@bachya Could you share your Slack setup for HASS and CI/CD pipeline?
Sure thing! Reminder that I use Drone.io, so my example will reflect that.
One of the best parts about Drone is its robust plugin architecture; to that end, I use the Slack plugin. Build notifications operate in their own Drone pipeline (so I can ensure that it doesnât run until all of the preceding pipelines run):
kind: pipeline
name: Build Notification
status:
- success
- failure
depends_on:
- ESPHome
- Fail2Ban
- Home Assistant
- NGINX
- Shell Scripts
steps:
- name: Send Notification
image: plugins/slack
settings:
webhook:
from_secret: slack_webhook
channel:
from_secret: slack_channel_name
template: >
{{#success build.status}}
`{{repo.name}}/{{build.branch}}`: Build #{{build.number}} successful
{{else}}
`{{repo.name}}/{{build.branch}}`: Build #{{build.number}} failed
{{/success}}
when:
status:
- failure
- success
Letâs break this down:
trigger
: run this pipeline on either success or the failure of whatever comes before it -
depends_on
: wait until these pipelines are done before executing -
steps
: the actual pipeline steps; there are several sub-parameters:-
webhook
: the webhook for the particular Slack app to send the message to (note that I store that value as a Drone secret so I can publicly share this configuration without exposing the webhook) -
channel
: the channel to send the message to (again a secret) -
template
: the message template to use (check the plugin documentation for all possible tokens)
Thanks for sharing those CI pipelines. I am still using a Travis CI pipeline, since home assistant has an integration to poll Travis CI, which makes it easy to poll for new successful builds. However, I would like to explore other solutions such as Github Actions or Done CI.
What are your best practices to restart home assistant based on the build result? I see the following options:
- polling (e.g. Travis CI sensor)
- webhook (requires public access to home assistant)
- ssh tunnelling (requires public access to ssh)
- run drone ci / gitlab runner locally on the home assistant host
I try to avoid public access for my services wherever I can. Is there any other options?
With Drone CI you can run everything local, so the ssh tunneling is not an issue as it is on the internal network.
Good point! I added this option to my list. I am currently testing to run a local gitlab runner on my home assistant host. I will look into drone ci next!
I worked with travis, gitlab and now drone ci. I am really impressed how easy it was to setup drone ci with a docker and ssh runner.
Deploying the new config with the ssh runner is a lot easier than working with travis.
Inspired by the pipeline from @bachya I created a basic pipeline for my deployment:
kind: pipeline
steps:
- name: test
image: homeassistant/home-assistant:latest
pull: always
commands:
- mv travis_secrets.yaml secrets.yaml
- python -m homeassistant --script check_config --config .
- name: lint
image: cytopia/yamllint:latest
commands:
- yamllint .
failure: ignore
kind: pipeline
type: ssh
branch:
- master
event:
exclude:
- pull_request
depends_on:
- testing
server:
host: 192.168.178.5
user: pi
ssh_key:
from_secret: SSH_KEY
steps:
- name: pull
commands:
- cd /media/usbstick/container/homeassistant/config
- git pull
- name: prepare
environment:
TOKEN:
from_secret: token
URL:
from_secret: url
commands:
curl -X POST -H "Authorization: Bearer $TOKEN" -H 'Content-Type: application/json' -d '{"entity_id": "script.prepare_restart"}' https://$URL:8123/api/services/script/turn_on
- name: restart
commands:
- cd /opt/configurations/docker-compose/homeassistant
- bash
- docker-compose down
- docker-compose up -d
See: https://github.com/TribuneX/home_assistant/blob/master/.drone.yml
How did you manage to handle changes made from the ui and effect the committed files?
For example when doing changes with the ui to the lovelace ui that behind scenes change lovelace.yaml
that is committedâŚ
And what about custom-components, nodered etc that are also managed from the ui of homeassistant?
Thanks for sharing this. Are you still using this? Specifically, the ESP home drone.io pipeline? for some reason the command does nothing. Does this still work for you or is it outdated?
- name: "Config Check: Latest"
image: esphome/esphome:latest
pull: always
commands:
- "for file in $(find /config -type f -name \"*.yaml\" -not \
-name \"secrets.yaml\"); do esphome \"$file\" config; done"
The command below work but cant find a way to exclude the secrets.yaml file.
commands:
- for file in config/*.yaml ; do esphome "$file" config ; done
Still works for me. If you run that command directly on your repo (no Drone), what happens?
I have it working now. I had to modify the command to get it to work
for file in $(find config -maxdepth 1 -type f -name "*.yaml" -not -name "secrets.yaml"); do esphome "$file" config; done
removed the backslashes also added -maxdepth 1 because my config files are splited and added in subfolders, only the main config files ar in the root of the config/ folder.
I have also added a deploy step to the ESP devices, when checks and tests are success then compile & upload. it would be nicer to upload only the modified files but cant find a good way.
- name: compile and upload
image: appleboy/drone-ssh
settings:
host: 192.168.1.99
username: <username>
password:
from_secret: ssh_password
port: 22
script:
- cd /docker-home-services/esphome/config/
- for file in $(find -maxdepth 1 -type f -name "*.yaml" -not -name "secrets.yaml"); do docker exec prd-esphome-app esphome "$file" run --no-logs; done
