Climate_IP - ClimateDevice for IP based units (not only Samsung AC)
I’m using reverse proxy on Synology NAS and everything is working well. You can look into this thread:
Yes, indeed. Since v0.89 components are moved to different folders. Including custom components. Compatibility was broken. To make it working with old HASS you probably have to do as follow:
  • download all files from GitHub and place them in folder custom_components/climate/
  • rename file climate.py to climate_ip.py
  • copy everything from file __init __.py to file climate_ip.py (you can paste everything at the beginning of the file)
  • restart HASS - it should work
Let me know if it is working or not
Thanks for sharing the info about reverse proxy. Actually I’m able to make 0.90 work under reverse proxy (like NGINX), but I have to disable basic auth in this condition, otherwise I get some 401 errors (specially on config tab).
I’ve tried to make the changes on the custom component you said, but then it fails in other way:
2019-04-01 11:26:52 ERROR (MainThread) [homeassistant.setup] Error during setup of component climate
File “/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py”, line 146, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
AttributeError: module ‘custom_components.climate’ has no attribute ‘setup’
Anyway, thanks for your support. I will try to find a solution to move to 0.90 and test (keeping basic auth) your component.
After upgrading to 0.90, this custom component works as expected. Pretty cool, thanks @SebuZet
Just for your record, I’m using the Samsung AC Wind free - more details here
Hi @SebuZet. I enabled the line as you requested. I can see full device state data in the response now. Still no attributes seem to be populated. See log below
The spelling error is on line 228 of samsung_2878.py. @propertry which should be @property
INFO (Thread-13) [custom_components.climate_ip.climate] Setting up verify location: /home/homeassistant/.homeassistant/custom_components/climate_ip/ac14k_m.pem
2019-04-01 12:58:18 INFO (Thread-13) [custom_components.climate_ip.climate] Setting up load cert chain: /home/homeassistant/.homeassistant/custom_components/climate_ip/ac14k_m.pem
2019-04-01 12:58:18 INFO (Thread-13) [custom_components.climate_ip.climate] Wrapping socket
2019-04-01 12:58:18 INFO (Thread-13) [custom_components.climate_ip.climate] Socket wrapped: True
2019-04-01 12:58:18 INFO (Thread-13) [custom_components.climate_ip.climate] Connecting with 192.168.1.38:2878
2019-04-01 12:58:19 INFO (Thread-13) [custom_components.climate_ip.climate] Response: DPLUG-1.6
2019-04-01 12:58:19 INFO (Thread-13) [custom_components.climate_ip.climate] Response: <?xml version="1.0" encoding="utf-8" ?><Update Type="InvalidateAccount"/>
2019-04-01 12:58:19 INFO (Thread-13) [custom_components.climate_ip.climate] Sending auth command: <Request Type="AuthToken"><User Token="f11d34c9a-fdd5-1112-8811-1c341111f9dc" /></Request>
2019-04-01 12:58:19 INFO (Thread-13) [custom_components.climate_ip.climate] Auth command sent
2019-04-01 12:58:21 INFO (Thread-13) [custom_components.climate_ip.climate] Response: <?xml version="1.0" encoding="utf-8" ?><Response Type="AuthToken" Status="Okay" StartFrom="1970-01-04/18:12:21"/>
2019-04-01 12:58:21 INFO (Thread-13) [custom_components.climate_ip.climate] Connection authenticated
2019-04-01 12:58:21 INFO (Thread-13) [custom_components.climate_ip.climate] Requesting status with command: <Request Type="DeviceState" DUID="1411E055EA11"></Request>
2019-04-01 12:58:21 INFO (Thread-13) [custom_components.climate_ip.climate] Status request sent
2019-04-01 12:58:33 WARNING (Thread-13) [custom_components.climate_ip.climate] Socket timed out
2019-04-01 12:58:33 INFO (Thread-13) [custom_components.climate_ip.climate] Connection created!
2019-04-01 12:58:33 INFO (Thread-13) [custom_components.climate_ip.climate] Sending command
2019-04-01 12:58:33 INFO (Thread-13) [custom_components.climate_ip.climate] Handling response
2019-04-01 12:58:35 INFO (Thread-13) [custom_components.climate_ip.climate] Response: <?xml version="1.0" encoding="utf-8" ?><Response Type="DeviceState" Status="Okay"><DeviceState><Device DUID="1411E055EA11" GroupID="AC" ModelID="AC" ><Attr ID="AC_FUN_ENABLE" Type="RW" Value="Enable"/><Attr ID="AC_FUN_POWER" Type="RW" Value="On"/><Attr ID="AC_FUN_OPMODE" Type="RW" Value="Heat"/><Attr ID="AC_FUN_TEMPSET" Type="RW" Value="22"/><Attr ID="AC_FUN_COMODE" Type="RW" Value="Off"/><Attr ID="AC_FUN_ERROR" Type="RW" Value="NULL"/><Attr ID="AC_FUN_TEMPNOW" Type="R" Value="22"/><Attr ID="AC_FUN_SLEEP" Type="RW" Value="0"/><Attr ID="AC_FUN_WINDLEVEL" Type="RW" Value="Low"/><Attr ID="AC_FUN_DIRECTION" Type="RW" Value="Fixed"/><Attr ID="AC_ADD_AUTOCLEAN" Type="RW" Value="Off"/><Attr ID="AC_ADD_SETKWH" Type="RW" Value="255"/><Attr ID="AC_ADD_CLEAR_FILTER_ALARM" Type="RW" Value="0"/><Attr ID="AC_ADD_APMODE_END" Type="W" Value="0"/><Attr ID="AC_ADD_STARTWPS" Type="RW" Value="Default"/><Attr ID="AC_ADD_SPI" Type="RW" Value="Off"/><Attr ID="AC_OUTDOOR_TEMP" Type="R" Value="69"/><Attr ID="AC_COOL_CAPABILITY" Type="R" Value="70"/><Attr ID="AC_WARM_CAPABILITY" Type="R" Value="80"/><Attr ID="AC_SG_WIFI" Type="W" Value="Connected"/><Attr ID="AC_SG_INTERNET" Type="W" Value="Disconnected"/><Attr ID="AC_ADD2_USEDWATT" Type="R" Value="65024"/><Attr ID="AC_ADD2_VERSION" Type="RW" Value="65024"/><Attr ID="AC_SG_MACHIGH" Type="W" Value="85"/><Attr ID="AC_SG_MACMID" Type="W" Value="234"/><Attr ID="AC_SG_MACLOW" Type="W" Value="100"/><Attr ID="AC_SG_VENDER01" Type="W" Value="20"/><Attr ID="AC_SG_VENDER02" Type="W" Value="73"/><Attr ID="AC_SG_VENDER03" Type="W" Value="224"/><Attr ID="AC_ADD2_PANEL_VERSION" Type="R" Value="130814"/><Attr ID="AC_ADD2_OUT_VERSION" Type="R" Value="1246985"/><Attr ID="AC_FUN_MODEL" Type="R" Value="6"/><Attr ID="AC_ADD2_OPTIONCODE" Type="R" Value="63162"/><Attr ID="AC_ADD2_USEDPOWER" Type="R" Value="28181"/><Attr ID="AC_ADD2_USEDTIME" Type="R" Value="24380"/><Attr ID="AC_ADD2_CLEAR_POWERTIME" Type="RW" Value="254"/
2019-04-01 12:58:35 ERROR (Thread-13) [custom_components.climate_ip.climate] Sending command failed
File "/home/homeassistant/.homeassistant/custom_components/climate_ip/samsung_2878.py", line 182, in send_socket_command
File "/home/homeassistant/.homeassistant/custom_components/climate_ip/samsung_2878.py", line 167, in handle_socket_response
File "/home/homeassistant/.homeassistant/custom_components/climate_ip/samsung_2878.py", line 154, in handle_response_device_state
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Executing command: None
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Getting socket connection
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Connection invalid, creating!
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Creating ssl context
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Setting up ciphers
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Setting up verify mode
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Setting up verify location: /home/homeassistant/.homeassistant/custom_components/climate_ip/ac14k_m.pem
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Setting up load cert chain: /home/homeassistant/.homeassistant/custom_components/climate_ip/ac14k_m.pem
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Wrapping socket
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Socket wrapped: True
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Connecting with 192.168.1.38:2878
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Response: DPLUG-1.6
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Response: <?xml version="1.0" encoding="utf-8" ?><Update Type="InvalidateAccount"/>
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Sending auth command: <Request Type="AuthToken"><User Token="f11d34c9a-fdd5-1112-8811-1c341111f9dc" /></Request>
2019-04-01 12:58:36 INFO (MainThread) [custom_components.climate_ip.climate] Auth command sent
2019-04-01 12:58:38 INFO (MainThread) [custom_components.climate_ip.climate] Response: <?xml version="1.0" encoding="utf-8" ?><Response Type="AuthToken" Status="Okay" StartFrom="1970-01-04/18:12:39"/>
2019-04-01 12:58:38 INFO (MainThread) [custom_components.climate_ip.climate] Connection authenticated
2019-04-01 12:58:38 INFO (MainThread) [custom_components.climate_ip.climate] Requesting status with command: <Request Type="DeviceState" DUID="1411E055EA11"></Request>
2019-04-01 12:58:38 INFO (MainThread) [custom_components.climate_ip.climate] Status request sent
2019-04-01 12:58:50 WARNING (MainThread) [custom_components.climate_ip.climate] Socket timed out
INFO (MainThread) [custom_components.climate_ip.climate] Connection created!
INFO (MainThread) [custom_components.climate_ip.climate] Command empty, skipping sending
2019-04-01 12:58:52 INFO (MainThread) [custom_components.climate_ip.climate] Executing command: None
2019-04-01 12:58:52 INFO (MainThread) [custom_components.climate_ip.climate] Getting socket connection
2019-04-01 12:58:52 INFO (MainThread) [custom_components.climate_ip.climate] Command empty, skipping sending
2019-04-01 12:58:54 INFO (MainThread) [custom_components.climate_ip.climate] Executing command: None
2019-04-01 12:58:54 INFO (MainThread) [custom_components.climate_ip.climate] Getting socket connection
2019-04-01 12:58:54 INFO (MainThread) [custom_components.climate_ip.climate] Command empty, skipping sending
2019-04-01 12:58:57 INFO (MainThread) [custom_components.climate_ip.climate] Executing command: None
2019-04-01 12:58:57 INFO (MainThread) [custom_components.climate_ip.climate] Getting socket connection
2019-04-01 12:58:57 INFO (MainThread) [custom_components.climate_ip.climate] Command empty, skipping sending
@Jman Thanks for checking, I need to find a way to check this out at home.
I’ve do telnet on my air conditionner and is old version, port 2878.
But what the way more easy for get token?
Thank you for help.
@ricain I’m sorry but I cannot help you. I don’t own such device. Maybe @jackdalma, @Modrica or @Jman can help you :wink:
@ricain Hi, I used this acdc to get the token.
@jackdalma Thank you very much
@SebuZet You are my hero :slight_smile: works fine my two AC, Thank you.
Additional feedback: I can turn on/off my air conditioning with google assistant (hass cloud). but it does not have voice feedback. I mean, when I say “turn on the ar conditioning” it turns on, but the voice feedback is “sorry, there was no response from ar conditioning”
I’m assuming you got ya token for port 2878. Could you please explain how you got this as I’m struggling to get my token.
edit : All good …Finally got the token.
So far works great. one slight issue …is showing currnet temp is 79 C. But on the controller is showing 22 C.
It looks like your device is reporting current temperature in Fahrenheit instead of Celsius.
Try to edit file samsung_2878.yaml in section temperature
Add new line after line #87 (should looks like this: status_template: ‘{% for a in device_state.Response.children.0.DeviceState.Device.children %}{% if a.Attr.attributes.ID == “AC_FUN_TEMPSET” %}{{a.Attr.attributes.Value}}{% endif %}{% endfor %}’)
with content:
unit_template : “F”
Just make sure that number of spaces (not tabs) at the beginning of the line is same as in lines before and after new one. Additionally make sure that letter F is between characters " - sometime editors are changing this character.
Component will convert temp from Fahrenheit to Celsius.
Is this how you meant…
still shows as fahrenheit after i restart H.A
My mistake. If current_temperature is shown in Fahrenheit thena move this line into current_temperature secion :wink:
EDIT: Four lines down :slight_smile:
Ok now I have it like this
still showing fahrenheit. I,ve also noticed that H.A not updating status of aircon. Gives correct status on restart but any state changes after ,status not change.
Can you add line
debug: True
In configuration.yaml and restart HA
Then in dev-state panel, your AC device will have attribute called device_state
Can you show what is in it?
If ya need more let me know.
Look good. thanks. Can you try to modify type property from number to temperature in current_temperature section?
And don’t forget to disable debug mode.
Ok it is now in celsius , but it is not matching the controller unit. H.A says 27.8 C and controller unit shows 23 C.
Your device is reporting current temp in AC_FUN_TEMPNOW attribute. in your debugs it was 83 (in F) so it is about 28 in C. Maybe your device is displaying desired temperature (this is how my AC unit works). maybe it can be changed somehow. I don’t know :wink:
