Error setting up platform legacy
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 160, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 61, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/local/lib/python3.7/socket.py”, line 752, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name does not resolve
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 677, in urlopen
chunked=chunked,
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 381, in _make_request
self._validate_conn(conn)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 976, in _validate_conn
conn.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 308, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 172, in _new_conn
self, “Failed to establish a new connection: %s” % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7fa2b0f15150>: Failed to establish a new connection: [Errno -2] Name does not resolve
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘mijnmodem.kpn’, port=443): Max retries exceeded with url: /login.htm (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0x7fa2b0f15150>: Failed to establish a new connection: [Errno -2] Name does not resolve’))
File “/usr/src/homeassistant/homeassistant/components/device_tracker/setup.py”, line 64, in async_setup_legacy
self.platform.get_scanner, hass, {DOMAIN: self.config}
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/config/custom_components/experiaboxv10a/device_tracker.py”, line 32, in get_scanner
return ExperiaBoxV10ADeviceScanner(config[DOMAIN])
File “/config/custom_components/experiaboxv10a/device_tracker.py”, line 58, in init
self.success_init = self._update_info()
File “/config/custom_components/experiaboxv10a/device_tracker.py”, line 96, in _update_info
page_initial = session.get(login_url_initial, timeout = 10, verify = self.ca_cert_bundle)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 543, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 530, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 643, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘mijnmodem.kpn’, port=443): Max retries exceeded with url: /login.htm (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0x7fa2b0f15150>: Failed to establish a new connection: [Errno -2] Name does not resolve’))
Verbinding verbroken. Opnieuw verbinden…
