From an RFXCom perspective, it turns out it was just a matter of creating the right codes
Classic Energenie support via 433MHz
kylegordon
#21
mebrew
#22
I use my Sonoff RF bridge flashed with Espurna (I guess Tasmota would work also) to control my Energenie devices. I set the device into learn mode and just press the energenie remote to get the activation codes. Once learnt I set up Home Assistant as :switch 8:
- name: Dehumidifier
platform: mqtt
state_topic: Sonoff-RF-Bridge/relay/2
command_topic: Sonoff-RF-Bridge/relay/2/set
payload_on: 1
payload_off: 0
availability_topic: Sonoff-RF-Bridge/status
payload_available: 1
payload_not_available: 0
and it works fine. I taken the Energenie hub out of my system which means I control all aspects from within my local device.
gwhitelaw
#24
I never did manage it. I realised to be useful I’d need to support other Pis too - but moved away from HA with Google Home being more restrictive and hard to support.
Will perhaps pick it up again - in the mean time you could get it working locally if you copy that file into your install.
Sorry to drop the ball!
