Hi guys,
i a newbie and i need your help for a automation for my circulation pump. the pump must be on for 5 minutes and then off for 30 minutes, the conditions are we are at home and the time 05:45 - 22:45
alias: Zirkulationspumpe
description: Tag-/Nachtumschaltung/Anwesenheit
- platform: time_pattern
minutes: "30"
- condition: time
after: "05:45:00"
before: "22:45:00"
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- condition: state
entity_id: group.anwesenheit
state: home
- service: switch.turn_on
data: {}
entity_id: switch.zirkulationspumpe
thank you and best regards.
finity
June 11, 2023, 11:53am
2
minutes: "/30"
- condition: time
after: "05:45:00"
before: "22:45:00"
- condition: state
state: home
- delay:
minutes: 5
- service: switch.turn_off
be aware that it will not turn off if you restart HA during the 5 minute delay.
there are ways to protect against that if that’s a concern.
thank you
Whtat do you recommend for the restart problem?
thank you i will test it in the nex days.
is that right?
alias: Asymmetric Timer Cycle
description: ""
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.pump
- platform: time
at:
- "05:45:00"
- "22:45:00"
- condition: state
state: home
- variables:
on_time: "00:05:00"
off_time: "00:30:00"
next_interval: >-
{{ iif( is_state('switch.zirkulationspumpe', 'off'), on_time, off_time)
- choose:
- conditions:
- condition: trigger
- service: switch.toggle
data: {}
- service: timer.start
duration: "{{ next_interval }}"
- conditions:
- condition: time
before: "05:46:00"
data: {}
duration: "{{ on_time }}"
default:
data: {}
- service: timer.cancel
data: {}
