Sadly fpr me it also doesn’t work because of missing dependencies.
I am using the latest Home Assistant Docker image on a Ubuntu server host.
My log looks like this:
2018-08-21 19:32:15 ERROR (SyncWorker_0) [homeassistant.loader] Error loading custom_components.switch.circadian_lighting. Make sure all dependencies are installed`
File "/usr/src/app/homeassistant/loader.py", line 94, in get_component
module = importlib.import_module(path)
File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/switch/circadian_lighting.py", line 9, in <module>
from custom_components.circadian_lighting import DOMAIN, CIRCADIAN_LIGHTING_UPDATE_TOPIC, DATA_CIRCADIAN_LIGHTING
File "/config/custom_components/circadian_lighting.py", line 50, in <module>
from timezonefinder import TimezoneFinder
ModuleNotFoundError: No module named 'timezonefinder'
2018-08-21 19:32:15 ERROR (SyncWorker_0) [homeassistant.loader] Unable to find component switch.circadian_lighting
2018-08-21 19:32:15 ERROR (SyncWorker_0) [homeassistant.loader] Error loading custom_components.circadian_lighting. Make sure all dependencies are installed
2018-08-21 19:32:15 ERROR (SyncWorker_0) [homeassistant.loader] Unable to find component circadian_lighting
2018-08-21 19:32:15 ERROR (MainThread) [homeassistant.components] Platform not found: switch.circadian_lighting
Component not found: circadian_lighting
