Hello all,
I’m not sure if I’m in the right section, but I couldn’t decide where to go, so here it is…
I upgraded Hasio from 0.88.1 to 0.90.1. Everything works, but for my climate config.
I use this repository from github: https://github.com/royduin/home-assistant-incomfort
In 0.88.1 it worked like a breeze, but since the update it is broken. This is how I set it up:
I created a folder in config/custom_components: InComfort. In that folder I copied climate.py. In configuration.yaml I added:
But when I check my configuration I get the error: Platform not found: climate.incomfort. In the loggin I first see that same error, and later on it says:
Mon Mar 25 2019 21:07:59 GMT+0100 (West-Europa (standaardtijd))
Error loading custom_components.incomfort.climate. Make sure all dependencies are installed
`Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/homeassistant/loader.py", line 166, in _load_file module = importlib.import_module(path) File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "<frozen importlib._bootstrap>", line 1006, in _gcd_import File "<frozen importlib._bootstrap>", line 983, in _find_and_load File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 677, in _load_unlocked File "<frozen importlib._bootstrap_external>", line 728, in exec_module File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed File "/config/custom_components/incomfort/climate.py", line 6, in <module> from homeassistant.components.climate import ( ImportError: cannot import name 'STATE_HEAT' from 'homeassistant.components.climate' (/usr/local/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py)`
I searched Github and the Forum, but no luck…
Can anybody point me in the right direction? Help is much appreciated!
Yes, I saw that one. But as far as my knowledge goes (I admit: that’s not too far - my programming skills are mostly copy and past) the changes do not hav any impact on my configuration.
post a screen shot of your folder tree that contains the custom climate.py file.
I’ve got the same problem.
I have downloaded everything from
installed as posted.
I get this message :
Platform error climate.InComfort - cannot import name ‘STATE_HEAT’ from ‘homeassistant.components.climate.const’ (/usr/src/homeassistant/homeassistant/components/climate/const.py)
Mijn home assistant kent de dir die genoemd is niet. /usr/src/homeassistant/homeassistant/components. HA is geinstalleerd onder Docker waarbij de configuration.yaml in /container/homeassistant/ staat…
als ik verder kijk, dan staat eea wel in /usr/src/homeassistant/homeassistant/components
@rotjong, @mike.blazer78
My setup still works lik a charm. In Configuration.yaml I only have this:
incomfort:
host: 192.168.1.117
Under the config folder (the folder that contains the configuration.yaml) I have a folder called custom_components, in this folder I have the folder InComfort which contains the following files:
Check if you guys have the same files. If not, import them from Github. Should work!
