Shelly stuff is very good and very affordable, good find on this one!
Nice work Maurice!
I would love to do something similar, but without changing the original buttons. I actually use the extra heater when brewing full pots sometimes.
Any advice on how I could be doing this without using a push-button?
Sorry for the really late reply to your question.
Some of these power switches can interoperate with different kinds of switches.
The Fibaro that I used for example, supports both momentary switches (push-button) and toggle switches (rocker). In the switch configuration you can change the mode of operation, to make a simple on/off switch work.
I didnât make use of this, simply to make the switch more predictable. I push on the left side of the switch to turn on the device. With a rocker switch, you have to toggle the switch to flip the power state, and that might be either pushing it left or right.
On thing to beware of, is when the rocker switch has a light built-in. If I remember correctly, the switch position is hard-linked to the light state. Therefore, it wouldnât be possible to turn on the button light when itâs in the OFF position and you would enable the smart switch remotely. An alternative would be to use a rocker switch without a light in it, and install an extra status light that you power from the smart switch. I would go for a round light, since those are most easy to build in by drilling a round hole in the enclosure.
Hope these hints help!
Regards,
Maurice
I modded my old Moccamaster as well. Thanks for the inspiration!
Instead of a Fibaro, I used a Sonoff Dual R3 to provide the smarts. The Sonoff has an ESP32, so I flashed it with ESPHome. That opened up clever programming possibilities, more of which later.
I replaced the two on/off switches with the very same momentary switches that youâre using. For indicator lights, I used two round neon ones, also per your suggestion. I drilled holes for the lights left and right of the switches.
Like the Fibaro, the Sonoff Dual R3 measures power. Technivorm says we should use the extra heat switch to pre-heat the glass jug while brewing, and keep it on if more than 5 cups are being brewed. I followed their advice to the letter.
When the Moccamaster is turned on and the Sonoff determines from the power consumption (>100W) that the coffee maker is indeed brewing, it automagically applies extra heat. It also measures the time taken to empty the water tank by monitoring the power consumption. If itâs 180 seconds or more, my electronic barista deduces that more than 5 cups were brewed, so the extra heat can stay on. All this can be overridden by pressing the switches. In fact, the extra heat should be turned off manually when 5 cups or less are left in the jug. After all, the Sonoff can measure power consumption, but not coffee consumption.
I also made it so that thereâs an auto power-off after 40 minutes. Thatâs in accordance with EU directive Nr. 801/2013 (EU critics can come up with a more palatable excuse). Helpfully, HASS sends a notification to my phone to remind me not to waste the coffee still left in the pot. Likewise, thereâs a phone reminder when brewing is done.
It was an enjoyable project, but whatâs best, itâs actually useful! It saves squirrels and pretty trees, too!
+1 for the liberal use of Wago 221âs! ![]()
Power sensing, auto-off and reminders sound like great added value.
Thanks. Gotta use all them Wagos, because the wiring got more complicated with two momentary switches and two indicator lights in the picture.
I used velcro tape to stick the Wagos and the Sonoff to the aluminium frame. Itâs not a good idea to let any of them rest on the bottom plate, because any coffee that drips onto the hotplate can leak inside and cause havoc. Technivorm would do well to fix this â if they havenât already.
Nicely done @epollari !
Cool idea to have the high power consumption time determine the number of cups
I only use it for signalling âcoffee is readyâ (which is 30 seconds after the power drops down, by which time the filter dripping is ready).
Auto power-off is something I do too. My home assistant sends me a telegram message to notify me about coffee getting lost when I donât act quickly. Also a nice trigger for knowing that I have been concentrating too much on coding and too little on drinking coffee.
Thanks. Your pioneering work benefited me greatly.
Even if you donât use extra heat, you may want to count the cups to predict how long it takes for the coffee to drip into the pot. Obviously, it varies according to the number of cups. The filter basket on mine lacks the automatic drip-stop and patience isnât my strong point, so Iâm forever cleaning the hotplate. There must be a simple formula for predicting the exact drip time. I guess Iâll have to time it with various loads.
Why arenât you using HA Companion App notifications instead of Telegram?
I implemented the Telegram notification before the companion app was supporting app notifications IIRC. One of these days, I will be re-implementing my whole setup, and then the companion app is definitely going to be my weapon of choice.
There are some nice perks to the HA Companion app. I donât need to be reminded that an auto-off occurred yesterday, so Iâve set the notification to expire and hence, disappear after a while. Also, Iâve included a shortcut to the coffee makerâs virtual on/off switch, so itâs extra easy to give myself extra time to finish the pot.
Nicely done on the mod! Any chance you could share the esphome config so I (and others) could use it as a base? Iâm planning to mod my Moccamaster the same way you did with the sonoff dual r3 ![]()
OK, here goes:
esphome:
friendly_name: Mokkamestari (Sonoff DUALR3)
on_boot:
- light.turn_on: led_power
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging, but disable logging over serial
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "<censored>"
ota:
- platform: esphome
password: "<censored>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Mokkamestari Fallback Hotspot"
captive_portal:
web_server:
globals:
- id: en_timer_var
type: bool
restore_value: no
initial_value: 'false'
- id: sec_timer_var
type: int
restore_value: no
button:
- platform: factory_reset
light:
- platform: status_led
pin:
number: GPIO13
inverted: true
internal: true
# BL0939 power sensor UART settings
uart:
tx_pin: GPIO25
rx_pin: GPIO26
baud_rate: 4800
parity: NONE
stop_bits: 2
- platform: bl0939
update_interval: never
active_power_1:
# internal: true
active_power_2:
# internal: true
accuracy_decimals: 0
accuracy_decimals: 2
name: "no. of cups brewed"
interval:
- interval: 1s
then:
- if:
condition:
- lambda: 'return id(en_timer_var);'
then:
- component.update: sonoff_power
- lambda: 'id(sec_timer_var) += 1;'
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: true
on_click:
min_length: 10s
max_length: 30s
then:
- light.turn_off: led_power
- lambda: 'id(reset_button).press();'
- platform: gpio
pin:
number: GPIO32
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: switch_1
- platform: gpio
pin:
number: GPIO33
mode: INPUT_PULLUP
inverted: true
on_press:
- if:
condition:
- switch.is_on: switch_1
then:
- switch.toggle: switch_2
output:
- platform: gpio
pin: GPIO27
- platform: gpio
pin: GPIO14
switch:
- platform: output
output: relay_1
on_turn_on:
- script.execute: power_timeout_script
- script.execute: hotplate_script
on_turn_off:
- switch.turn_off: switch_2
- script.stop: hotplate_script
- script.stop: power_timeout_script
- lambda: 'id(coffee_ready).publish_state(false);'
- platform: output
output: relay_2
script:
- id: power_timeout_script
mode: restart
then:
- lambda: 'id(power_timeout).publish_state(false);'
- delay: 40min
- lambda: 'id(power_timeout).publish_state(true);'
- switch.turn_off: switch_1
- id: hotplate_script
mode: restart
then:
- lambda: 'id(en_timer_var) = true;'
- delay: 2s
- if:
condition:
- lambda: 'return id(power_1).state > 100;'
then:
- switch.turn_on: switch_2
- lambda: 'id(sec_timer_var) = 0;'
- delay: 2s
- wait_until:
condition:
- lambda: 'return id(power_1).state < 100;'
timeout: 200s
- if:
condition:
- lambda: 'return id(sec_timer_var) < 180;'
then:
# - delay: lambda: 'return (id(sec_timer_var) * 2);'
- lambda: 'id(brew_dur).publish_state(id(sec_timer_var));'
- lambda: 'id(cups_brewed).publish_state(id(sec_timer_var)/35);'
- lambda: 'id(coffee_ready).publish_state(true);'
- lambda: 'id(en_timer_var) = false;'
There are still some deficiencies in the code. I still havenât bothered with a formula to estimate drip time, so once boiling is finished, Home Assistant optimistically announces that coffee is ready, while itâs actually still dripping. Also, I need to devise something to prevent these annoucements when I manually turn power back on after an auto-off (or have forgotten to fill the water tank the previous night).
Pidä hauskaa!
I stood next to my MoccaMaster a few brewing rounds, and for me the max dripping time after finishing boiling was 30 seconds. So thatâs what I have hard-coded as the wait time before announcing âCoffee is ready!â on my telegram ![]()
There wasnât much difference between brewing only a bit and brewing a full pot (I think I saw 15-20 seconds for a non-full pot), so I didnât bother with getting a formula that took the cooking time into account or so. I can live with 15 seconds late announcements.
Are you saying I suffered ten years of studying wiskunde for nothing? I still curse Simon Stevin for translating all mathematical terms into Dutch. Even we Finns, whose language is out of this world, stick with the Greek and Latin terms.
Hey, nobody is stopping you from gaining 5 seconds on the coffee intake initiation time. It is clear that this is a noble and praise-worthy goal!
Sorry for wiskunde, but feel free to name it mathematica.
As a long-time Phorum user (about 2003 to 2014-ish) its a nice surprise to recognise your name here! The site is no longer ran by me and has switched to Xenforo but is still really active.
I just converted our coffee brewer with great inspiration from your github instructions, but used a Shelly relay instead (A PM2 because that was what i had available).
The button cutouts in the metal was not the right size for the switches so I had to modify the plastic surroundings instead to make it fit but otherwise it was straight forward.
If anyone uses a Shelly relay for this, remember to set it to OFF as default after power outage, and Auto Off after a suitable amount of time.
The PM2 relay has one more switch and output, so you could get creativeâŚ
Ha, nice to see a Phorum user âin the wildâ ![]()
The modification is looking good.
Nice classic color machine you got there ![]()
You could use the second Shelly relay for extra heat. It could work without its own manually-operated momentary switch, too, if you just use the heat boost to pre-warm the pot and have it automagically switched off when brewing is done. I rarely if ever press that switch on my machine, because 4 cups is typically the most that I brew.
I assume your Shelly is unhacked, so not re-flashed with ESPHome?
I was thinking a buzzer to notify that the auto off-time is reached! I never use the extra heater, I just disconnected it completely. But it would be easy to make it work as you say even by just using the Shelly functions. Yes. itâs unhacked.
The power meter was an added bonus, I now know that our Mocca Master uses in average 0.25kWh / day. Itâs quite negligible, I thought it would be more!
Iâve got an Aqara Home Hub annouce through its loudspeaker that the coffee machine switched itself off. I find that Google Translate TTS is easier on the ears than a buzzer.
I couldnât be bothered with keeping tabs on power consumption either, but you can tell from the power sensor that boiling is finished, as Maurice discovered. Also, if youâre into stats and have ESPHome estimate the number of cups brewed, like I did, you can monitor your coffee consumption over time. The price of coffee has skyrocketed, so maybe thatâs a better savings opportunity.
