Chromecast Radio with station and player selection
You will have to add a “Entities Card”
Have a look at https://github.com/wills106/homeassistant-config/tree/master/packages/lovelace-example for an example.
Look at the ChromeCastRadio file.
Hi @ASNNetworks
Can you share the card config, not everything behind, but the build-up of the card and the styling?
Unfortunately not. I use LMS for music now, which renders my previous setup redundant. I used that for Google Cast service calls which I no longer use.
But basically what you see there is:
  • Input select playlist
  • Input select speaker
  • Script to start service call for selected playlist over the selected speaker
  • My custom media player based on picture elements and mini media player (see this)
This all inside a vertical stack, which opens through popup with browser mod.
Thanks for the quick reply!
I’ll se where I get to
Oh yeah, I forgot. To make things more complicated (lol) I put multiple custom media card inside a swiper card and each custom media card is inside a conditional card. So I could swipe between currently active speakers and only see those that are playing/paused.
Yeah, I realized that from the forum posts. I’ll skip that, what I’m looking for is anice popup to handle selcetion of source, playlist and maybe the group management.
Have you seen my question in your Fully loaded tread? Fully loaded media player card (picture-elements project)
I don’t use group managing options, so I can’t help with that sorry. You could try with card mod to get the styling fixed, like how I edited the below bar of mini media player with card mod. You could maybe also create button cards and use those control the group. Each button could represent an input_boolean, which you can tie to a speaker through automations. But you will need to go a little deeper with automations.
Makes sense! Thanks
Works great thanks,
just one question, I would like to display the artwork cover is that possible with this option?
Kr,
André
you need to create a camera that points to a jpg file.
I retrieve artwork, artist and track via a separate python script (scrape using BS4 and send to HA via MQTT)
Then I use a template sensor to figure out which station I’m playing and a picture-glance lovelace card to display the template sensors (artist, track, artwork camera):
Lovelace config extract for that:
  - type: custom:stack-in-card
    mode: vertical
    cards:
    - type: picture-glance
      camera_image: camera.chromecast_radio_pic
      entities:
        - entity: input_select.chromecast_radio_station
        - entity: input_text.custom_station
        - entity: input_select.chromecast_radio_speakers
        - entity: switch.chromecast_radio_vol_down
        - entity: switch.chromecast_radio_mute
        - entity: switch.chromecast_radio_vol_up
        - entity: switch.chromecast_radio_stop
        - entity: switch.chromecast_radio_play
    - type: conditional
      conditions:
        - entity: binary_sensor.radio_is_streaming
          state: "on"
      card:
        type: entities
        show_header_toggle: false
        entities:
          - entity: sensor.stream_artist
            secondary_info: last-changed
            icon: mdi:account-music
          - entity: sensor.stream_track
            icon: mdi:music-circle
Great howto, I will try it tonight.
Can you please share this script? I’m not familiar with BS4, can you explain?
BS4 is Beautiful Soup. It’s the engine that’s used by the Scrape Sensor
But the scrape sensor only refreshes once every min and I find it a bit more complicated than using BS4 directly. In addition I want a single call per radio, as opposed to 1 call per attribute, which might end up black listing me as spam/DDOS
Here is the python script I’ve written to extract artist, track and album art from the various radios I listen to:
Show Code
#!/usr/bin/python
# -*- coding: utf-8 -*-
from bs4 import BeautifulSoup
from urllib.request import urlopen, Request
import paho.mqtt.client as mqtt
import time
from threading import Thread
from datetime import datetime
import json
import secrets
MQTT_Host = secrets.MQTT_Host
MQTT_Port = secrets.MQTT_Port
MQTT_User = secrets.MQTT_User
MQTT_Password = secrets.MQTT_Password
client = mqtt.Client("HA_Scraper") # must be unique on MQTT network
client.username_pw_set(str(MQTT_User),str(MQTT_Password))
client.connect(MQTT_Host, port=MQTT_Port, keepalive=60)
client.loop_start()
headers = {'User-Agent': 'Mozilla/5.0'}
class Radio:
	# Initializer / Instance Attributes
	def __init__(self, name, url, pic, pic_sel, pic_att, artist, artist_sel, artist_att, track, track_sel, track_att):
		self.name = name
		self.url = url
		self.pic = pic
		self.pic_sel = pic_sel
		self.pic_att = pic_att
		self.artist = artist
		self.artist_sel = artist_sel
		self.artist_att = artist_att
		self.track = track
		self.track_sel = track_sel
		self.track_att = track_att
class Podcast:
	def __init__(self, name, url, track, track_sel, track_att, mp3_url, mp3_sel, mp3_att):
		self.name = name
		self.url = url
		self.track = track
		self.mp3_url = mp3_url
		self.mp3_sel = mp3_sel
		self.mp3_att = mp3_att
RTL2 = Radio("RTL2", "https://www.6play.fr/rtl2/quel-est-ce-titre", "", ".ecfper-2", "src", "", ".ecfper-6", "", "", ".ecfper-5", "") #https://timeline.rtl.fr/RTL2/songs
Absolute_Radio_CR = Radio("Absolute_Radio_CR", "https://planetradio.co.uk/absolute-radio-60s/player/", "", ".station-cards.cf > div:nth-child(3) > a .main-img", "style", "", ".station-cards.cf > div:nth-child(3) > a > .text-wrapper > div > .artist", "", "", ".station-cards.cf > div:nth-child(3) > a > .text-wrapper > div > .track", "")
Absolute_Radio_CR2 = Radio("Absolute_Radio_CR2", # Name
                "https://planetradio.co.uk/absolute-classic-rock/player/", # URL
                "", #Leave Blank
                ".now-playing-wrapper > .now-playing.cf > .now-playing-block.cf.right.extended-info > .image", # Picture Select
                "style", # Picture Select Attribute
                "", #Leave Blank
                ".now-playing-wrapper > .now-playing.cf > .now-playing-block.cf.right.extended-info > .info-wrapper.fr > div > .title.extended-info", # Artist Select
                "", # Artist Select Attribute
                "", #Leave Blank
                ".now-playing-wrapper > .now-playing.cf > .now-playing-block.cf.right.extended-info > .info-wrapper.fr > div > .track.extended-info", # Track Select
                "" # Track Select Attribute
Absolute_Radio = Radio("Absolute_Radio", "https://planetradio.co.uk/absolute-radio-60s/player/", "", ".station-cards.cf > div:nth-child(1) > a .main-img", "style", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .artist", "", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .track", "")
Absolute_Radio2 = Radio("Absolute_Radio2", # Name
                "https://planetradio.co.uk/absolute-radio/player/", # URL
                "", #Leave Blank
                "", #Leave Blank
                "", #Leave Blank
IoT_Podcast = Podcast("IoT Podcast", "https://iotpodcast.com/feed/", "", "item:nth-of-type(1) title", "", "","enclosure:nth-of-type(1)", "url")
Hass_Podcast = Podcast("Hass Podcast", "https://hasspodcast.io/feed/podcast", "", "item:nth-of-type(1) title", "", "","enclosure:nth-of-type(1)", "url")
Chill = Radio("Chill", "https://www.smoothradio.com/chill/radio/playlist/", "", ".js-lazy", "data-src", "", ".now-playing__text-content__details__artist", "", "", ".now-playing__text-content__details__track", "")
Scala = Radio("Scala", "https://planetradio.co.uk/jazz-fm/player/", "", ".station-cards.cf > div:nth-child(1) > a .main-img", "style", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .artist", "", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .track", "")
Scala2 = Radio("Scala2", # Name
                "https://planetradio.co.uk/scala-radio/player/", # URL
                "", #Leave Blank
                "", #Leave Blank
                "", #Leave Blank
def bs_get_value_radio(radio):
	req = Request(radio.url, headers=headers)
	content = urlopen(req).read()
	try:
		raw_data = BeautifulSoup(content,"html.parser")
	except Exception as e:
		print("%s Unable to get BS from URL" % e)
	try:
		if(radio.pic != raw_data.select(radio.pic_sel)[0][radio.pic_att]):
			radio.pic = raw_data.select(radio.pic_sel)[0][radio.pic_att].replace("background-image:url(", "").replace(")", "")
			client.publish("RadioStream/"+radio.name+"/pic_url",radio.pic.encode('ascii'), qos=0, retain=True)
		print ("Can't get "+radio.name+" Image")
	try:
		if (radio.artist_att):
			if(radio.artist != raw_data.select(radio.artist_sel)[0][radio.artist_att]):
				radio.artist = raw_data.select(radio.artist_sel)[0][radio.artist_att]
				client.publish("RadioStream/"+radio.name+"/artist",radio.artist, qos=0, retain=True)
		else:
			if(radio.artist != raw_data.select(radio.artist_sel)[0].text.title()):
				radio.artist = raw_data.select(radio.artist_sel)[0].text.title().strip()
		print ("Can't get "+radio.name+" Artist")
	try:
		if (radio.track_att):
			if(radio.track != raw_data.select(radio.track_sel)[0][radio.track_att]):
				radio.track = raw_data.select(radio.track_sel)[0][radio.track_att]
				client.publish("RadioStream/"+radio.name+"/track",radio.track, qos=0, retain=True)
		else:
			if(radio.track != raw_data.select(radio.track_sel)[0].text.title()):
				radio.track = raw_data.select(radio.track_sel)[0].text.title().strip()
		print ("Can't get "+radio.name+" Track")
def bs_get_value_podcast(podcast):
	req = Request(podcast.url, headers=headers)
	try:
	try:
		if (podcast.mp3_att):
			if(podcast.mp3_url != raw_data.select(podcast.mp3_sel)[0][podcast.mp3_att]):
				podcast.mp3_url = raw_data.select(podcast.mp3_sel)[0][podcast.mp3_att]
				client.publish("RadioStream/"+podcast.name+"/mp3_url",podcast.mp3_url, qos=0, retain=True)
		else:
			if(podcast.mp3_url != raw_data.select(podcast.mp3_sel)[0].text.title()):
				podcast.mp3_url = raw_data.select(podcast.mp3_sel)[0].text.title().strip()
		print ("Can't get "+podcast.name+" MP3 URL")
	try:
		if (podcast.track_att):
			if(podcast.track != raw_data.select(podcast.track_sel)[0][podcast.track_att]):
				podcast.track = raw_data.select(podcast.track_sel)[0][podcast.track_att]
				client.publish("RadioStream/"+podcast.name+"/track",podcast.track, qos=0, retain=True)
		else:
			if(podcast.track != raw_data.select(podcast.track_sel)[0].text.title()):
				podcast.track = raw_data.select(podcast.track_sel)[0].text.title().strip()
		print ("Can't get "+podcast.name+" Track")
def planetradio(name, url):
    url = url + str(datetime.now().strftime('%Y-%m-%d')) + "/" + str(datetime.now().strftime('%H:%M')) +"/1"
    req = Request(url, headers=headers)
    content = str(urlopen(req).read()).replace("b'","").replace("'","")
    json_content = json.loads(content)
    client.publish("RadioStream/"+name+"/pic_url",json_content[0]["nowPlayingImage"], qos=0, retain=True)
    client.publish("RadioStream/"+name+"/artist",json_content[0]["nowPlayingArtist"], qos=0, retain=True)
    client.publish("RadioStream/"+name+"/track",json_content[0]["nowPlayingTrack"], qos=0, retain=True)
def streamguys(url):
    # url = "https://jeta.streamguys.com:8444/8944a2fe68caa986fdee0f2a3c03675d624bab9a/scraper/9cebb028-9f73-4062-830b-478535e516a1/metadata"
    metadata = json_content["StreamTitle"].split(" - ")
    try:
        client.publish("RadioStream/Radio_Fiji_Two/artist",metadata[-1], qos=0, retain=True)
    except:
        client.publish("RadioStream/Radio_Fiji_Two/artist","N/A", qos=0, retain=True)
        pass
    try:
        client.publish("RadioStream/Radio_Fiji_Two/track",metadata[-2], qos=0, retain=True)
    except:
        client.publish("RadioStream/Radio_Fiji_Two/track","N/A", qos=0, retain=True)
        pass
Refresh_Timer = 0
while(True):
	Thread(target=bs_get_value_radio, args=[RTL2]).start()
	Thread(target=planetradio, args=["Absolute_Radio_CR","https://listenapi.bauerradio.com/api9/eventsdadi/absolute-classic-rock/"]).start()
	Thread(target=planetradio, args=["Absolute_Radio","https://listenapi.bauerradio.com/api9/eventsdadi/absolute-radio/"]).start()
	Thread(target=planetradio, args=["Scala","https://listenapi.bauerradio.com/api9/eventsdadi/scala-radio/"]).start()
	Thread(target=streamguys, args=["https://jeta.streamguys.com:8444/8944a2fe68caa986fdee0f2a3c03675d624bab9a/scraper/9cebb028-9f73-4062-830b-478535e516a1/metadata"]).start()
	Thread(target=bs_get_value_podcast, args=[IoT_Podcast]).start()
	if(Refresh_Timer == 240):
		Thread(target=bs_get_value_podcast, args=[Hass_Podcast]).start()
		Refresh_Timer = 0
	Thread(target=bs_get_value_radio, args=[Chill]).start()
	time.sleep(15)
	Refresh_Timer = Refresh_Timer + 1
it probably needs a bit of cleaning… I originally scraped content of the html player page, but that would fail every now and again. I then found out that some radios offered a json page with the details I needed (e.g. planet radio stations) so I adjusted.
I then call the script at HA startup and it keeps running…
Hope it makes sense / is helpful to others
Hi @ASNNetworks
So I’m getting there now.
But I’m going crazy over the gap between the buttons in the top. I tried with padding 0px, margins: 0px, etc…
Here’s my config: https://pastebin.com/6f0D1Erk
Are you able to see my mistake?
Thanks in advance!
Use stack-in-card instead of vertical-stack. That allows you create vertical and horizontal stacks where the button cards have no gaps and look like one single card. This is what I use for most of my UI to give it a more clean look.
For example:
These are all stack within stacks, but they appear as single cards.
Make sure you use 0.1.1, 0.2.0 has a bug with nested cards.
Nice!
I’ll give a go
Thanks man! :slight_smile: :ok_hand:t3:
Guys,
Streaming to Sonos will not work by me. Streaming to googlehome mini or Chromecast is no problem. What should be the problem?
Hello dear people…i have been reading the original post and scrolling till 2021. I am quite confuse to which is the working iteration now on the current HA version.
I got a google home mini and interested in streaming tunein or other radio to the mini. I don’t have a Spotify account. If anyone can point me to the right direction please?
If you haven’t already, setup the package folder / file
Place this in the yaml file:
input_select:
  radio_station:
    name: 'Select Radio Station:'
    options:
      - Hit 92-9
      - Nova 93-7
      - Mix 94-5
      - 96FM
      - 80's 1
      - 80's 2
      - OldSkool Hits
      - Old Skool Anthems
      - Raw FM (dance)
      - 181FM Power (Todays Hits)
      - 181FM 90's Dance
      - 181FM Star 90's
      - 181FM The Breeze
      - Heat Radio (RnB)
      - Fresh 92-7
      - DI Chill & Tropical House
      - DI Disco House
      - DI Funky House
      - DI Liquid D&B
      - Aloha Joe's Relaxation Island
      - Spectrum Fit
      - Energy FM Australia
      - Jazz Relax
      - Australian Country
      - Rebel FM
    initial: Raw FM (dance)
    icon: mdi:radio
  chromecast_radio:
    name: 'Select Speakers:'
    options:
      - Lounge
      - Bedroom
      - Office
      - Lounge and Office
      - House
      - House except office
      - Everywhere
      - Everywhere except office
      - Back yard
    initial: House
    icon: mdi:speaker-wireless
input_number:
  volume_radio:
    icon: mdi:volume-high
    min: 0
    max: 1
    step: 0.05
automation:
  - alias: 'Listen Radio'
      - platform: state
        entity_id: input_select.radio_station
      - service: script.radio
  - alias: 'Set Chromecast Radio Volume'
      platform: state
      entity_id: input_number.volume_radio
      service: media_player.volume_set
      data_template:
        entity_id: >
          {% if is_state("input_select.chromecast_radio", "Lounge") %} media_player.lounge_speakers
          {% elif is_state("input_select.chromecast_radio", "Bedroom") %} media_player.bedroom
          {% elif is_state("input_select.chromecast_radio", "Office") %} media_player.chromecastaudio3249
          {% elif is_state("input_select.chromecast_radio", "Lounge and Office") %} media_player.lounge_and_office
          {% elif is_state("input_select.chromecast_radio", "House") %} media_player.house
          {% elif is_state("input_select.chromecast_radio", "House except office") %} media_player.house_except_office
          {% elif is_state("input_select.chromecast_radio", "Everywhere") %} media_player.everywhere
          {% elif is_state("input_select.chromecast_radio", "Everywhere except office") %} media_player.all_except_office
          {% elif is_state("input_select.chromecast_radio", "Back yard") %} media_player.back_yard
        volume_level: '{{  states.input_number.volume_radio.state  }}'
script:
  radio:
    alias: Play Radio on Chromecast Audio
    - service: media_player.volume_set
      data_template:
        entity_id: >
      data_template:
        entity_id: >
        media_content_id: >
          {% if is_state("input_select.radio_station", "Hit 92-9") %} http://ic6ti.scahw.com.au/6ppm_128
          {% elif is_state("input_select.radio_station", "Nova 93-7") %} http://streaming.novaentertainment.com.au/nova937
          {% elif is_state("input_select.radio_station", "Mix 94-5") %} http://sc01.scahw.com.au/6mix_32
          {% elif is_state("input_select.radio_station", "96FM") %} https://icy.ihrcast.arn.com.au/au_012_icy
          {% elif is_state("input_select.radio_station", "80's 1") %} http://ic2ti.scahw.com.au/2easy_128
          {% elif is_state("input_select.radio_station", "80's 2") %} http://18243.live.streamtheworld.com/T_RAD_80S_S01_SC?
          {% elif is_state("input_select.radio_station", "OldSkool Hits") %} http://sc01.scahw.com.au/loveland_32
          {% elif is_state("input_select.radio_station", "Old Skool Anthems") %} http://nebula.shoutca.st:8075/stream
          {% elif is_state("input_select.radio_station", "Raw FM (dance)") %} https://frontend.stream.rawfm.net.au/i/syd-stream-192k.mp3
          {% elif is_state("input_select.radio_station", "181FM Power (Todays Hits)") %} http://listen.181fm.com/181-power_128k.mp3?
          {% elif is_state("input_select.radio_station", "181FM 90's Dance") %} http://listen.181fm.com/181-90sdance_128k.mp3
          {% elif is_state("input_select.radio_station", "181FM Star 90's") %} http://listen.181fm.com/181-star90s_128k.mp3
          {% elif is_state("input_select.radio_station", "181FM The Breeze") %} http://listen.181fm.com/181-breeze_128k.mp3
          {% elif is_state("input_select.radio_station", "Heat Radio (RnB)") %} http://174.37.159.206:8106/stream
          {% elif is_state("input_select.radio_station", "Fresh 92-7") %} http://live.fresh927.com.au:80/freshaac
          {% elif is_state("input_select.radio_station", "DI Chill & Tropical House") %} http://pub1.diforfree.org:8000/di_chillntropicalhouse_hi
          {% elif is_state("input_select.radio_station", "DI Disco House") %} http://pub1.diforfree.org:8000/di_discohouse_hi
          {% elif is_state("input_select.radio_station", "DI Funky House") %} http://pub1.diforfree.org:8000/di_funkyhouse_hi
          {% elif is_state("input_select.radio_station", "DI Liquid D&B") %} http://pub1.diforfree.org:8000/di_liquiddnb_hi
          {% elif is_state("input_select.radio_station", "Aloha Joe's Relaxation Island") %} http://s2.voscast.com:7932/
          {% elif is_state("input_select.radio_station", "Spectrum Fit") %} http://51.255.235.165:5292/
          {% elif is_state("input_select.radio_station", "Energy FM Australia") %} http://s3.viastreaming.net:8502/
          {% elif is_state("input_select.radio_station", "Jazz Relax") %} http://199.195.194.94:8036/stream
          {% elif is_state("input_select.radio_station", "Australian Country") %} https://streaming.radio.co/s5ea3fdd1c/listen
          {% elif is_state("input_select.radio_station", "Rebel FM") %} https://au1.fastcast4u.com/proxy/rblgc?mp=/stream
        media_content_type: 'audio/mp4'
Adjust the entity id’s for your media players accordingly, change the radio station URL’s to whatever you want etc.
In Lovelace add a card:
entities:
  - input_select.radio_station
  - input_select.chromecast_radio
  - script.radio
  - input_number.volume_radio
header:
  image: /local/images/internet_radio.jpg
  type: picture
type: entities
Save this file under: www\images\internet_radio.jpg
internet_radio
…and you should end up with this:
thanks a lot. It works :slight_smile:
