steinis
(stein)
November 16, 2018, 6:41pm
1
I have a touch screen that needs to be calibrated each time Hass is restarted or when the screen goes black(Im turning of the screen at night).
The line of code that I need to send to the terminal on Ubuntu:
/usr/bin/xinput set-prop 13 307 0.000000, -1.000000, 1.000000, 1.000000, 0.000000, 0.000000, 0.000000, 0.000000, 1.000000
The pc I have running the touch screen on is the same as the one running Hass, also the same user(with root) but im still struggling to get this thing to work.
This is what I have now:
-platform: command_line
switches:
home_assistant_system_shutdown:
friendly_name: Sett touch skjerm
command_on: '/usr/bin/xinput set-prop 13 307 0.000000, -1.000000, 1.000000, 1.000000, 0.000000, 0.000000, 0.000000, 0.000000, 1.000000'
silvrr
November 16, 2018, 7:00pm
2
How did you install?
If you used hass.io I think you would need to SSH into your ubuntu host to make this work.
If you are running from the virtual environment install instructions I would enter that environment and switch to your home assistant user and try running the command and see what the result is.
VDRainer
November 16, 2018, 7:06pm
3
I think HA has no access to the X-Server to run xinput.
Example:
If i ssh to a remote ubuntu and run xinput:
rk@TPAD:~$ xinput
Unable to connect to X server
If i set the DISPLAY variable in the ssh session it works
rk@TPAD:~$ export DISPLAY=":0.0"
rk@TPAD:~$ xinput
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Atmel Atmel maXTouch Digitizer id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Sleep Button id=9 [slave keyboard (3)]
↳ TGT TGT DIGITIZER id=10 [slave keyboard (3)]
↳ USB 2.0 Camera : USB 2.0 Camera id=11 [slave keyboard (3)]
↳ USB 2.0 Camera : USB 2.0 Camera id=12 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=14 [slave keyboard (3)]
steinis
(stein)
November 17, 2018, 12:09pm
4
Thanks for replaying.
So I can’t do this from command line in hass? But is there another way, maybe make a .sh file and have hass triggering this?
This is how I manage it from standard HA docker (not Hass.io ). I ssh from the container into the host and send the command.
There’s a way to do it in Hass.io . have a look at this post
SSH keys - Permission denied (publickey,keyboard-interactive)
VDRainer
November 17, 2018, 4:34pm
6
steinis:
Give it a try.
Make a script:
#!/bin/bash
make it executable
chmod +x /path/to/your/script.sh
Change your switch
command_on: '/path/to/your/script.sh'
steinis
(stein)
November 17, 2018, 7:32pm
7
thanks, I will give it a try when I’m back home!
nickrout
(Nick Rout)
November 18, 2018, 5:27am
8
or even simpler
command_on: 'DISPLAY=:0.0 /usr/bin/xinput set-prop 13 307 0.000000, -1.000000, 1.000000, 1.000000, 0.000000, 0.000000, 0.000000, 0.000000, 1.000000'
