Chromecast Radio with station and player selection
First I want to thank @Bob_NL for the initial code and concept and I also want to thank @lolouk44 as I used his github repository to piece it all together into a package. I prefer to use packages now as all of the code is in one place and you don’t need to remember where all of the bits are.
If you have not used packages before make sure you add the following to your configuration.yaml file:
configuration.yaml
  customize: !include customize.yaml
  packages: !include_dir_named packages
Then create a folder called “packages” in your main config folder.
Then create a file called “radio.yaml” or what ever you want to call it.
Then copy in the following and edit your radio stations and media players.
radio.yaml
#Initial code and concept Bob_NL https://community.home-assistant.io/t/chromecast-radio-with-station-and-player-selection/12732/1
#Converted into a package by wills106 https://community.home-assistant.io/t/chromecast-radio-with-station-and-player-selection/12732/419
group:
  Radio:
    icon: mdi:radio
    entities:
    - input_select.chromecast_radio_station
    - input_text.custom_station
    - input_select.chromecast_radio_speakers
    - input_number.volume_radio
    - script.play_chromecast_radio
    - script.stop_chromecast_radio
input_select:
  chromecast_radio_station:
    name: 'Select Radio Station'
    options:
      - Absolute Radio Classic Rock
      - RealXS Manchester
      - Custom Station
    icon: mdi:radio
  chromecast_radio_speakers:
    name: 'Select Speakers'
    options:
      - LivingRoom
      - Bedroom
      - TV
      - All
    initial: LivingRoom
    icon: mdi:speaker-wireless
input_text:
  custom_station:
    icon: mdi:link-variant
input_number:
  volume_radio:
    icon: mdi:volume-high
    initial: 0.3
    min: 0
    max: 1
    step: 0.05
script:
  play_chromecast_radio:
    alias: Cast Selected Radio on Chromecast Speakers
      - service: media_player.volume_set
        data_template:
          entity_id: >
            {% if is_state("input_select.chromecast_radio_speakers", "LivingRoom") %} media_player.living_room_speaker
            {% elif is_state("input_select.chromecast_radio_speakers", "Bedroom") %} media_player.bedroom_speaker
            {% elif is_state("input_select.chromecast_radio_speakers", "TV") %} media_player.chromecast0899
            {% elif is_state("input_select.chromecast_radio_speakers", "All") %} media_player.home_group
          volume_level: '{{  states.input_number.volume_radio.state  }}'
        data_template:
          entity_id: >
          media_content_id: >
            {% if is_state("input_select.chromecast_radio_station", "Absolute Radio Classic Rock") %} http://icy-e-bab-04-cr.sharp-stream.com/absoluteclassicrock.mp3
            {% elif is_state("input_select.chromecast_radio_station", "RealXS Manchester") %} http://media-ice.musicradio.com:80/RealXSManchesterMP3
            {% elif is_state("input_select.chromecast_radio_station", "Custom Station") %} {{states.input_text.custom_station.state}}
          media_content_type: 'audio/mp4'
  stop_chromecast_radio:
    alias: Stop Playing Radio on ChromeCast
      - service: media_player.turn_off
        data_template:
          entity_id: >
Then to clean it up a bit I add the following to the customize.yaml file in the main config folder:
customize.yaml
script.play_chromecast_radio:
  friendly_name: Play
  icon: mdi:play
script.stop_chromecast_radio:
  friendly_name: Stop
  icon: mdi:stop
radio
You then should end up with something looking like this.
