Hi all,
This is something that I’ve been looking for for ages. I have a Midea heat pump and it has zero connectivity at the moment, I just have the awful control panel. Does anyone know where I could find a diagram demonstrating how to wire this up? I’ve never so much as looked inside the heat pump, but being able to get this level of control would allow me to automate all sorts. I’m hoping it would allow me to tailor my own weather compensation etc.
Hello guys, I recently installed a SWAN2. Could you explain how to connect it? I have seen the product I need to buy, but I am not sure where to connect it. Is there also a WiFi version? Because I would have trouble running the cable all the way to the pump. Could someone kindly give me some guidance? Thanks.
You need that rs485 to ethernet module LINK to converte modbus rs485 to ethernet, then you can make a wifi link from ethernet module over wifi to switch over tcp.
Thanks for your reply. My only doubt is where the electronic board for the Modbus connection is located. I have seen the wiring diagram in the manual, and it doesn’t seem complicated to connect the cable to the connector, but my doubt is where it is located and what I need to disassemble to make the connection.
which makes me assume I can wire the modbus to TCP converter (waveshare as above, but wifi) directly to the three clamps of the indorr unit.
on the other hand I see A and B clamps directly on the outdppr units board, which are not mentioned at any other point - do i need to wire directly to these ports?
Yes you wire them on the internal module. There’s not really anything that can go wrong, wire it up and check if you can get a mod bus connection. You can use some mod bus read tool to read the registers and see if it works.
