Try it with brackets Dave - not sure it will make a difference tho’
{{ (states.media_player.lounge_amp.attributes.volume_level | float) - 0.05 }}
I just tried it but it makes no difference unfortunately
The + = clockwise and the - = anticlockwise in other words the cube generates a +ve number for clockwise and a -ve number for anticlockwise. So as it stands because the check is for > 0 then it’s generating a vol up for clockwise and vice versa. You may find that you need to change it to +/- 0.1 rather than 0.05, depends what the state table says, mine goes from 0 to 100% in steps of 10 but in HA it goes from 0.0 to 1 therefore I step it in 0.1 incements.
What media platform are you using? Take a look at your entity attributes while playing audio to find out the naming and steps for the volume level.
so would there be a way I can extract the >0 / <0 data from the cube to send a volume up / volume down command, rather than an increment to the volume attribute?
Yep the component just sends a broadlink vol up/down packet and does not use an attribute, just do a vol up/down, so maybe…
volume_level: >
{%if trigger.event.data.action_value | float > 0 %}
+1
{% else %}
-1
{% endif %}
or put whatever the command is, I’ve not looked at the component yet well not in any detail anyway
thanks for that. I tried your code but it didnt work so I also tried the below, same deal, not working
alias: Cube - Rotate
initial_state: 'on'
- platform: event
event_type: cube_action
event_data:
entity_id: binary_sensor.cube_158d00010fd152
action_type: rotate
- service: media_player.volume_set
data_template:
entity_id: media_player.lounge_amp
volume_level: >
service: switch.turn_on
entity_id: switch.amp_volume
{% else %}
service: switch.turn_off
{% endif %}
The above wouldn’t work it would be something like…
- service: switch.turn_on
data_template:
entity_id: switch.amp_volume_up
{% else %}
entity_id: switch.amp_volume_down <------------ or whatever you specified in the broadlink switches
{% endif %}
I have my doubts about this as well, I would ask the author how to go about using the volume switches from his media_player.
in the broadlink switch setup there is just switch.amp_volume which gets turned on for volume up and off for volume down… I suppose I could modify it to have two entities with only an ON command
You could just use the already setup switches, you must have defined them to put them in the .ini files to start with.
try a service_template
- service_template: >
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
The broadlink component doesnt have separate volume up and volume down commands though. It works likie switches with vol up being on and vol down being off. here is my .ini file for the amp
#switch:
- platform: broadlink
host: 192.168.0.71
mac: '34:ea:34:xx:xx:xx'
friendly_name: IR Transceiver
type: rm_mini
switches:
onkyo_amp:
friendly_name: "Amp Power"
command_on: 'JgBMAAYABD8AASiSFBEUNRQRFBEUNRQRFDYUNRU1FBEUNhQ1FBEUNhQ1FBEUERQQFDYUERQQFBEUEBQRFDYUNRQRFDYUNRU1FDYUNhQADQUAAAAAAAAAAAAAAAA='
command_off: 'JgBIAAABKJEUERQ2FBAUERQ2FBAUNhQ2FBAUERQ2FDUUERQ2FDYUEBQ2FDYUNRQRFBEUEBQ2FBEUEBQRFBAUNhQ2FDYUEBQ2FAANBQ=='
onkyo_amp_cd:
friendly_name: "Amp CD Input"
command_on: 'JgBQAAABKJIUEBQ2FBEUEBQ2FBETNhQ2FDYUERM2FDYUERM2FDYUERM2FBEUERM2FBEUERMRFBEUEBQ2FDYUERM2FDYUNhQ2EwAE8gABKEkTAA0FAAAAAAAAAAA='
onkyo_amp_v1:
friendly_name: "Amp V1 Input"
command_on: 'JgBIAAABKJEUERM2FBEUERM2FBEUNhM2FDYUERQ1FDYUERQ2EzYUERQ2EzYUNhQ2FBETERQRExEUERQRExEUERQ1FDYUNhQ2EwANBQ=='
onkyo_amp_volume_up:
friendly_name: "Amp Volume"
command_on: 'JgBIAAABKIwaERM2FBEUERM2FBEUNhM2FDYUERM2FDYUERQ1FDYUERQQFDYUERQQFBEUERMRFBEUNhMRFDYUNhM2FDYUNhQ2EwANBQ=='
command_off: 'JgBQAAkADMILAAzsAAEqkRQRFDYUEBQRFDYUEBQ2FDYUNRQRFDYUNhMRFDYUNhQQFDYUNhQQFBEUERQQFBEUEBQRFBEUNRQ2FDYUNhQ1FDYUAA0FAAAAAAAAAAA='
onkyo_amp_mute:
friendly_name: "Amp Mute"
command_on: 'JgBIAAABKJIUEBQ2FBEUEBQ2FBETNhQ2FDYUEBQ2FDYUERM2FDYUERQ1FBEUNhQQFBEUERMRFBEUEBQ2FBEUNRQ2FDYUNhQ1FAANBQ=='
command_off: 'JgBIAAABKJIUEBQ2FBEUEBQ2FBETNhQ2FDYUEBQ2FDYUERM2FDYUERQ1FBEUNhQQFBEUERMRFBEUEBQ2FBEUNRQ2FDYUNhQ1FAANBQ=='
So I’m thinking I should change the volume to be 2 separate entities with only an ON command for each
friendly_name: "Amp Volume Up"
onkyo_amp_volume_down:
friendly_name: "Amp Volume Down"
command_on: 'JgBQAAkADMILAAzsAAEqkRQRFDYUEBQRFDYUEBQ2FDYUNRQRFDYUNhMRFDYUNhQQFDYUNhQQFBEUERQQFBEUEBQRFBEUNRQ2FDYUNhQ1FDYUAA0FAAAAAAAAAAA='
data_template: >
entity_id: switch.onkyo_amp_volume_up
{% else %}
entity_id: switch.onkyo_amp_volume_down
{% endif %}
I think that would work fine
I just tried this and it works!!! thank you so much. you are a legend
thats definitely another option I might try if I decide I want to separate the vol up and down commands. Cheers for the help
I cant seem to get the radio player to work. I have put everything in a package as per below. It shows up in the frontend and seems to fire the command if I hit activate, but nothing happens. no errors in the log. any ideas?
chromecast_radio.yaml (inside packages folder)
group:
radio:
entities:
- input_select.radio_station
- input_select.chromecast_radio
- script.radio
- input_number.volume_radio
input_select:
radio_station:
name: 'Select Radio Station:'
options:
- Hit 92-9
- Nova 93-7
- Mix 94-5
- 96FM
- 80's
- OldSkool Hits
- Raw FM (dance)
- 181FM Power (Todays Hits)
- 181FM 90's Dance
- 181FM Star 90's
- 181FM The Breeze
- Heat Radio (RnB)
- Fresh 92-7
- DI Chill & Tropical House
- DI Disco House
- DI Liquid D&B
initial: Raw FM (dance)
icon: mdi:radio
chromecast_radio:
name: 'Select Speakers:'
options:
- Lounge
- Bedroom
- House
initial: Lounge
icon: mdi:speaker-wireless
input_number:
volume_radio:
icon: mdi:volume-high
min: 0
max: 1
step: 0.05
automation:
- alias: Listen Radio
hide_entity: True
- platform: state
entity_id: input_select.radio_station
- service: script.radio
- alias: Set Chromecast Radio Volume
platform: state
entity_id: input_number.volume_radio
data_template:
entity_id: >
{% if is_state("input_select.chromecast_radio", "Lounge") %} media_player.lounge
{% elif is_state("input_select.chromecast_radio", "Bedroom") %} media_player.bedroom
{% elif is_state("input_select.chromecast_radio", "House") %} media_player.house_group
{% endif %}
volume_level: '{{ states.input_number.volume_radio.state }}'
script:
radio:
alias: Play Radio on Chromecast Audio
sequence:
data_template:
entity_id: >
{% endif %}
- service: media_player.play_media
data_template:
entity_id: >
{% endif %}
media_content_id: >
{% if is_state("input_select.radio_station", "Hit 92-9") %} http://sc01.scahw.com.au/6ppm_32
{% elif is_state("input_select.radio_station", "Nova 93-7") %} http://streaming.novaentertainment.com.au/nova937
{% elif is_state("input_select.radio_station", "Mix 94-5") %} http://sc01.scahw.com.au/6mix_32
{% elif is_state("input_select.radio_station", "96FM") %} https://icy.ihrcast.arn.com.au/au_012_icy
{% elif is_state("input_select.radio_station", "80's") %} http://streaming.the80s.com.au/;stream/1
{% elif is_state("input_select.radio_station", "OldSkool Hits") %} http://sc01.scahw.com.au/loveland_32
{% elif is_state("input_select.radio_station", "Raw FM (dance)") %} http://stream.rawfm.com.au:8000/;stream.nsv
{% elif is_state("input_select.radio_station", "181FM Power (Todays Hits)") %} http://listen.181fm.com/181-power_128k.mp3?
{% elif is_state("input_select.radio_station", "181FM 90's Dance") %} http://listen.181fm.com/181-90sdance_128k.mp3
{% elif is_state("input_select.radio_station", "181FM Star 90's") %} http://listen.181fm.com/181-star90s_128k.mp3
{% elif is_state("input_select.radio_station", "181FM The Breeze") %} http://listen.181fm.com/181-breeze_128k.mp3
{% elif is_state("input_select.radio_station", "Heat Radio (RnB)") %} http://174.37.159.206:8106/stream
{% elif is_state("input_select.radio_station", "Fresh 92-7") %} http://live.fresh927.com.au/freshmp3
{% elif is_state("input_select.radio_station", "DI Chill & Tropical House") %} http://pub1.diforfree.org:8000/di_chillntropicalhouse_hi
{% elif is_state("input_select.radio_station", "DI Disco House") %} http://pub1.diforfree.org:8000/di_discohouse_hi
{% elif is_state("input_select.radio_station", "DI Liquid D&B") %} http://pub1.diforfree.org:8000/di_liquiddnb_hi
{% endif %}
media_content_type: 'audio/mp4'
Did you try all stations?
These stations have a bad link and will not work:
These seem fine:
You can check if you are using the right link by opening it in your browser, it should start playing immediately without having to press a play button.
I’ve tried a lot of them, not all. But I just tried some of the ones that you mentioned have good links, still no joy
What kind of media platform are you using?
