Compile error with sample file "uart_read_line_sensor.h"
Thanks for your answer.
My environment (on Raspi 4B):
Home Assistant 2022.10.4
Supervisor 2022.10.0
Operating System 9.2
Frontend 20221010.0 - latest
ESPHome AddOn 2022.10.1
My yaml-file:
esphome:
  includes:
    - uart_read_line_sensor.h
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  password: !secret api_password
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_eg_ssid
  password: !secret wifi_eg_password
  manual_ip:
    static_ip: 192.168.2.86
    gateway: 192.168.2.1
    subnet: 255.255.255.0
  fast_connect: true
  ap:
    ssid: "stromzaehler"
    password: !secret hotspot_password
captive_portal:
uart:
  - id: uart_bus1
    rx_pin: GPIO16
    tx_pin: GPIO17
    baud_rate: 9600
    data_bits: 8
    parity: NONE
    stop_bits: 1
  - id: uart_bus2
    rx_pin: GPIO18
    tx_pin: GPIO19
    baud_rate: 300
    data_bits: 7
    parity: EVEN
    stop_bits: 1
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        delimiter: "\n"
        - lambda: UARTDebug::log_string(direction, bytes);
sml:
  uart_id: uart_bus1
  - platform: sml
    name: "Strom Haushalt Zählerstand"
    sml_id: sml1
    server_id: "0a014150410105e05912"
    obis_code: "1-0:1.8.0"
    unit_of_measurement: kWh
    accuracy_decimals: 5
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.0001
  - platform: sml
    name: "Strom Haushalt Leistung"
    sml_id: sml1
    obis_code: "1-0:16.7.0"
    accuracy_decimals: 3
    device_class: power
    state_class: measurement
    filters:
      - multiply: 0.001
button:
    on_press:
      - then:
        - uart.write:
            data: [0x2F, 0x3F, 0x21, 0x0D, 0x0A]
        - delay: 2s
        - uart.write:
            data: [0x06, 0x30, 0x30, 0x30, 0x0D, 0x0A]
My file /config/esphome/uart_read_line_sensor.h:
#include "esphome.h"
class UartReadLineSensor : public Component, public UARTDevice, public TextSensor {
 public:
  UartReadLineSensor(UARTComponent *parent) : UARTDevice(parent) {}
  void setup() override {
    // nothing to do here
  int readline(int readch, char *buffer, int len)
    static int pos = 0;
    int rpos;
    if (readch > 0) {
      switch (readch) {
        case '\n': // Ignore new-lines
          break;
        case '\r': // Return on CR
          rpos = pos;
          pos = 0;  // Reset position index ready for next time
          return rpos;
        default:
          if (pos < len-1) {
            buffer[pos++] = readch;
            buffer[pos] = 0;
    // No end of line has been found, so return -1.
    return -1;
  void loop() override {
    const int max_line_length = 80;
    static char buffer[max_line_length];
    while (available()) {
      if(readline(read(), buffer, max_line_length) > 0) {
        publish_state(buffer);
