I’ve tried your code and it works, thanks!
Yes it is the start of the moste expensive period
Can you post the template you used to get that start time?
Here is it:
expensive_hours_jinja_am:
value_template: >
{% from ‘cheapest_energy_hours.jinja’ import cheapest_energy_hours %}
{{ cheapest_energy_hours(‘sensor.nordpool_kwh_se4_sek_2_00_0’, lowest=false, hours=3, start=‘07:00’, end=‘13:00’, mode=‘start’) }}
If you use it in a binary_sensor
instead of a sensor
and use mode='is_now
you will get a binary sensor which is on
during the most expensive hours.
You can use that in a condition or trigger.
I made binary_sensor.yaml in the configuration directory and made this binary sensor.
binary_sensor:
sensors:
friendly_name: 'Expensive Hours'
device_class: expensive_hours_am
value_template: >
{{ is_state('binary_sensor.expensive_hours_jinja_am', 'is_now') }}
Have ‘binary_sensor: !include binary_sensor.yaml’ in the configuration file.
Got warning: Invalid config for ‘binary_sensor’ at configuration.yaml, line 24: required key ‘platform’ not provided
That’s not a valid device_class
But your main problem is that you are repeating the binary_sensor
key in her first line. Remove that line from binary_sensor.yaml
Oh, and that value_template doesn’t make sense.
sensors:
value_template: >
{% from 'cheapest_energy_hours.jinja' import cheapest_energy_hours %}
{{ cheapest_energy_hours('sensor.nordpool_kwh_se4_sek_2_00_0', lowest=false, hours=3, start='07:00', end='13:00', mode='is_now') }}
You might also want to consider moving to the modern template sensor format
Thanks so much. It was so easy, just change mode in the present template sensor. BTW which modern template format?
The one described here:
Thank you for this great macro! I’ve already started using it for my dishwasher and washing machine. For my dryer however I’m looking for a small tweak I can’t figure out.
I want to be able to throw washed clothes/sheets/towels/etc. in the dryer whenever and I want the dryer to start no later than 6 hours after I’ve done that. I’ve been trying set up a trigger to start the automation but can’t get it to work. Would great appreciate any tips.
How can HA know you did prepare your dryer? Is there a sensor for that?
I’ve set up a boolean switch that I’ll switch on.
input_boolean.dryer_automation_switch
Make a trigger based template sensor triggering on the state of that input boolean. Then you can use start=now(), end=now() + timedelta(hours=6)
You might want to add the duration of the program to that 6 hours, depending on your exact goal
Not sure if I understood correctly but currently running this in an automation with the and if condition that the ‘automation switch’ has to be on. It seems to be working!
{% set start = as_timestamp(states.input_boolean.dryer_automation_switch.last_changed) %}
{% set end = as_timestamp(states.input_boolean.dryer_automation_switch.last_changed) + (6*3600) %}
{{ cheapest_energy_hours(sensor='sensor.current_electricity_price_all_in', hours=2, start=start, end=end, mode='is_now') }}
I was more thinking in line of this, which will create a sensor you can use in a time trigger to start the program
template:
- trigger:
- platform: state
entity_id: input_boolean.dryer_automation_switch
- unique_id: 016219bc-a575-497e-b982-3506c1fb48b1
device_class: timestamp
state: >
{{ cheapest_energy_hours(sensor='sensor.current_electricity_price_all_in', hours=2, start=now(), end=now() + timedelta(hours=6)) }}
availability: "{{ trigger.to_state.state == 'on' }}"
After my adventure with learning to build a dashboard for my phone and wall tablet, as i have some time over i’am gonne try making this work and try to learn so bare with me
As i have limited knowledge i don’t understand the docs.
i installed the jinja template and it’s in the correct place.
As i’am using energyzero i wanted to use the template thats on the github page and put that config_entry in the template.
template:
- trigger:
- platform: time_pattern
hours: "/1"
- platform: homeassistant
event: start
- service: energyzero.get_energy_prices
incl_vat: false
config_entry: 57358b6979f0bdf2756604a1504c42f2
start: "{{ today_at() - timedelta(days=1) }}"
end: "{{ today_at() + timedelta(days=2) }}"
response_variable: prices
- unique_id: 77358b6979f0bdf2756604a1504c42f5
name: Energy Zero prices
state: "{{ prices.prices | selectattr('timestamp', '<=', utcnow().strftime('%Y-%m-%d %H:%M:%S+00:00')) | map(attribute='price') | list | last }}"
attributes:
prices: "{{ prices.prices }}"
but got the error: prices is undefined.
as a test i installed the nordpol intergration and with the following template i’am getting the following result.
{% set output = cheapest_energy_hours (
sensor = 'sensor.energi_data_service',
time_key = 'hour',
value_key = 'price',
hours = 3.5,
include_tomorrow = true,
look_ahead = true,
mode='all',
{{ output | from_json }}
result:
"start": "2024-04-21T11:35:00+02:00",
"end": "2024-04-21T15:05:00+02:00",
"min": -2.90884,
"max": -0.45859,
"time_min": "2024-04-21T12:00:00+02:00",
"time_max": "2024-04-21T14:00:00+02:00",
"average": -1.5528,
"weighted_average": -1.5528,
"list": [
-2.6862,
-2.6862,
-2.6862,
-2.6862,
-2.6862,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-2.90884,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.847,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-0.45859,
-1.21363
"is_now": false,
"extreme_now": false,
"estimated_costs": "unknown",
"datapoints_per_hour": 12,
"hours": 3.5,
"datapoints": 42
Can you go to developer tools > services and try if this works if you paste this (using YAML mode)
incl_vat: false
And where did you paste the template exemple for the energy zero price sensor?
It has to be placed in your configuration.yaml. it doesn’t work in a GUI created template helper, or in Developer tools > templates
this one is working, i get the list with timestamps and prices
hmm that a bit dumb of me, i put it in my sensor.yaml where the template didn’t work.
After i put it in my configuration.yaml the sensor is actief but still get the value of ‘unknown’
edit: ok it’s working
now i have to figure out how to set this up voor my dishwasher, dryer and washing machine.
i think i saw somewhere in this tread something about and binary sensor to trigger an automation, or can i just use the timestamp attr to trigger something
