Climate_IP - ClimateDevice for IP based units (not only Samsung AC)
Hi @SebuZet
Thanks for this great plugin, with the help of another member ive got it working, but some unexpected behaviour
  1. i could not get it to work with the validate ssl being true, setting to false it works now
  2. If i turn the AC on via HAS, i can see it comes on and is working, then within minutes, say 5 or so turns off, its like HAS then tells it to turn off
If i turn it on using my samsung panel, or the genuine samsung app it stays on, so i know the AC and connectivity is ok
Any reason why this might occur
Im using old 2878 generation on ducted air
Sorry for my late feedback
You were rigth, I changed location of antena and WiFi channel and the error disappeared.
I have another problem, when I install climate_ip with HACS it seems there is a background process that implements a loop with a responsiveness delay, I mean, if I switch on and switch off a light through HA I can do it in a very responsive way during 8-10 seconds and after that time it does not repond during 5 seconds. Any similar behaviour? How to fix/debug it?
I have 3 units with similar config:
platform: climate_ip
config_file: 'samsung_2878.yaml'
ip_address: '192.168.1.29'
token: 'XXXXX'
cert: ''
#cert: 'ac14k_m.pem' #set as '' to skip certificate verification
mac: 'XXXXX'
debug: false
poll: disable_ip
I’m stuck ! help !
This is my configuration.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
#tts:
- platform: google_translate
climate:
  • platform: ‘climate_ip’
    config_file: ‘samsung_2878.yaml’
    ip_address: ‘192.168.25.91’
    token: ‘b7ded355-6d3a-4c4c-9ea6-38ca11e17’
    cert: ‘ac14k_m.pem’ #set as ‘’ to skip certificate verification
    mac: ‘BC:8C:CD:D7:A5:63’
    ip_address: ‘192.168.25.93’
    token: ‘fcf4096f-9b1d-401b-a587-7153aa89d’
    mac: ‘BC:8C:CD:D7:DA:95’
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
I’m keep getting the:
2019-12-16 01:10:43 ERROR (SyncWorker_9) [homeassistant.util.yaml.loader] while parsing a block mapping
in “/config/configuration.yaml”, line 3, column 1
expected , but found ‘-’
in “/config/configuration.yaml”, line 18, column 1
2019-12-16 01:10:43 ERROR (MainThread) [homeassistant.components.homeassistant] Error loading /config/configuration.yaml: while parsing a block mapping
2019-12-16 01:12:49 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while parsing a block mapping
in “/config/configuration.yaml”, line 12, column 1
2019-12-16 01:12:49 ERROR (MainThread) [homeassistant.components.homeassistant] Error loading /config/configuration.yaml: while parsing a block mapping
Don’t know what to do ! anyone know ?
Apparently I could put it to work at least I can see it working in the overview now:
default_config:
climate:
    token: ‘b7ded355-6d3a-4c4c-9ea6-38’
    token: ‘fcf4096f-9b1d-401b-a587-7153a’
I also had to work with the CPURAM post regarding:
near line 25, remove “ATTR_HVAC_ACTIONS” and its preceding comma
near line 251, commnet/delete the below 3 lines
@property
def hvac_action(self):
return self.rac.get_property(ATTR_HVAC_ACTIONS)
re-start HA
Looks better now.
Rui
Thanks for your work on this @SebuZet. I recently got my Samsung Aircon set up in Home Assistant, and wrote about it here: https://newadventuresinwi-fi.blogspot.com/2019/11/controlling-samsung-air-conditioner-from-home-assistant.html
@oscill8ory Good to hear that.
Guys, I’m really sorry but at this moment I have no free time for this component. There is a lot of private stuff in my live to organize.
Additionally I’m not using HA anymore. Support for Z-Wave is very poor so I decided to stop using it. I’m not sure if I will come back to HA later or move to something else.
@wifi75 You need to call service climate_ip_set_property on you entity with dedicated params, eg:
  "entity_id" : "climate.salon_ac",
  "power" : "on",
  "purify" : "on",
  "special_mode" : "comfort"
You can find more info on github or in this thread.
@tode Did you try to something similar to this:
switch:
    switches:
      purify:
        value_template: "{{ is_state_attr('climate.salon_ac', 'purify', 'on') }}"
        turn_on:
          service: climate.climate_ip_set_property
            entity_id: climate.salon_ac
            purify: 'on'
        turn_off:
            purify: 'off'
You need to adopt entity name to yours config
@SebuZet, thanks again, and understand you have moved on from this. Are you open to receiving pull requests to fix issues that crop up with the climate_ip component over time? Or would you prefer someone to just fork your repository?
I was trying to use sebuzet’s custom integration for Samsung AC, and had a hard time with it: my HA slowed to a crawl, with updates taking 5-10 seconds.
Would take me too long to learn enough HA infrastructure to debug it, and with it unsupported at the moment, I wrote my own, this time it’s a small Go bridge that runs in a separate process and connects to HA through MQTT. Seems to work.
Find it here: https://github.com/gsasha/hvac_ip_mqtt_bridge
There is also a docker image: https://hub.docker.com/r/gsasha/hvac_ip_mqtt_bridge/tags
Let me know what you think,
– Sasha
Thanks!
It works :slight_smile:
Very pleased with this component. I have two Samsung A/C units both the older generation on port 2878. Getting the token was easy once I found out about the Homebridge method.
I was eventually going to purchase another two Sensibo Sky units (I already have one) to control the two Samsungs and a Fujitsu AC. I can now use the existing Sensibo for the Fujitsu, so this component has just saved me about $318 AUD!
Hi Walkie,
is it working fine for you? i got it to work even send/receive commands, but Current temperature displayed on HA is showing on F* (instead of C*), all other temps are fine on C*.
Mine is displaying in C not F. I can change it to F in Home Assistant/Configuration/General Configuration.
Not sure why you’d see F on Climate_IP devices but C everywhere else.
Hi Guys!! Very stupid question maybe! :slight_smile:
How do I get the token of my ac units from smartthings app?
Thanks a lot!!
UPDATE; i have found the curl to perform but now I’m getting:
curl: (7) Failed to connect to 192.168.1.108 port 8888: Connection refused
I’ve tried with nmap and I got:
PORT STATE SERVICE
2878/tcp closed aap
8888/tcp closed sun-answerbook
how can i open port 8888?
Thanks in advance
did climate_ip stopped working with the latest release of home assistant 0.108? i’m having troubles
It’s working fine for me. I just had to restart HA after the update as it wasn’t recognising it.
how do i install it? https://github.com/gsasha/hvac_ip_mqtt_bridge
Hi all,
Im trying to create an automation to turn on the heat for when the current_temperature drops below a value, but I’m not finding a way to read the value for the trigger, or to add it as a condition.
Has anyone done something like this?
TIA!
N.
Hi, after HomeAssistant 109 update, I have this issues on Climate_IP:
Please how can i solve it?
Thanks.
Dettagli registro (WARNING)
Logger: homeassistant.util.async_
Source: util/async_.py:120
First occurred: 11:02:22 (1068 occurrences)
Last logged: 16:16:11
Detected I/O inside the event loop. This is causing stability issues. Please report issue to the custom component author for climate_ip doing I/O at custom_components/climate_ip/connection_request.py, line 89: resp = session.request(**self._params)
Dettagli registro (ERROR)
Logger: custom_components.climate_ip.climate
Source: custom_components/climate_ip/connection_request.py:123
Integration: climate_ip (documentation)
First occurred: 11:05:47 (106 occurrences)
Last logged: 16:15:12
Request execution failed. Stack trace:
