Hello. I Update to 0.2.1.
And this is my Error. It should be noted that I have disabled everything from ip_ban
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 10-run: applying...
[fix-attrs.d] 10-run: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Hass.io Add-on: Lovelace Migration v0.2.1
Automatically convert your existing UI to the new Lovelace UI
By: Franck Nijhof <[email protected]>
armhf / Resin OS 2.3.0+rev1 / HA 0.76.1 / SU 127 / stable
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 10-auto-backup.sh: executing...
[cont-init.d] 10-auto-backup.sh: exited 0.
[cont-init.d] 11-cleanup-old.sh: executing...
[cont-init.d] 11-cleanup-old.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
INFO: Output file is set to: /config/ui-lovelace.yaml
File "/root/lovelace_migrate.py", line 844, in <module>
sys.exit(main())
File "/root/lovelace_migrate.py", line 779, in main
states_json = hass.get_states()
File "/root/lovelace_migrate.py", line 711, in get_states
request = self.get('/states', **kwargs)
File "/root/lovelace_migrate.py", line 699, in get
request.raise_for_status()
File "/usr/lib/python3.6/site-packages/requests/models.py", line 939, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 403 Client Error: Forbidden for url: http://hassio/homeassistant/api/states
[cmd] /usr/bin/run.sh exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
