LED drivers, remote controls, switches, etc.
For communication with HomeAsistant. I use d.i.y hub:
https://github.com/sidoh/esp8266_milight_hub
https://community.home-assistant.io/t/milight-status-feedback-with-nodemcu/17349
As @Grzech said, MiLight bulbs are cheap and work well. Especially the newer versions.
Sengled bulbs work great with a HUSBZB-1 and ZHA, or with Zigbee2MQTT and can sometimes be found for $5 each (when bought in 8 packs or so).
I’m thinking about using this lightify switch: https://www.amazon.com/SYLVANIA-LIGHTIFY-Function-Gateway-Assistant/dp/B01M3OK6J7
The only component I can find is to connect to the Osram hub. Will this switch work over Zigbee?
