Check Home Assistant configuration*ERROR*
As far as I know this is not possible with HassIO as it doesn’t a fully fledged accessible Linux below the Supervisor. This is why I can’t imagine that millions (?) of users now need to run a command after every update… :slight_smile: But I might be wrong…
The new update 0.117.3 is out. Did the check again and this popup:
ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
aiohttp 3.6.2 requires multidict<5.0,>=4.5, but you'll have multidict 5.0.0 which is incompatible.
Very strange because i started this topic with same error… did the command:
pip3 install --upgrade --force-reinstall multidict==4.7.6
And the whole problem was solved…
Now back with the whole problem…
Did the command again:
Did the check again… and now the error is gone again…
If this is the case, and it’s reporting this error on a SUPPORTED installation method - has anyone opened a ticket on GitHub to report? Definitely seems like it should be ‘fixed’ if it’s causing errors on a Hassio / HassOS.
There is now:
Just a thought: Does the update break anything if you don’t do the downgrade with the pip3 command before?
Quick push: The issue on GitHub does not seem to get any feedback. Anyone here who can point me in the right direction or shall I just do the update, see what happens and then roll-back if it breaks?
I did the update to 117.2 a while back and it starts in safe-mode. I had to restore from a snapshot. I’m in a holding pattern until this gains traction. I’m thinking about installing the virtual appliance fresh and restoring that from a snapshot.
That command to force a downgrade, where would I enter that? Not sure if I have access to the OS using the official virtual appliance. Can I use the SSH and Web Terminal add-on?
Same error message here. Running HassOS directly on an Intel NUC.
Using above downgrade command gives me the following error in the terminal:
Collecting multidict==4.7.6
  Using cached multidict-4.7.6.tar.gz (50 kB)
  Installing build dependencies: started
  Installing build dependencies: finished with status 'done'
  Getting requirements to build wheel: started
  Getting requirements to build wheel: finished with status 'done'
    Preparing wheel metadata: started
    Preparing wheel metadata: finished with status 'done'
Building wheels for collected packages: multidict
  Building wheel for multidict (PEP 517): started
  Building wheel for multidict (PEP 517): finished with status 'error'
Failed to build multidict
I now did the update on the fully supported / supervised RasPi setup, went through without error and is running for 24hrs now. So it seems there is no direct implication for these installs.
Solved it as well: first update the host os to 4.15 and then run the config check again. Problem solved :+1:
Interesting, I was on HassOS 4.15 and seeing the error with Config Checker. Did the update from 0.117.0 to 0.117.5 and it went fine.
Something definitely changed, mine’s currently showing error-free as well!
System:
Config Checker results:
Follow-Up. Just upgraded to .117.5 on my setup and all went smoothly.
This morning i upgraded to HASSOS 4.16, did the config check and the error about multidict is gone.
Edit: Did the config check again and error is back.
I have exactly the same behavior. 7/10 times errors with the config check, 3/10 times positive results.
Can confirm that I see the issue on HassOS 4.16 as well:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
starting version 3.2.9
[20:38:49] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[20:38:50] INFO: Setup udev devices
[20:38:52] INFO: Don't worry, this temporary installation is not overwriting your current one.
[20:38:52] INFO: Installing Home Assistant: latest...
[20:38:52] INFO: Please be patient, this might take a few minutes...
[20:40:59] INFO: Installed Home Assistant 0.117.6
[20:40:59] INFO: Making a copy of your configuration for checking...
[20:41:02] INFO: Checking your configuration against this version...
[20:46:57] INFO: Configuration check finished - no error found! :)
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
@pvizeli I found your name on a number of commits for the update check so I (more or less randomly) tagged you: Can you point us in the right direction?
I have checked several times against 0.118.1 /.2 and found no issues, so this seems to be resolved.
[fix-attrs.d] done.
[11:02:10] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
[11:02:10] INFO: Setup udev devices
[11:02:13] INFO: Don't worry, this temporary installation is not overwriting your current one.
[11:02:13] INFO: Installing Home Assistant: latest...
[11:02:13] INFO: Please be patient, this might take a few minutes...
[11:04:27] INFO: Installed Home Assistant 0.118.2
[11:04:27] INFO: Making a copy of your configuration for checking...
[11:04:30] INFO: Checking your configuration against this version...
[11:10:25] INFO: Configuration check finished - no error found! :)
I’m getting an error using check config on 118.1 and 118.2 I haven’t updated to either.
I’m not sure what to do about it.
Here is the error I get:
[14:20:00] INFO: Setup udev devices
[14:20:02] INFO: Don't worry, this temporary installation is not overwriting your current one.
[14:20:02] INFO: Installing Home Assistant: latest...
[14:20:02] INFO: Please be patient, this might take a few minutes...
[14:22:23] INFO: Installed Home Assistant 0.118.2
[14:22:23] INFO: Making a copy of your configuration for checking...
[14:22:31] INFO: Checking your configuration against this version...
[14:23:39] ERROR: The configuration check did not pass!
[14:23:39] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Fatal error while loading config: 'int' object is not iterable
Failed config
  General Errors:
    - 'int' object is not iterable
Successful config (partial)
[14:23:39] INFO: The full output has been written to /share/check_config.txt
This shows an error in your config and is not related to this topic. You can the .txt file to see where the error is and follow-up…
Thanks Daniel.
Can you tell me how to get to that txt file?
Using HA I can’t see where to get there.
