Chromecast Radio with station and player selection
@vladosam try this:
  radio538:
    alias: Play Radio on Chromecast Audio
      - service: media_player.volume_set
        data_template:
          entity_id: >
            {% if is_state("input_select.chromecast_radio", "Livingroom") %} media_player.ca_livingroom
            {% elif is_state("input_select.chromecast_radio", "Hall") %} media_player.ca_hall
            {% elif is_state("input_select.chromecast_radio", "Bedroom") %} media_player.bed_room
            {% elif is_state("input_select.chromecast_radio", "Bathroom") %} media_player.ca_bathroom
            {% elif is_state("input_select.chromecast_radio", "Everywhere") %} media_player.home_group
          volume_level: '{{  states.input_slider.volume_radio.state  }}'
      - service: tts.amazon_polly_say
        data_template:
          entity_id: >
          message: "Next station: {{ states.input_select.radio_station.state  }}"
      - delay: '00:00:08'
      -  service: media_player.play_media
         data_template:
           entity_id: >
           media_content_id: >
            {% if is_state("input_select.radio_station", "Radio 538") %} http://vip-icecast.538.lw.triple-it.nl:80/RADIO538_MP3
            {% elif is_state("input_select.radio_station", "Q-Music") %} http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3
            {% elif is_state("input_select.radio_station", "3FM") %} http://icecast.omroep.nl/3fm-bb-mp3
            {% elif is_state("input_select.radio_station", "100% NL") %} http://stream.100p.nl/100pctnl.mp3
            {% elif is_state("input_select.radio_station", "Veronica") %} http://8543.live.streamtheworld.com/VERONICACMP3
            {% elif is_state("input_select.radio_station", "Sky Radio") %} http://8623.live.streamtheworld.com:80/SKYRADIOAAC_SC
            {% elif is_state("input_select.radio_station", "Arrow Classic Rock") %} http://91.221.151.155/listen.mp3
            {% elif is_state("input_select.radio_station", "Classic FM") %} http://19143.live.streamtheworld.com/CLASSICFM_SC
            {% elif is_state("input_select.radio_station", "BNR Nieuwsradio") %} http://icecast-bnr.cdp.triple-it.nl/bnr_mp3_96_03
            {% elif is_state("input_select.radio_station", "Smooth Jazz Tampa") %} http://us3.internet-radio.com:8007/listen.mp3
            {% elif is_state("input_select.radio_station", "Classic Rock Florida") %} http://listen.shoutcast.com/Classic-RockFlorida
            {% elif is_state("input_select.radio_station", "Bob Sinclar Radio") %} http://listen.shoutcast.com/prysmradio09-mp3
            {% elif is_state("input_select.radio_station", "Chill Out Zone") %} http://air.chillout.zone:8000/radio
            {% elif is_state("input_select.radio_station", "SLAM! Hardstyle") %} http://stream.radiocorp.nl/web11_mp3
            {% elif is_state("input_select.radio_station", "Sleep Radio") %} http://37.59.28.208:8722/stream
            {% elif is_state("input_select.radio_station", "Ambient Sleeping Pill") %} http://perseus.shoutca.st:8447/h
            {% elif is_state("input_select.radio_station", "Radio Art - Sleep") %} http://live.radioart.com/fSleep.mp3
            {% elif is_state("input_select.radio_station", "Ambi Nature Radio") %} http://94.23.252.14:8067/stream
            {% elif is_state("input_select.radio_station", "Calm Radio - Sleep") %} http://streams.calmradio.com/api/39/128/stream
            {% elif is_state("input_select.radio_station", "Dinamo.FM Sleep") %} http://channels.dinamo.fm/sleep-aac
           media_content_type: 'audio/mp4'
I you don’t have Amazin Polly setup, use Google TTS instead.
Also, the delay of 8 seconds is just an estimate, change if needed.
Update:
You can also try this for the delay:
      - delay: >
            {% if is_state("input_select.chromecast_radio", "Livingroom") %} '00:00:{{ states.media_player.ca_livingroom.attributes.media_duration | int }}'
            {% elif is_state("input_select.chromecast_radio", "Hall") %}  '00:00:{{ states.media_player.ca_hall.attributes.media_duration | int }}'
            {% elif is_state("input_select.chromecast_radio", "Bedroom") %}  '00:00:{{ states.media_player.media_player.bed_room.attributes.media_duration | int }}'
            {% elif is_state("input_select.chromecast_radio", "Bathroom") %}  '00:00:{{ states.media_player.media_player.ca_bathroom.attributes.media_duration | int }}'
            {% elif is_state("input_select.chromecast_radio", "Everywhere") %}  '00:00:{{ states.media_player.media_player.home_group.attributes.media_duration | int }}'
I’m not sure if templating is possible in the delay section though.
Works like a charm with google tts. :smiley: Thanks Bob.
I love this Chromecast Radio integration! Thanks @Bob_NL :+1:
I made a radio station list mixing in stations from my RTL-SDR using rtl_fm_streamer for some Internet-free streaming local radio stations.
It would be made even easier if input_select supported a data payload like in the Feature Request linked below. Consider voting on it to greatly simplify this type of scripting.
Did you put script.radio538 in the group for viewing?
from where did you get stream links? i want to get some arabic channel.
I have actually made a spotify version of this - it works fine - the only problem is that the spotify component have a bad memory when it comes to sources, especially if you use multiple chromecasts - rendering it useless to me at the moment. However if anybody have better luck with spotify i’ll love to share.
UPDATE:
The spotify version can be found here: Spotify Playlist Player :slight_smile:
I’m assuming that all these multi speakers solutions requires to keep the speakers powered all the time. I mean, you are not using home assistant to turn on the speaker. Am I right?
I would like to make something similar, but the fact that it will drain power while not in use really annoys me… :yum:
You can, but it will depend on what your speaker setup. With my yamaha AVR I have auto on and off working with squeezebox, chromecasts, mibox and you can use it with any media player that reports its state to hass.
Have a look at the last part of the first post in this thread.
This is my first ever try with HA, i installed it manually on my RBP3, the aim of this is that I wanted to say hey google good morning, it would dim the lights (already done through smartthings) AND play music on chromecast (I have the 2nd gen chromecast not audio) <- this i got told can only be done with HA
So now i installed it and i used the following in my configurations.yaml:
 radio538:
    data_template:
      entity_id: >
     data_template:
       entity_id: >
       media_content_id: >
I now get the activate but nothing happens…
I can see my Chromecast widget and my Google home widget as well, the logs shows this:
2017-09-24 18:42:12 INFO (MainThread) [homeassistant.helpers.script] Script Play Radio on Chromecast: Executing step call service
2017-09-24 18:42:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=1972524368-57, domain=media_player, service_data=entity_id=, media_content_id=, media_content_type=audio/mp4, service=play_media>
2017-09-24 18:42:12 ERROR (MainThread) [homeassistant.core] Invalid service data for media_player.play_media: Entity ID is an invalid entity id for dictionary value @ data[‘entity_id’]. Got ‘’
2017-09-24 18:42:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1972524368-57>
2017-09-24 18:42:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1972524368-55>
2017-09-24 18:42:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=script.radio538, old_state=<state script.radio538=off; last_triggered=2017-09-24T20:36:52.562368+02:00, friendly_name=Play Radio on Chromecast @ 2017-09-24T20:34:24.628233+02:00>, new_state=<state script.radio538=off; last_triggered=2017-09-24T20:42:12.046148+02:00, friendly_name=Play Radio on Chromecast @ 2017-09-24T20:34:24.628233+02:00>>
Any help is appreciated
Some things to try:
  • collapse whitespace. use a - after the > and remove the space after the curly brace that closes the if/elif statement. indentation is significant. the extra space could cause trouble
  • test everything in the template dev tool, just to make sure that your if/elif returns what you expect it to return.
    entity_id: >-
        {% if is_state("input_select.chromecast_radio", "Livingroom") %}media_player.ca_livingroom
Very thankful for reaching this topic. I use to play on a speaker connected do the raspberry pi aux port. My custom implementation was:
Changed the script
To: media_content_type: ‘audio/mp3’
I also created a intent script to start the radio by voice commands (api.ai / actions on google):
ListenToRadio:
speech:
text: >
{%- if OnOff == “on” -%}
You are listening to {{ RadioStation }}
{%- else -%}
Turning off the radio
{%- endif -%}
- service: input_select.select_option
data_template:
entity_id: input_select.chromecast_radio
option: OrangePi
data_template:
entity_id: input_select.radio_station
option: >
{{ RadioStation }}
{%- else -%}
Stop
{%- endif -%}
- service: script.radio_start
Change the entity_id’s to your media player id’s, I see you are using my exact same names which would be very coincidental :slight_smile:
That’s correct. I’m using a couple of simple ball speakers which hardly use any power but you’re right it is a drain.
Ok so now I have this in my config:
script:
radio538:
entity_id: media_player.chromecast
volume_level: ‘0.35’
volume_level: ‘0.20’
volume_level: ‘0.30’
- service: media_player.chromecast
data_template:
entity_id: >
{% if is_state(“input_select.chromecast_radio”, “Livingroom”) %} media_player.chromecast
{% elif is_state(“input_select.chromecast_radio”, “Hall”) %} media_player.chromecast
{% elif is_state(“input_select.chromecast_radio”, “Bedroom”) %} media_player.chromecast
{% elif is_state(“input_select.chromecast_radio”, “Bathroom”) %} media_player.chromecast
{% elif is_state(“input_select.chromecast_radio”, “Everywhere”) %} media_player.chromecast
media_content_id: >
{% if is_state(“input_select.radio_station”, “Radio 538”) %} http://vip-icecast.538.lw.triple-it.nl:80/RADIO538_MP3
{% elif is_state(“input_select.radio_station”, “Q-Music”) %} http://icecast-qmusic.cdp.triple-it.nl/Qmusic_nl_live_96.mp3
{% elif is_state(“input_select.radio_station”, “3FM”) %} http://icecast.omroep.nl/3fm-bb-mp3
{% elif is_state(“input_select.radio_station”, “100% NL”) %} http://stream.100p.nl/100pctnl.mp3
{% elif is_state(“input_select.radio_station”, “Veronica”) %} http://8543.live.streamtheworld.com/VERONICACMP3
{% elif is_state(“input_select.radio_station”, “Sky Radio”) %} http://8623.live.streamtheworld.com:80/SKYRADIOAAC_SC
{% elif is_state(“input_select.radio_station”, “Arrow Classic Rock”) %} http://91.221.151.155/listen.mp3
{% elif is_state(“input_select.radio_station”, “Classic FM”) %} http://19143.live.streamtheworld.com/CLASSICFM_SC
{% elif is_state(“input_select.radio_station”, “BNR Nieuwsradio”) %} http://icecast-bnr.cdp.triple-it.nl/bnr_mp3_96_03
{% elif is_state(“input_select.radio_station”, “SLAM! Hardstyle”) %} http://vip-icecast.538.lw.triple-it.nl/WEB17_MP3
{% elif is_state(“input_select.radio_station”, “Sleep Radio”) %} http://37.59.28.208:8722/stream
{% elif is_state(“input_select.radio_station”, “Ambient Sleeping Pill”) %} http://perseus.shoutca.st:8447/h
{% elif is_state(“input_select.radio_station”, “Radio Art - Sleep”) %} http://live.radioart.com/fSleep.mp3
{% elif is_state(“input_select.radio_station”, “Ambi Nature Radio”) %} http://94.23.252.14:8067/stream
{% elif is_state(“input_select.radio_station”, “Calm Radio - Sleep”) %} http://streams.calmradio.com/api/39/128/stream
{% elif is_state(“input_select.radio_station”, “Dinamo.FM Sleep”) %} http://channels.dinamo.fm/sleep-aac
media_content_type: ‘audio/mp4’
and now i get this, not sure exactly what to change:
2017-09-25 20:28:33 WARNING (MainThread) [homeassistant.core] Unable to find service media_player/chromecast
Please use blockquotes or preformatted text when posting code so we can debug. This is unreadable. Thanks.
done, apologies
I Also never get past the Activate widget…i never seen a drop down menu to choose speakers or stations…
however, if i click activate, the volume slider appears on TV and thats the best it went…
Hmmm
I’ve been trying for 15 min. to paste my configurations.yaml in blockquoted or preformatted and it just won’t work!!!
Here it is:
indent preformatted text by 4 spaces
pi@raspberrypi:~ $ cat .homeassistant/configuration.yaml
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 31.2156
longitude: 29.9553
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: List of tz database time zones - Wikipedia
time_zone: Africa/Cairo
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
http:
Uncomment this to add a password (recommended!)
api_password: PASSWORD
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
base_url: example.duckdns.org:8123
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
Explaining the Updater - Home Assistant
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Track the sun
sun:
Weather prediction
  • platform: yr
Text to speech
tts:
  • platform: google
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
mqtt:
broker: 192.168.2.228
port: 9001
client_id: mqttc
discovery: true
discovery_prefix: smartthings
light:
  • platform: mqtt
    name: “Far Right Stand”
    brightness_command_topic: “smartthings/Far Right Stand/level/set”
    brightness_state_topic: “smartthings/Far Right Stand/level”
    command_topic: “smartthings/Far Right Stand/switch”
    optimistic: false
    payload_off: “off”
    payload_on: “on”
    qos: 0
    state_topic: “smartthings/Far Right Stand/switch”
  • platform: mqtt
    brightness_command_topic: “smartthings/Right Stand/level/set”
    brightness_state_topic: “smartthings/Right Stand/level”
    command_topic: “smartthings/Right Stand/switch”
    optimistic: false
    payload_off: “off”
    payload_on: “on”
    qos: 0
    state_topic: “smartthings/Right Stand/switch”
script:
radio538:
media_content_id: >
ios:
Thank you so much for posting your code. i was looking for something exactly like this!
For my setup, I have a Monoprice Six Zone controller/amp connected to HomeAssistant. The Monoprice unit has six inputs and six speaker zones. I have one Chromecast connected as an input, and I can output it to all any or all zones. The Monoprice unit doesn’t natively support groups, but I added group support via groups.yaml. It works a treat.
Thanks again!
