Chromecast Radio with station and player selection
Try state_not: ‘off’ So put off inside apostrophes. I’ve read somewhere that on and off needs to be formatted like that when it as state in YAML. That’s what have always done with all states and variables.
I would also add a second line for unavailable. Because that’s a real state (if device is disconnected). If you only use the off then it WILL show when it’s actually unavailable.
                  - entity: media_player.keuken
                    state_not: ‘off’
                    state_not: ‘unavailable’
This means it will ONLY show when it’s NOT off OR unavailable. Every other state (idle, playing, paused) will show it.
Works thanks again !
Newbie here.
First, thanks for sharing project.
It’s really nice.
I try it on my own, it works fine.
But I would like to add minor changes in my UI lovelace outfit which currently looks something like this:
RadioStations
I am using entity card for UI output:
type: entities
entities:
  - entity: input_select.radio_station
  - entity: input_select.radio_player
  - entity: input_number.radio_volume
  - type: call-service
    icon: 'mdi:play'
    action_name: Play
    service: script.radio_play
    service_data:
      entity_id: script.radio_play
    icon: 'mdi:stop'
    action_name: Stop
    service: script.radio_stop
    service_data:
      entity_id: script.radio_stop
I would like to have buttons for start and stop scripts instead of START/STOP string and I don’t know how to do that.
I looked here, but it’s very big topic with several different approaches and didn’t completely understand everything neither found something that works for my case.
I looked at some other topics as well but still didn’t found changes that works for me.
Appreciate if someone could help.
One way you could neaten it up is to add a ‘footer’ to you entities card and have the play and stop buttons in the footer.
Thank you very much!
Works fine and looks nice.
Hi Will,
thank you for the code. But can I ask a stupid question?
How can I get this on my lovelace dashboard?
I thank you in advance.
yours,
You will have to add a “Entities Card”
Have a look at https://github.com/wills106/homeassistant-config/tree/master/packages/lovelace-example for an example.
Look at the ChromeCastRadio file.
Hi @ASNNetworks
Can you share the card config, not everything behind, but the build-up of the card and the styling?
Unfortunately not. I use LMS for music now, which renders my previous setup redundant. I used that for Google Cast service calls which I no longer use.
But basically what you see there is:
  • Input select playlist
  • Input select speaker
  • Script to start service call for selected playlist over the selected speaker
  • My custom media player based on picture elements and mini media player (see this)
This all inside a vertical stack, which opens through popup with browser mod.
Thanks for the quick reply!
I’ll se where I get to
Oh yeah, I forgot. To make things more complicated (lol) I put multiple custom media card inside a swiper card and each custom media card is inside a conditional card. So I could swipe between currently active speakers and only see those that are playing/paused.
Yeah, I realized that from the forum posts. I’ll skip that, what I’m looking for is anice popup to handle selcetion of source, playlist and maybe the group management.
Have you seen my question in your Fully loaded tread? Fully loaded media player card (picture-elements project)
I don’t use group managing options, so I can’t help with that sorry. You could try with card mod to get the styling fixed, like how I edited the below bar of mini media player with card mod. You could maybe also create button cards and use those control the group. Each button could represent an input_boolean, which you can tie to a speaker through automations. But you will need to go a little deeper with automations.
Makes sense! Thanks
Works great thanks,
just one question, I would like to display the artwork cover is that possible with this option?
Kr,
André
you need to create a camera that points to a jpg file.
I retrieve artwork, artist and track via a separate python script (scrape using BS4 and send to HA via MQTT)
Then I use a template sensor to figure out which station I’m playing and a picture-glance lovelace card to display the template sensors (artist, track, artwork camera):
Lovelace config extract for that:
  - type: custom:stack-in-card
    mode: vertical
    cards:
    - type: picture-glance
      camera_image: camera.chromecast_radio_pic
      entities:
        - entity: input_select.chromecast_radio_station
        - entity: input_text.custom_station
        - entity: input_select.chromecast_radio_speakers
        - entity: switch.chromecast_radio_vol_down
        - entity: switch.chromecast_radio_mute
        - entity: switch.chromecast_radio_vol_up
        - entity: switch.chromecast_radio_stop
        - entity: switch.chromecast_radio_play
    - type: conditional
      conditions:
        - entity: binary_sensor.radio_is_streaming
          state: "on"
      card:
        type: entities
        show_header_toggle: false
        entities:
          - entity: sensor.stream_artist
            secondary_info: last-changed
            icon: mdi:account-music
          - entity: sensor.stream_track
            icon: mdi:music-circle
Great howto, I will try it tonight.
Can you please share this script? I’m not familiar with BS4, can you explain?
BS4 is Beautiful Soup. It’s the engine that’s used by the Scrape Sensor
But the scrape sensor only refreshes once every min and I find it a bit more complicated than using BS4 directly. In addition I want a single call per radio, as opposed to 1 call per attribute, which might end up black listing me as spam/DDOS
Here is the python script I’ve written to extract artist, track and album art from the various radios I listen to:
Show Code
#!/usr/bin/python
# -*- coding: utf-8 -*-
from bs4 import BeautifulSoup
from urllib.request import urlopen, Request
import paho.mqtt.client as mqtt
import time
from threading import Thread
from datetime import datetime
import json
import secrets
MQTT_Host = secrets.MQTT_Host
MQTT_Port = secrets.MQTT_Port
MQTT_User = secrets.MQTT_User
MQTT_Password = secrets.MQTT_Password
client = mqtt.Client("HA_Scraper") # must be unique on MQTT network
client.username_pw_set(str(MQTT_User),str(MQTT_Password))
client.connect(MQTT_Host, port=MQTT_Port, keepalive=60)
client.loop_start()
headers = {'User-Agent': 'Mozilla/5.0'}
class Radio:
	# Initializer / Instance Attributes
	def __init__(self, name, url, pic, pic_sel, pic_att, artist, artist_sel, artist_att, track, track_sel, track_att):
		self.name = name
		self.url = url
		self.pic = pic
		self.pic_sel = pic_sel
		self.pic_att = pic_att
		self.artist = artist
		self.artist_sel = artist_sel
		self.artist_att = artist_att
		self.track = track
		self.track_sel = track_sel
		self.track_att = track_att
class Podcast:
	def __init__(self, name, url, track, track_sel, track_att, mp3_url, mp3_sel, mp3_att):
		self.name = name
		self.url = url
		self.track = track
		self.mp3_url = mp3_url
		self.mp3_sel = mp3_sel
		self.mp3_att = mp3_att
RTL2 = Radio("RTL2", "https://www.6play.fr/rtl2/quel-est-ce-titre", "", ".ecfper-2", "src", "", ".ecfper-6", "", "", ".ecfper-5", "") #https://timeline.rtl.fr/RTL2/songs
Absolute_Radio_CR = Radio("Absolute_Radio_CR", "https://planetradio.co.uk/absolute-radio-60s/player/", "", ".station-cards.cf > div:nth-child(3) > a .main-img", "style", "", ".station-cards.cf > div:nth-child(3) > a > .text-wrapper > div > .artist", "", "", ".station-cards.cf > div:nth-child(3) > a > .text-wrapper > div > .track", "")
Absolute_Radio_CR2 = Radio("Absolute_Radio_CR2", # Name
                "https://planetradio.co.uk/absolute-classic-rock/player/", # URL
                "", #Leave Blank
                ".now-playing-wrapper > .now-playing.cf > .now-playing-block.cf.right.extended-info > .image", # Picture Select
                "style", # Picture Select Attribute
                "", #Leave Blank
                ".now-playing-wrapper > .now-playing.cf > .now-playing-block.cf.right.extended-info > .info-wrapper.fr > div > .title.extended-info", # Artist Select
                "", # Artist Select Attribute
                "", #Leave Blank
                ".now-playing-wrapper > .now-playing.cf > .now-playing-block.cf.right.extended-info > .info-wrapper.fr > div > .track.extended-info", # Track Select
                "" # Track Select Attribute
Absolute_Radio = Radio("Absolute_Radio", "https://planetradio.co.uk/absolute-radio-60s/player/", "", ".station-cards.cf > div:nth-child(1) > a .main-img", "style", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .artist", "", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .track", "")
Absolute_Radio2 = Radio("Absolute_Radio2", # Name
                "https://planetradio.co.uk/absolute-radio/player/", # URL
                "", #Leave Blank
                "", #Leave Blank
                "", #Leave Blank
IoT_Podcast = Podcast("IoT Podcast", "https://iotpodcast.com/feed/", "", "item:nth-of-type(1) title", "", "","enclosure:nth-of-type(1)", "url")
Hass_Podcast = Podcast("Hass Podcast", "https://hasspodcast.io/feed/podcast", "", "item:nth-of-type(1) title", "", "","enclosure:nth-of-type(1)", "url")
Chill = Radio("Chill", "https://www.smoothradio.com/chill/radio/playlist/", "", ".js-lazy", "data-src", "", ".now-playing__text-content__details__artist", "", "", ".now-playing__text-content__details__track", "")
Scala = Radio("Scala", "https://planetradio.co.uk/jazz-fm/player/", "", ".station-cards.cf > div:nth-child(1) > a .main-img", "style", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .artist", "", "", ".station-cards.cf > div:nth-child(1) > a > .text-wrapper > div > .track", "")
Scala2 = Radio("Scala2", # Name
                "https://planetradio.co.uk/scala-radio/player/", # URL
                "", #Leave Blank
                "", #Leave Blank
                "", #Leave Blank
def bs_get_value_radio(radio):
	req = Request(radio.url, headers=headers)
	content = urlopen(req).read()
	try:
		raw_data = BeautifulSoup(content,"html.parser")
	except Exception as e:
		print("%s Unable to get BS from URL" % e)
	try:
		if(radio.pic != raw_data.select(radio.pic_sel)[0][radio.pic_att]):
			radio.pic = raw_data.select(radio.pic_sel)[0][radio.pic_att].replace("background-image:url(", "").replace(")", "")
			client.publish("RadioStream/"+radio.name+"/pic_url",radio.pic.encode('ascii'), qos=0, retain=True)
		print ("Can't get "+radio.name+" Image")
	try:
		if (radio.artist_att):
			if(radio.artist != raw_data.select(radio.artist_sel)[0][radio.artist_att]):
				radio.artist = raw_data.select(radio.artist_sel)[0][radio.artist_att]
				client.publish("RadioStream/"+radio.name+"/artist",radio.artist, qos=0, retain=True)
		else:
			if(radio.artist != raw_data.select(radio.artist_sel)[0].text.title()):
				radio.artist = raw_data.select(radio.artist_sel)[0].text.title().strip()
		print ("Can't get "+radio.name+" Artist")
	try:
		if (radio.track_att):
			if(radio.track != raw_data.select(radio.track_sel)[0][radio.track_att]):
				radio.track = raw_data.select(radio.track_sel)[0][radio.track_att]
				client.publish("RadioStream/"+radio.name+"/track",radio.track, qos=0, retain=True)
		else:
			if(radio.track != raw_data.select(radio.track_sel)[0].text.title()):
				radio.track = raw_data.select(radio.track_sel)[0].text.title().strip()
		print ("Can't get "+radio.name+" Track")
def bs_get_value_podcast(podcast):
	req = Request(podcast.url, headers=headers)
	try:
	try:
		if (podcast.mp3_att):
			if(podcast.mp3_url != raw_data.select(podcast.mp3_sel)[0][podcast.mp3_att]):
				podcast.mp3_url = raw_data.select(podcast.mp3_sel)[0][podcast.mp3_att]
				client.publish("RadioStream/"+podcast.name+"/mp3_url",podcast.mp3_url, qos=0, retain=True)
		else:
			if(podcast.mp3_url != raw_data.select(podcast.mp3_sel)[0].text.title()):
				podcast.mp3_url = raw_data.select(podcast.mp3_sel)[0].text.title().strip()
		print ("Can't get "+podcast.name+" MP3 URL")
	try:
		if (podcast.track_att):
			if(podcast.track != raw_data.select(podcast.track_sel)[0][podcast.track_att]):
				podcast.track = raw_data.select(podcast.track_sel)[0][podcast.track_att]
				client.publish("RadioStream/"+podcast.name+"/track",podcast.track, qos=0, retain=True)
		else:
			if(podcast.track != raw_data.select(podcast.track_sel)[0].text.title()):
				podcast.track = raw_data.select(podcast.track_sel)[0].text.title().strip()
		print ("Can't get "+podcast.name+" Track")
def planetradio(name, url):
    url = url + str(datetime.now().strftime('%Y-%m-%d')) + "/" + str(datetime.now().strftime('%H:%M')) +"/1"
    req = Request(url, headers=headers)
    content = str(urlopen(req).read()).replace("b'","").replace("'","")
    json_content = json.loads(content)
    client.publish("RadioStream/"+name+"/pic_url",json_content[0]["nowPlayingImage"], qos=0, retain=True)
    client.publish("RadioStream/"+name+"/artist",json_content[0]["nowPlayingArtist"], qos=0, retain=True)
    client.publish("RadioStream/"+name+"/track",json_content[0]["nowPlayingTrack"], qos=0, retain=True)
def streamguys(url):
    # url = "https://jeta.streamguys.com:8444/8944a2fe68caa986fdee0f2a3c03675d624bab9a/scraper/9cebb028-9f73-4062-830b-478535e516a1/metadata"
    metadata = json_content["StreamTitle"].split(" - ")
    try:
        client.publish("RadioStream/Radio_Fiji_Two/artist",metadata[-1], qos=0, retain=True)
    except:
        client.publish("RadioStream/Radio_Fiji_Two/artist","N/A", qos=0, retain=True)
        pass
    try:
        client.publish("RadioStream/Radio_Fiji_Two/track",metadata[-2], qos=0, retain=True)
    except:
        client.publish("RadioStream/Radio_Fiji_Two/track","N/A", qos=0, retain=True)
        pass
Refresh_Timer = 0
while(True):
	Thread(target=bs_get_value_radio, args=[RTL2]).start()
	Thread(target=planetradio, args=["Absolute_Radio_CR","https://listenapi.bauerradio.com/api9/eventsdadi/absolute-classic-rock/"]).start()
	Thread(target=planetradio, args=["Absolute_Radio","https://listenapi.bauerradio.com/api9/eventsdadi/absolute-radio/"]).start()
	Thread(target=planetradio, args=["Scala","https://listenapi.bauerradio.com/api9/eventsdadi/scala-radio/"]).start()
	Thread(target=streamguys, args=["https://jeta.streamguys.com:8444/8944a2fe68caa986fdee0f2a3c03675d624bab9a/scraper/9cebb028-9f73-4062-830b-478535e516a1/metadata"]).start()
	Thread(target=bs_get_value_podcast, args=[IoT_Podcast]).start()
	if(Refresh_Timer == 240):
		Thread(target=bs_get_value_podcast, args=[Hass_Podcast]).start()
		Refresh_Timer = 0
	Thread(target=bs_get_value_radio, args=[Chill]).start()
	time.sleep(15)
	Refresh_Timer = Refresh_Timer + 1
it probably needs a bit of cleaning… I originally scraped content of the html player page, but that would fail every now and again. I then found out that some radios offered a json page with the details I needed (e.g. planet radio stations) so I adjusted.
I then call the script at HA startup and it keeps running…
Hope it makes sense / is helpful to others
Hi @ASNNetworks
So I’m getting there now.
But I’m going crazy over the gap between the buttons in the top. I tried with padding 0px, margins: 0px, etc…
Here’s my config: https://pastebin.com/6f0D1Erk
Are you able to see my mistake?
Thanks in advance!
