Community Hass.io Add-on: Paradox Alarm Interface
So, do you have an IP150+ module? Because I have the an IP150+ module and I can’t get this thing working. Any help from you would be appreciated!
Could you please help me, because I also have IP150+ and I cannot integrate my alarm system with HA
Yes, I have a IP150, installed PAI on my HomeAssitant and made it talk to the IP150, once I got that confirmed and test via some test messages via MQTT Explorer I configured that interface in Home assistant. We’ve been using it now for 4 days and love it compared to InsiteGold.
Would have loved to have had InsiteGold still useable, just as a backup plan but not…
My next plan is to add a button in home assistant with which I can stop/disable a add on, in the case that something goes wrong with this integration then I can stop the PAI add-on and then revert back to InsiteGold.
G
Could you please show me your settings? I am trying to add this to HA, but unfortunately I can’t
2020-12-27 16:14:04,626 - ERROR - PAI - Unable to connect to alarm
2020-12-27 16:14:04,627 - INFO - PAI - Starting…
2020-12-27 16:14:04,627 - INFO - PAI.paradox.paradox - Disconnecting from the Alarm Panel
2020-12-27 16:14:04,628 - INFO - PAI.paradox.paradox - Clean Session
2020-12-27 16:14:04,628 - INFO - PAI.paradox.paradox - Cleaning previous session. Closing connection
2020-12-27 16:14:04,632 - ERROR - PAI.paradox.connections.protocols - Connection was closed: None
2020-12-27 16:14:04,634 - ERROR - PAI.paradox.connections.connection - Connection was lost
2020-12-27 16:14:04,636 - INFO - PAI.paradox.paradox - Disconnected from the Alarm Panel
2020-12-27 16:14:04,636 - INFO - PAI.paradox.paradox - Connecting to interface
2020-12-27 16:14:04,636 - INFO - PAI.paradox.connections.ip.connection - Connecting. Try 1/3
2020-12-27 16:14:04,639 - INFO - PAI.paradox.connections.connection - Connection established
2020-12-27 16:14:04,640 - INFO - PAI.paradox.connections.ip.commands - Authenticating with IP Module
2020-12-27 16:14:04,646 - INFO - PAI.paradox.connections.ip.commands - Authentication Success. IP(114) Module version 20, firmware: 5.2, serial: 72002f7c
2020-12-27 16:14:04,659 - INFO - PAI.paradox.connections.ip.commands - Session successfully established with IP Module
2020-12-27 16:14:04,659 - INFO - PAI.paradox.paradox - Connecting to Panel
but after this there are a lot of errors, for example
2020-12-27 16:14:26,465 - ERROR - PAI.paradox.paradox - Got ERROR Message: Partition in code lockout (too many bad entries)
2020-12-27 16:16:28,420 - ERROR - PAI.paradox.paradox - Timeout while connecting to panel. Is an other connection active?
2020-12-27 16:16:28,420 - ERROR - PAI - Unable to connect to alarm
2020-12-27 16:16:30,433 - WARNING - PAI.paradox.paradox - Missing element with ID 5 in zone/Zone 05
Only change the values in bold, leave the rest as per below.
LOGGING_FILE: null
LOGGING_LEVEL_CONSOLE: 20
LOGGING_LEVEL_FILE: 40
LOGGING_DUMP_PACKETS: false
LOGGING_DUMP_MESSAGES: false
LOGGING_DUMP_STATUS: false
LOGGING_DUMP_EVENTS: false
CONNECTION_TYPE: IP
SERIAL_PORT: /dev/ttyUSB0
SERIAL_BAUD: 9600
IP_CONNECTION_HOST:
IP_CONNECTION_PORT: 1000
IP_CONNECTION_PASSWORD: paradox
IP_CONNECTION_SITEID: null
IP_CONNECTION_EMAIL: null
IP_CONNECTION_PANEL_SERIAL: None
IP_CONNECTION_BARE: false
LIMITS: {}
SYNC_TIME: true
PASSWORD: ‘0000’
MQTT_ENABLE: true
MQTT_HOST:
MQTT_PORT: 1883
MQTT_USERNAME: pai
MQTT_PASSWORD:
MQTT_RETAIN: true
MQTT_BIND_ADDRESS: null
MQTT_BIND_PORT: null
MQTT_HOMEASSISTANT_AUTODISCOVERY_ENABLE: true
MQTT_BIND_ADDRESS IP_CONNECTION_HOST MQTT_PASSWORD are empty in your configuration.
I forgot to add next to mqtt_host. add your server IP there
hmm interesting, everywhere where I replaced my value with a place holder was removed…
specify you password next to Mqtt_Password.
Let me repost…
LOGGING_FILE: null
CONNECTION_TYPE: IP
SERIAL_BAUD: 9600
IP_CONNECTION_HOST: ADDIPHERE
IP_CONNECTION_PORT: 10000
LIMITS: {}
SYNC_TIME: true
PASSWORD: '0000'
MQTT_ENABLE: true
MQTT_HOST: ADDIPHERE
MQTT_PORT: 1883
MQTT_USERNAME: mqttusername
MQTT_PASSWORD: mqttpassword
MQTT_RETAIN: true
I get a message about wrong pc password :frowning:
I can’t really understand what I am doing wrong
Is password by default ‘0000’?
yes… try it as is…
G
Unfortunately, no success. I don’t know what else can I do
Means PAI has tried too many times with wrong password, panel has blocked further password checks. You need to wait some time to try different password again.
Things to try:
  • Try empty PASSWORD:
If that fails, I have two questions:
  • Was it you who installed the system?
  • Do you have Installer password?
No, it wasn’t me, but yes I have Installer’s password. Password is 0010. I don’t know if the problem is because of the zeros, because I’ve read that if the password contains zeros, it’s possible to have issues with login.
Do you mean to leave empty this option?
Something like this?
PASSWORD: ‘’
yes. Leave it empty.
What panel you have? Try replacing 0010 with aa1a. Some panels have this weird password encoding.
Thank you very much! The code aa1a worked!!!
Does it work with IP150 or IP150s? It is said to work only with IP150s. As far as I know, IP150s are no longer manufactured.
Hi there,
thanks for the support for Paradox alarm for Home Assistant. I installed it yesterday and worked immediately. I have MG5050 and IP150.
Still I do have a problem with the PGMs. I use a device that uses 2 PGMs tor turning lights on/off. The device accepts a pulse from the PGMs and also from wall push buttons sending main voltage pulses (with optocouplers isolation and for command uses optotriacs).
So far I configured two buttons on Paradox’s remote to send those pulses (in Babymonitor you can choose the high level time for the pulse as well as default level). It worked fine for more than 5 years now.
Now with HA the two PGMs appear in main screen and when I click on them they turn on and then off as expected but the lights sometimes turn on w/o turning off or reverse in an non controllable way. To reset from this situation I use the remote control buttons that seem to bring the system to the correct state.
My feeling is that the PGMs go high but they don’t go low so that the pulse is shaped.
I also see that the lights are turning on by themselves sometimes after 1h or so while nobody touches the alarm and the HA. This mean that the PGMs are receiving a command somehow.
So how should I start investigating this? I am new to HA although a developer for other software.
