Any idea why I’m constantly getting a system notification for “login attempt or invalid authentication” for the below requested URL? This occurred 1,700 times in the past five hours.
‘/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3’
I’ve been away for a while and I was in the middle of re-writing it all - schoolboy error, because now I have to pick it up and remember what I have done!!
I will try to remember to put it here when I have it all sorted out,
Hey @msl2424, are you sure your path is correct?
According to your url, your home assistant config folder is located within your media folder?? The following url is the same path which doesn’t make sense to me:
‘/media/config/www/sounds/temp/chime_tts/0lwkjkm7.mp3’
I think you meant to set it up as:
‘/media/sounds/temp/chime_tts/0lwkjkm7.mp3’
Attaching a screen print to show you how I have mine setup and it works fine.
Same here …. Updated Long time ago to the Dev. os18…. Since this update - does not work anmymore….
Big HomePod with old os, 17.x it works …
@ColtonYYZ Thanks for your reply. Below is a screen shot of my existing Chime TTS setup. I have also pasted below the log for the system notification error (which is displayed constantly). Running v1.1.4-beta4. Any ideas?
Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
I’m afraid I don’t know. I had to roll back to Beta 3 because Beta 4 wasn’t working for me (I have Alexa devices).
Are you able to post the whole section for ChimeTTS from your logs, not just the single line? It might be helpful to see the steps it’s taking. Be sure to redact your NabuCasa ID in the public path URL. The log should look like this:
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] - Chime TTS audio generated:
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] * audio_duration = 2.064
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] * local_path = None
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] * public_path = "https://<redacted>.ui.nabu.casa//local/chime_tts/8_c8bt5q.mp3"
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] * media_content_id = None
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] ****************************
2024-09-11 13:24:15.816 DEBUG (MainThread) [custom_components.chime_tts] *** Pre-Playback Actions ***
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts] ****************************
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Increasing media_player.couch_echo_left_amz's volume from -1.0 to 0.35
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - Setting media_player.couch_echo_left_amz's volume to 0.35
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Increasing media_player.bathroom_echo_show_5's volume from -1.0 to 0.35
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - Setting media_player.bathroom_echo_show_5's volume to 0.35
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Increasing media_player.colton_s_echo_show's volume from -1.0 to 0.35
2024-09-11 13:24:15.817 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - Setting media_player.colton_s_echo_show's volume to 0.35
2024-09-11 13:24:15.818 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Increasing media_player.kitchen_echo_plus_amz's volume from -1.0 to 0.35
2024-09-11 13:24:15.818 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - Setting media_player.kitchen_echo_plus_amz's volume to 0.35
2024-09-11 13:24:15.818 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - ✔️ media_player.couch_echo_left_amz's volume now -1.0
2024-09-11 13:24:15.818 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - ✔️ media_player.bathroom_echo_show_5's volume now -1.0
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - ✔️ media_player.colton_s_echo_show's volume now -1.0
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - ✔️ media_player.kitchen_echo_plus_amz's volume now -1.0
2024-09-11 13:24:15.819 WARNING (MainThread) [custom_components.chime_tts.helpers.media_player_helper] No media_players were found that support joining speakers into a group. A minimum of 2 is requied.
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] **************************
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] *** Chime TTS playback ***
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] 4 Alexa media players detected:
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - media_player.couch_echo_left_amz
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - media_player.bathroom_echo_show_5
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - media_player.colton_s_echo_show
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - media_player.kitchen_echo_plus_amz
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] Calling notify.alexa_media with data:
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - message: <audio src="https://<redacted>.ui.nabu.casa//local/chime_tts/8_c8bt5q.mp3"/>
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - data: {'type': 'tts'}
2024-09-11 13:24:15.819 DEBUG (MainThread) [custom_components.chime_tts] - target: ['media_player.couch_echo_left_amz', 'media_player.bathroom_echo_show_5', 'media_player.colton_s_echo_show', 'media_player.kitchen_echo_plus_amz']
2024-09-11 13:24:15.820 DEBUG (MainThread) [custom_components.chime_tts] - Waiting 2.064s for audio playback to complete...
2024-09-11 13:24:17.885 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - Waiting until 4 media_players aren't playing...
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] ✔ media_player.couch_echo_left_amz
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] ✔ media_player.bathroom_echo_show_5
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] ✔ media_player.colton_s_echo_show
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] ✔ media_player.kitchen_echo_plus_amz
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts] *****************************
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts] *** Post-Playback Actions ***
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Initial volume for media_player.couch_echo_left_amz is unknown. Unable to restore volume.
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Initial volume for media_player.bathroom_echo_show_5 is unknown. Unable to restore volume.
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Initial volume for media_player.colton_s_echo_show is unknown. Unable to restore volume.
2024-09-11 13:24:17.886 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] Initial volume for media_player.kitchen_echo_plus_amz is unknown. Unable to restore volume.
2024-09-11 13:24:17.887 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Completed in 2.62 s -----
@ColtonYYZ See additional logs below. I also found this related issue reported. I appreciate your time and help on this. The constant system notification is kind of driving me nuts.
Home Assistant Core
2024-09-11 20:56:21.882 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration chime_tts which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-09-11 20:56:28.343 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
2024-09-11 20:56:38.378 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
2024-09-11 20:56:48.311 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
2024-09-11 20:56:58.326 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
2024-09-11 20:57:08.304 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
2024-09-11 20:57:25.956 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from pool-74-96-37-218.washdc.fios.verizon.net (74.96.37.218). Requested URL: '/media/local/sounds/temp/chime_tts/0lwkjkm7.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiIzYTdmMDcwZDk3YzQ0NjJkODgwYzJlMDMxN2UyOTUxYiIsInBhdGgiOiIvbWVkaWEvbG9jYWwvc291bmRzL3RlbXAvY2hpbWVfdHRzLzBsd2tqa203Lm1wMyIsInBhcmFtcyI6W10sImlhdCI6MTcyNTYyOTg0MiwiZXhwIjoxNzI1NzE2MjQyfQ.p7dBSs23II8EtyXtZd0LOwBbc0WlQ1LPjz0CRJBQFsQ'. (Linux UPnP/1.0 Sonos/80.1-55240 (ZPS18))
2024-09-11 21:00:40.393 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╔════════════════════════════════════════════╗
2024-09-11 21:00:40.393 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ║ Chime TTS Say Called. Version v1.1.4-beta4 ║
2024-09-11 21:00:40.393 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╚════════════════════════════════════════════╝
2024-09-11 21:00:40.394 DEBUG (MainThread) [custom_components.chime_tts.queue_manager] Adding service call to queue
2024-09-11 21:00:40.596 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╭────────────────────╮
2024-09-11 21:00:40.596 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] │ General Parameters │
2024-09-11 21:00:40.596 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╰────────────────────╯
2024-09-11 21:00:40.596 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * entity_ids = ['media_player.basement_bedroom']
2024-09-11 21:00:40.596 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * chime_path = /config/www/custom_audio/Alexa_Notification.mp3
2024-09-11 21:00:40.596 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * cache = False
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * offset = 450.0
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * final_delay = 0.0
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * message = Testing testing
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_speed = 100.0
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * tts_pitch = 0
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * announce = False
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * fade_audio = False
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * volume_level = -1
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * join_players = False
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * unjoin_players = False
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] * media_players_array:
2024-09-11 21:00:40.597 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - 0: entity_id: media_player.basement_bedroom
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] platform: sonos
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] initial volume: 0.1
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] target volume: -1.0
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] now playing: False
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] join supported: True
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] announce supported: True
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╭─────────────────╮
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] │ Preparing Audio │
2024-09-11 21:00:40.598 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╰─────────────────╯
2024-09-11 21:00:40.602 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving audio from path: "/config/www/custom_audio/Alexa_Notification.mp3"...
2024-09-11 21:00:40.690 DEBUG (MainThread) [custom_components.chime_tts] ...audio retrieved. Duration: 1.75s
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] - Using default TTS platform: 'google_translate'
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts] - Generating new TTS audio with parameters:
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = 'google_translate'
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts] * message = 'Testing testing'
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts] * cache = False
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts] * language = None
2024-09-11 21:00:40.692 DEBUG (MainThread) [custom_components.chime_tts] * options = {}
2024-09-11 21:00:40.946 DEBUG (MainThread) [custom_components.chime_tts] ...TTS audio generated in 260.0ms
2024-09-11 21:00:40.951 DEBUG (MainThread) [custom_components.chime_tts] - Saving mp3 file to local folder: /media/sounds/temp/chime_tts/...
2024-09-11 21:00:41.047 DEBUG (MainThread) [custom_components.chime_tts.helpers.filesystem] File saved to path: /media/sounds/temp/chime_tts/ays_3vsa.mp3
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] - Chime TTS audio generated:
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] * audio_duration = 3.688
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] * local_path = "/media/sounds/temp/chime_tts/ays_3vsa.mp3"
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] * public_path = None
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] * media_content_id = "media-source://media_source/local/sounds/temp/chime_tts/ays_3vsa.mp3"
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╭────────────────────╮
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] │ Chime TTS playback │
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╰────────────────────╯
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] 1 Sonos media player detected:
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] - media_player.basement_bedroom
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media with data:
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.basement_bedroom']
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] - announce: False
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2024-09-11 21:00:41.127 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/ays_3vsa.mp3
2024-09-11 21:00:41.128 DEBUG (MainThread) [custom_components.chime_tts] - Waiting 3.688s for audio playback to complete...
2024-09-11 21:00:44.820 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] - Waiting until 1 media_player isn't playing...
2024-09-11 21:00:45.223 DEBUG (MainThread) [custom_components.chime_tts.helpers.media_player_helper] ✔ media_player.basement_bedroom
2024-09-11 21:00:45.223 DEBUG (MainThread) [custom_components.chime_tts] Removing temporary file:
2024-09-11 21:00:45.223 DEBUG (MainThread) [custom_components.chime_tts.helpers.filesystem] Deleting file /media/sounds/temp/chime_tts/ays_3vsa.mp3
2024-09-11 21:00:45.225 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╭───────────────────────────────────────────╮
2024-09-11 21:00:45.225 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] │──── Chime TTS Say Completed in 4.63 s ────│
2024-09-11 21:00:45.225 DEBUG (MainThread) [custom_components.chime_tts.helpers.helpers] ╰───────────────────────────────────────────╯
2024-09-11 21:00:45.225 DEBUG (MainThread) [custom_components.chime_tts.queue_manager] Service call completed successfully
2024-09-11 21:00:45.225 DEBUG (MainThread) [custom_components.chime_tts.queue_manager] Queue now empty```
@Nimrod_Dolev thanks for the integration. Is there also a way to use this with the notification
entity as I have some devices (NSPanel Pro) that run HA companion app and I would like to place notifications on them.
Hi Christopher. You can review the notify documentation for guidance on using Chime TTS for notifications.
@derekcentrico Did you find a solution for this? I’ve had the same for some time now, and it’s driving me nuts.
Hey @msl2424. It looks like this isn’t an issue with Chime TTS but with Home Assistant Core.
There’s an open issue here which includes a solution from @derekcentrico.
