Chime TTS - Play audio before/after TTS audio lag free
@Nimrod_Dolev i tried v.0.6.0 and it is not working for me at all now. I am using the same script as before with only one speaker. No sound and no error messages.
Iā€™m sorry to hear that, can you please enable debug logging, run the script and then send me the log messages?
Also: please send me the script you are using so that I can test against it as well.
Unfortunately, the log information is not that informative.
File "/config/custom_components/chime_tts/__init__.py", line 224, in handle_service_calls
File "/config/custom_components/chime_tts/__init__.py", line 130, in async_say_execute
File "/config/custom_components/chime_tts/__init__.py", line 485, in async_get_playback_audio_path
output_audio = get_audio_from_path(hass, chime_path)
File "/config/custom_components/chime_tts/__init__.py", line 604, in get_audio_from_path
@theadlee I think you either did not correctly enable debug logs before calling the service, or you didnā€™t expand the full logs.
If the service is being called, I would expect to see at least the initial debug log.
Can you please follow these steps to reveal the full debug logs?
  1. Enable debug log messages:
    Settings ā†’ Devices & Services ā†’ Chime TTS ā†’ Enable debug logging
  2. Call the chime_tss.say service (or your script which calls the service)
  3. Open the full log messages for Chime TTS:
    Open the log messages: https://YOUR_HA_ADDRESS:8123/config/logs?filter=chime_tts
    Then press the LOAD FULL LOGS button
@Nimrod_Dolev
I figured out what the issue was. When I upgraded to v.0.6.0 it deleted all of my personal mp3s and the directory only contained the stock mp3s. This issue leaves the integration in a broken state which requires a restart of homeassistant.
It seems to be working relatively well now on two speakers that I have running in parallel with the exception of the volume being very low on occasion. I will keep playing with it and report back. Thanks again for your work on this.
I meant to say if the integration cannot find the mp3 it leaves the integration in a broken state.
Thank you, this release seems to indeed solve the issue! Great job!
In further testing on V.0.6.0, the integration will intermittently crash during some TTS events but the main features are working as advertised. I will continue testing with debug turned on and capture the logs.
Iā€™m curious - why does this require a long lived token? Is there no way to get the TTS URL/audio file without using the REST API?
Yes, Chime TTS uses the Home Assistant tts_get_url API to generate the TTS audio and obtain the filepath, which requires a long lived token.
Iā€™ve tried to find a way around this but I couldnā€™t find any other way.
@Nimrod_Dolev for what its worth, I havenā€™t been able to reproduce this issue again on v0.6.0. Service calls to chime_tts seem to all work as expected when using Piper. Iā€™ll let you know if I see this happen again.
Hi @Nimrod_Dolev
I am also having trouble with the integration. I have not been able to get it to work at all with Nabu Casa TTS, the chime plays but no speech. Here are the debug logs:
2023-08-10 16:53:53.706 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called -----
2023-08-10 16:53:53.706 DEBUG (MainThread) [custom_components.chime_tts] * entity_ids = ['media_player.study']
2023-08-10 16:53:53.706 DEBUG (MainThread) [custom_components.chime_tts] * hass = <homeassistant.core.HomeAssistant object at 0x7fadeb8990>
2023-08-10 16:53:53.707 DEBUG (MainThread) [custom_components.chime_tts] * chime_path = custom_components/chime_tts/mp3s/choir.mp3
2023-08-10 16:53:53.707 DEBUG (MainThread) [custom_components.chime_tts] * delay = 450.0
2023-08-10 16:53:53.707 DEBUG (MainThread) [custom_components.chime_tts] * message = Hello
2023-08-10 16:53:53.707 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = cloud_say
2023-08-10 16:53:53.707 DEBUG (MainThread) [custom_components.chime_tts] * tts_playback_speed = 100.0
2023-08-10 16:53:53.708 DEBUG (MainThread) [custom_components.chime_tts] * volume_level = 0.32
2023-08-10 16:53:53.708 DEBUG (MainThread) [custom_components.chime_tts] * cache = True
2023-08-10 16:53:53.708 DEBUG (MainThread) [custom_components.chime_tts] * announce = False
2023-08-10 16:53:53.708 DEBUG (MainThread) [custom_components.chime_tts] ------
2023-08-10 16:53:53.708 DEBUG (MainThread) [custom_components.chime_tts] async_get_playback_audio_path
2023-08-10 16:53:53.709 DEBUG (MainThread) [custom_components.chime_tts] Attempting to retrieve generated mp3 file from cache
2023-08-10 16:53:53.709 DEBUG (MainThread) [custom_components.chime_tts] - async_get_cached_audio_data('583bf8ca5c7c971b1b3ed0dc254fe3ac788e0fcce55cd9025b23b30d901266d5')
2023-08-10 16:53:53.709 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving key/value from chime_tts storage:
2023-08-10 16:53:53.709 DEBUG (MainThread) [custom_components.chime_tts] - key: 583bf8ca5c7c971b1b3ed0dc254fe3ac788e0fcce55cd9025b23b30d901266d5
2023-08-10 16:53:53.710 DEBUG (MainThread) [custom_components.chime_tts] - value: {'audio_path': '/media/sounds/temp/chime_tts/0u4mh1ey.mp3', 'audio_duration': 3.328}
2023-08-10 16:53:53.712 DEBUG (MainThread) [custom_components.chime_tts] - Cached audio data found
2023-08-10 16:53:53.712 DEBUG (MainThread) [custom_components.chime_tts] Using previously generated mp3 saved in cache
2023-08-10 16:53:53.712 DEBUG (MainThread) [custom_components.chime_tts] - audio_dict = {'audio_path': '/media/sounds/temp/chime_tts/0u4mh1ey.mp3', 'audio_duration': 3.328}
2023-08-10 16:53:53.713 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.study", 0.32)
2023-08-10 16:53:53.713 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.study" to: 0.32
2023-08-10 16:53:53.739 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 16:53:53.739 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media service with data:
2023-08-10 16:53:53.739 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/0u4mh1ey.mp3
2023-08-10 16:53:53.739 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2023-08-10 16:53:53.739 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.study']
2023-08-10 16:53:53.810 DEBUG (MainThread) [custom_components.chime_tts] ...media_player.play_media completed.
2023-08-10 16:53:53.811 DEBUG (MainThread) [custom_components.chime_tts] Waiting 3.328s for audio playback to complete...
2023-08-10 16:53:57.143 DEBUG (MainThread) [custom_components.chime_tts] Returning media_player.study's volume level to 0.08
2023-08-10 16:53:57.143 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.study", 0.08)
2023-08-10 16:53:57.143 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.study" to: 0.08
2023-08-10 16:53:57.184 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 16:53:57.185 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Completed in 3479.0589999999997 ms -----
I am currently running v0.6.0. Previously the integration was working with Google TTS but now that doesnā€™t work either! :woozy_face:
EDIT: I have also found the audio file generated in the media folder and I can confirm it is just the chime with no TTS element.
Will
@varyamereon sorry to hear itā€™s not woprking for you.
The log messages you provided were from playing a previously cached generated audio file. Can you please play a new message (one that isnā€™t in the cache), so I can check the logs for what might be going wrong when generating the TTS?
Sure thing:
2023-08-10 17:08:43.288 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called -----
2023-08-10 17:08:43.288 DEBUG (MainThread) [custom_components.chime_tts] * entity_ids = ['media_player.study']
2023-08-10 17:08:43.288 DEBUG (MainThread) [custom_components.chime_tts] * hass = <homeassistant.core.HomeAssistant object at 0x7fadeb8990>
2023-08-10 17:08:43.288 DEBUG (MainThread) [custom_components.chime_tts] * chime_path = custom_components/chime_tts/mp3s/ding_dong.mp3
2023-08-10 17:08:43.289 DEBUG (MainThread) [custom_components.chime_tts] * delay = 450.0
2023-08-10 17:08:43.289 DEBUG (MainThread) [custom_components.chime_tts] * message = Hello
2023-08-10 17:08:43.289 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = cloud_say
2023-08-10 17:08:43.289 DEBUG (MainThread) [custom_components.chime_tts] * tts_playback_speed = 100.0
2023-08-10 17:08:43.289 DEBUG (MainThread) [custom_components.chime_tts] * volume_level = 0.36
2023-08-10 17:08:43.290 DEBUG (MainThread) [custom_components.chime_tts] * cache = True
2023-08-10 17:08:43.290 DEBUG (MainThread) [custom_components.chime_tts] * announce = False
2023-08-10 17:08:43.290 DEBUG (MainThread) [custom_components.chime_tts] ------
2023-08-10 17:08:43.290 DEBUG (MainThread) [custom_components.chime_tts] async_get_playback_audio_path
2023-08-10 17:08:43.291 DEBUG (MainThread) [custom_components.chime_tts] Attempting to retrieve generated mp3 file from cache
2023-08-10 17:08:43.291 DEBUG (MainThread) [custom_components.chime_tts] - async_get_cached_audio_data('d4eb43cffc8587a27197cd4ac6cf081679f48653aee4b6a9c6a556b95813b099')
2023-08-10 17:08:43.291 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving key/value from chime_tts storage:
2023-08-10 17:08:43.291 DEBUG (MainThread) [custom_components.chime_tts] - key: d4eb43cffc8587a27197cd4ac6cf081679f48653aee4b6a9c6a556b95813b099
2023-08-10 17:08:43.291 DEBUG (MainThread) [custom_components.chime_tts] - value: {'audio_path': '/media/sounds/temp/chime_tts/fhg_d5g8.mp3', 'audio_duration': 2.005}
2023-08-10 17:08:43.292 WARNING (MainThread) [custom_components.chime_tts] Could not find previosuly cached generated mp3 file
2023-08-10 17:08:43.299 DEBUG (MainThread) [custom_components.chime_tts] get_audio_from_path("custom_components/chime_tts/mp3s/ding_dong.mp3", 0, audio)
2023-08-10 17:08:43.299 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving audio from path: "custom_components/chime_tts/mp3s/ding_dong.mp3"...
2023-08-10 17:08:43.665 DEBUG (MainThread) [custom_components.chime_tts] - ...audio with duration 1.533s retrieved successfully
2023-08-10 17:08:43.665 DEBUG (MainThread) [custom_components.chime_tts] Cached TTS mp3 file exists?
2023-08-10 17:08:43.665 DEBUG (MainThread) [custom_components.chime_tts] - async_get_cached_audio_data('ad14d27cfbee1b282fd033bc90f8aeb6ea8f375c2d5c22e69073a5374f7b1e9c')
2023-08-10 17:08:43.665 DEBUG (MainThread) [custom_components.chime_tts] - Audio data not found in cache.
2023-08-10 17:08:43.666 DEBUG (MainThread) [custom_components.chime_tts] - filepath_hash ad14d27cfbee1b282fd033bc90f8aeb6ea8f375c2d5c22e69073a5374f7b1e9c does not exist in the cache.
2023-08-10 17:08:43.666 DEBUG (MainThread) [custom_components.chime_tts] - Cached TTS mp3 file not found
2023-08-10 17:08:43.666 DEBUG (MainThread) [custom_components.chime_tts] async_request_tts_audio_filepath(hass, tts_platform="cloud_say", message="Hello", language="None", tld="None", gender="None"))
2023-08-10 17:08:43.666 DEBUG (MainThread) [custom_components.chime_tts] Requesting TTS audio:
2023-08-10 17:08:43.667 DEBUG (MainThread) [custom_components.chime_tts] * url = http://192.168.1.41:8123/api/tts_get_url
2023-08-10 17:08:43.667 DEBUG (MainThread) [custom_components.chime_tts] * headers = {'Authorization': 'Bearer eyJhb##########DtMrE', 'Content-Type': 'application/json'}
2023-08-10 17:08:43.667 DEBUG (MainThread) [custom_components.chime_tts] * data = {"message": "Hello", "platform": "cloud_say", "cache": true}
2023-08-10 17:08:43.667 DEBUG (MainThread) [custom_components.chime_tts] * timeout = 10
2023-08-10 17:08:43.691 DEBUG (MainThread) [custom_components.chime_tts] - Repsonse status_code: "500"
2023-08-10 17:08:43.691 DEBUG (MainThread) [custom_components.chime_tts] - Repsonse received: "500: Internal Server Error"
2023-08-10 17:08:43.691 WARNING (MainThread) [custom_components.chime_tts] TTS Audio request unsuccessful: '500: Internal Server Error'
2023-08-10 17:08:43.693 DEBUG (MainThread) [custom_components.chime_tts] - No TTS filepaths returned
2023-08-10 17:08:43.694 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving audio from path: "custom_components/chime_tts/mp3s/_blank.mp3"...
2023-08-10 17:08:44.012 DEBUG (MainThread) [custom_components.chime_tts] - ...audio with duration 0.022s retrieved successfully
2023-08-10 17:08:44.016 DEBUG (MainThread) [custom_components.chime_tts] - Final audio created:
2023-08-10 17:08:44.016 DEBUG (MainThread) [custom_components.chime_tts] - Duration = 2.005s
2023-08-10 17:08:44.016 DEBUG (MainThread) [custom_components.chime_tts] Creating final audio file
2023-08-10 17:08:44.018 DEBUG (MainThread) [custom_components.chime_tts] - Temp folder exists: /media/sounds/temp/chime_tts/
2023-08-10 17:08:44.018 DEBUG (MainThread) [custom_components.chime_tts] - Creating temporary mp3 file...
2023-08-10 17:08:44.019 DEBUG (MainThread) [custom_components.chime_tts] - temp_obj = <tempfile._TemporaryFileWrapper object at 0x7f9d9e2010>
2023-08-10 17:08:44.021 DEBUG (MainThread) [custom_components.chime_tts] - Filepath = '/media/sounds/temp/chime_tts/n_e_lupo.mp3'
2023-08-10 17:08:44.322 DEBUG (MainThread) [custom_components.chime_tts] - File saved successfully
2023-08-10 17:08:44.323 DEBUG (MainThread) [custom_components.chime_tts] - audio_dict = {'audio_path': '/media/sounds/temp/chime_tts/n_e_lupo.mp3', 'audio_duration': 2.005}
2023-08-10 17:08:44.323 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.study", 0.36)
2023-08-10 17:08:44.323 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.study" to: 0.36
2023-08-10 17:08:44.349 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 17:08:44.349 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media service with data:
2023-08-10 17:08:44.349 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/n_e_lupo.mp3
2023-08-10 17:08:44.349 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2023-08-10 17:08:44.350 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.study']
2023-08-10 17:08:44.420 DEBUG (MainThread) [custom_components.chime_tts] ...media_player.play_media completed.
2023-08-10 17:08:44.421 DEBUG (MainThread) [custom_components.chime_tts] Waiting 2.005s for audio playback to complete...
2023-08-10 17:08:46.432 DEBUG (MainThread) [custom_components.chime_tts] Returning media_player.study's volume level to 0.08
2023-08-10 17:08:46.432 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.study", 0.08)
2023-08-10 17:08:46.433 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.study" to: 0.08
2023-08-10 17:08:46.465 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 17:08:46.465 DEBUG (MainThread) [custom_components.chime_tts] Saving generated mp3 file to cache
2023-08-10 17:08:46.465 DEBUG (MainThread) [custom_components.chime_tts] Saving to chime_tts storage:
2023-08-10 17:08:46.465 DEBUG (MainThread) [custom_components.chime_tts] - key: "d4eb43cffc8587a27197cd4ac6cf081679f48653aee4b6a9c6a556b95813b099"
2023-08-10 17:08:46.465 DEBUG (MainThread) [custom_components.chime_tts] - value: "{'audio_path': '/media/sounds/temp/chime_tts/n_e_lupo.mp3', 'audio_duration': 2.005}"
2023-08-10 17:08:46.474 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Completed in 3186.735 ms -----
I see the 500 error, just out of interest calling the tts.cloud_say service works fine.
Will
I am still having issues with the integration stopping. It take a reboot to get it started again. Below is log of a recent event where the service stopped and would not restart.
2023-08-10 10:45:08.740 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called -----
2023-08-10 10:45:08.740 DEBUG (MainThread) [custom_components.chime_tts] * entity_ids = []
2023-08-10 10:45:08.740 DEBUG (MainThread) [custom_components.chime_tts] * hass = <homeassistant.core.HomeAssistant object at 0x7fa430935950>
2023-08-10 10:45:08.741 DEBUG (MainThread) [custom_components.chime_tts] * delay = 450.0
2023-08-10 10:45:08.742 DEBUG (MainThread) [custom_components.chime_tts] * tts_playback_speed = 100.0
2023-08-10 10:45:08.742 DEBUG (MainThread) [custom_components.chime_tts] * volume_level = 1.0
2023-08-10 10:45:08.742 DEBUG (MainThread) [custom_components.chime_tts] * cache = False
2023-08-10 10:45:08.742 DEBUG (MainThread) [custom_components.chime_tts] * announce = False
2023-08-10 10:45:08.742 DEBUG (MainThread) [custom_components.chime_tts] ------
2023-08-10 10:45:08.743 ERROR (MainThread) [custom_components.chime_tts] No valid media player found
2023-08-10 10:45:08.746 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called -----
2023-08-10 10:45:08.746 DEBUG (MainThread) [custom_components.chime_tts] * entity_ids = ['media_player.workout_room_2', 'media_player.living_room']
2023-08-10 10:45:08.746 DEBUG (MainThread) [custom_components.chime_tts] * hass = <homeassistant.core.HomeAssistant object at 0x7fa430935950>
2023-08-10 10:45:08.746 DEBUG (MainThread) [custom_components.chime_tts] * chime_path = custom_components/chime_tts/mp3s/teams_drip_drop.mp3
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * delay = 600.0
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * message = Todd is ending a Teams Meeting
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = amazon_polly
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * tts_playback_speed = 100.0
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * volume_level = 0.25
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * cache = True
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] * announce = True
2023-08-10 10:45:08.747 DEBUG (MainThread) [custom_components.chime_tts] ------
2023-08-10 10:45:08.748 DEBUG (MainThread) [custom_components.chime_tts] async_get_playback_audio_path
2023-08-10 10:45:08.748 DEBUG (MainThread) [custom_components.chime_tts] Attempting to retrieve generated mp3 file from cache
2023-08-10 10:45:08.748 DEBUG (MainThread) [custom_components.chime_tts] - async_get_cached_audio_data('ef6499742dc0546ccc38693aa2be1a000b30ed0cf322e67677c4bbe4dac44023')
2023-08-10 10:45:08.748 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving key/value from chime_tts storage:
2023-08-10 10:45:08.748 DEBUG (MainThread) [custom_components.chime_tts] - key: ef6499742dc0546ccc38693aa2be1a000b30ed0cf322e67677c4bbe4dac44023
2023-08-10 10:45:08.748 DEBUG (MainThread) [custom_components.chime_tts] - value: {'audio_path': '/media/sounds/temp/chime_tts/xec9gqef.mp3', 'audio_duration': 4.042}
2023-08-10 10:45:08.749 DEBUG (MainThread) [custom_components.chime_tts] - Cached audio data found
2023-08-10 10:45:08.749 DEBUG (MainThread) [custom_components.chime_tts] Using previously generated mp3 saved in cache
2023-08-10 10:45:08.749 DEBUG (MainThread) [custom_components.chime_tts] - audio_dict = {'audio_path': '/media/sounds/temp/chime_tts/xec9gqef.mp3', 'audio_duration': 4.042}
2023-08-10 10:45:08.749 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.workout_room_2", 0.25)
2023-08-10 10:45:08.749 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.workout_room_2" to: 0.25
2023-08-10 10:45:08.785 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 10:45:08.785 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.living_room", 0.25)
2023-08-10 10:45:08.785 DEBUG (MainThread) [custom_components.chime_tts] - Skipped setting volume
2023-08-10 10:45:08.785 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media service with data:
2023-08-10 10:45:08.786 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/xec9gqef.mp3
2023-08-10 10:45:08.786 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2023-08-10 10:45:08.786 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.workout_room_2', 'media_player.living_room']
2023-08-10 10:45:08.786 DEBUG (MainThread) [custom_components.chime_tts] - announce: True
2023-08-10 10:45:08.820 DEBUG (MainThread) [custom_components.chime_tts] ...media_player.play_media completed.
2023-08-10 10:45:08.821 DEBUG (MainThread) [custom_components.chime_tts] Waiting 4.042s for audio playback to complete...
2023-08-10 10:45:12.866 DEBUG (MainThread) [custom_components.chime_tts] Waiting 0.0006s for final_delay to complete...
2023-08-10 10:45:13.470 DEBUG (MainThread) [custom_components.chime_tts] Returning media_player.workout_room_2's volume level to 0.14
2023-08-10 10:45:13.470 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.workout_room_2", 0.14)
2023-08-10 10:45:13.470 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.workout_room_2" to: 0.14
2023-08-10 10:45:13.486 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 10:45:13.486 DEBUG (MainThread) [custom_components.chime_tts] Returning media_player.living_room's volume level to 0.25
2023-08-10 10:45:13.486 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.living_room", 0.25)
2023-08-10 10:45:13.486 DEBUG (MainThread) [custom_components.chime_tts] - Skipped setting volume
2023-08-10 10:45:13.486 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Completed in 4740.732 ms -----
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called -----
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * entity_ids = []
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * hass = <homeassistant.core.HomeAssistant object at 0x7fa430935950>
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * delay = 450.0
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * tts_playback_speed = 100.0
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * volume_level = 1.0
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * cache = False
2023-08-10 10:45:13.487 DEBUG (MainThread) [custom_components.chime_tts] * announce = False
2023-08-10 10:45:13.488 DEBUG (MainThread) [custom_components.chime_tts] ------
2023-08-10 10:45:13.488 ERROR (MainThread) [custom_components.chime_tts] No valid media player found
2023-08-10 10:59:52.186 DEBUG (MainThread) [custom_components.chime_tts] ----- Chime TTS Say Called -----
2023-08-10 10:59:52.186 DEBUG (MainThread) [custom_components.chime_tts] * entity_ids = ['media_player.workout_room_2', 'media_player.living_room']
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * hass = <homeassistant.core.HomeAssistant object at 0x7fa430935950>
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * chime_path = custom_components/chime_tts/mp3s/keys.mp3
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * delay = 600.0
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * message = Garage Door Open
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * tts_platform = amazon_polly
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * tts_playback_speed = 100.0
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * volume_level = 0.25
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * cache = True
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] * announce = True
2023-08-10 10:59:52.187 DEBUG (MainThread) [custom_components.chime_tts] ------
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] async_get_playback_audio_path
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] Attempting to retrieve generated mp3 file from cache
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] - async_get_cached_audio_data('4fa4eb1935d4583503c2ede6035d677f4291d765f5c48d417f8a5bacc6bdd6f5')
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving key/value from chime_tts storage:
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] - key: 4fa4eb1935d4583503c2ede6035d677f4291d765f5c48d417f8a5bacc6bdd6f5
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] - value: {'audio_path': '/media/sounds/temp/chime_tts/kptqvl_i.mp3', 'audio_duration': 2.661}
2023-08-10 10:59:52.188 DEBUG (MainThread) [custom_components.chime_tts] - Cached audio data found
2023-08-10 10:59:52.189 DEBUG (MainThread) [custom_components.chime_tts] Using previously generated mp3 saved in cache
2023-08-10 10:59:52.189 DEBUG (MainThread) [custom_components.chime_tts] - audio_dict = {'audio_path': '/media/sounds/temp/chime_tts/kptqvl_i.mp3', 'audio_duration': 2.661}
2023-08-10 10:59:52.189 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.workout_room_2", 0.25)
2023-08-10 10:59:52.189 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.workout_room_2" to: 0.25
2023-08-10 10:59:52.213 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 10:59:52.213 DEBUG (MainThread) [custom_components.chime_tts] - async_set_volume_level("media_player.living_room", 0.25)
2023-08-10 10:59:52.213 DEBUG (MainThread) [custom_components.chime_tts] - Seting volume_level of media player "media_player.living_room" to: 0.25
2023-08-10 10:59:52.269 DEBUG (MainThread) [custom_components.chime_tts] - Volume set
2023-08-10 10:59:52.269 DEBUG (MainThread) [custom_components.chime_tts] Calling media_player.play_media service with data:
2023-08-10 10:59:52.270 DEBUG (MainThread) [custom_components.chime_tts] - media_content_id: media-source://media_source/local/sounds/temp/chime_tts/kptqvl_i.mp3
2023-08-10 10:59:52.270 DEBUG (MainThread) [custom_components.chime_tts] - media_content_type: music
2023-08-10 10:59:52.270 DEBUG (MainThread) [custom_components.chime_tts] - entity_id: ['media_player.workout_room_2', 'media_player.living_room']
2023-08-10 10:59:52.270 DEBUG (MainThread) [custom_components.chime_tts] - announce: True
File "/config/custom_components/chime_tts/__init__.py", line 179, in async_say_execute
I canā€™t get the integration to run for more than a few hours without crashing. Here is another log dump.
2023-08-10 21:00:00.965 DEBUG (MainThread) [custom_components.chime_tts] * data = {"message": "The Time Is 9:00 PM", "platform": "amazon_polly", "cache": true}
2023-08-10 21:00:00.966 DEBUG (MainThread) [custom_components.chime_tts] * timeout = 10
2023-08-10 21:00:02.184 DEBUG (MainThread) [custom_components.chime_tts] - Repsonse status_code: "200"
2023-08-10 21:00:02.185 DEBUG (MainThread) [custom_components.chime_tts] - Repsonse received: "{"url":"http://192.168.7.202:8123/api/tts_proxy/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3","path":"/api/tts_proxy/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3"}"
2023-08-10 21:00:02.185 DEBUG (MainThread) [custom_components.chime_tts] - TTS filepaths = {'path': '/config/tts/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3', 'url': 'http://192.168.7.202:8123/api/tts_proxy/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3'}
2023-08-10 21:00:02.185 DEBUG (MainThread) [custom_components.chime_tts] - TTS file path found: /config/tts/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3
2023-08-10 21:00:02.186 DEBUG (MainThread) [custom_components.chime_tts] Saving to chime_tts storage:
2023-08-10 21:00:02.186 DEBUG (MainThread) [custom_components.chime_tts] - key: "1fa2638756c57ab8e55099131d558aa6516bdfdd976a75759258cb85bb66a38c"
2023-08-10 21:00:02.186 DEBUG (MainThread) [custom_components.chime_tts] - value: "{'audio_path': '/config/tts/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3', 'audio_duration': None}"
2023-08-10 21:00:02.197 DEBUG (MainThread) [custom_components.chime_tts] get_audio_from_path("/config/tts/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3", 0.1, audio)
2023-08-10 21:00:02.198 DEBUG (MainThread) [custom_components.chime_tts] - Retrieving audio from path: "/config/tts/3c468b5886c4a84c7cec982bc7df6c7c0de9e74c_en-us_98338dd59c_amazon_polly.mp3"...
File "/config/custom_components/chime_tts/__init__.py", line 535, in async_get_playback_audio_path
It appears the new queueing feature is responsible.
For now I have release v0.6.1 which removes the service queue addition.
I will try to change the way service calls are queued in the next release.
v0.6.1 has been working great so far. I was also experiencing a delay between speakers on the prior release and that seems to have gone away also. I really donā€™t need the queue feature, I am calling the service from a script that I have set to queued mode and that seems to work just fine.
Glad to hear it, thanks for the feedback :+1:
I have been testing v0.6.1. Two issues still open. Sometimes the volume does not revert to what was before the announcement is played. Secondly, all the speaker are not 100% in sync. There is about a 200ms delay between speakers during an announcement. I am test by sending the announcement to three speakers.
