Cleverspa Integration?
I am trying to get my Cleverspa connected. I have added the custom add on via HACS but I’m having issues adding the integration to HA.
I get this error:
Config flow could not be loaded: {“message”:“Invalid handler specified”}
The log from Ha gives a bit more detai:
Logger: homeassistant.config_entries
Source: config_entries.py:863
First occurred: 07:00:46 (1 occurrences)
Last logged: 07:00:46
Error occurred loading flow for integration cleverspa: cannot import name ‘gaecontrib’ from ‘requests_toolbelt._compat’ (/usr/local/lib/python3.10/site-packages/requests_toolbelt/_compat.py)
I did find this recent post online:
It looks like maybe it’s a problem elsewhere. I don’t have a clue how to work around it, however.
I am having the same issue, Any support would be greatly appreciated im very new to HA
Same issue here. Would be great if anyone knew how to get round this. @Wh1terat
@DaveUK83 @Tingle @vinniegraves
I have switched to using this as an alternative which works well and it’s shows a thermostat not a water meter :+1:
Worked a treat, thank you!
I notice the original version had a ‘CleverSpa Replace Filter Warning’ entity which sadly this one doesn’t.
So far i’ve tried setting up getting a notification when the filter needs changing, such as if the temperature between 4.30-5.30 is lower then 37 degrees, send a push notification to my mobile - However this seems very hit and miss so far.
Anyone achieved anything similar?
