IT WORKED!!!
I updated the hassio software today to the newest, deleted the manual entry to the yaml and rebooted the whole unit then ran the integration wizard again.
Thanks for all your suggestions, I wish I knew what the issue was before
IT WORKED!!!
Getting this error also trying to run a simple install of ZHA “Unable to connect to ZHA device.” via the integration GUI.
Running VE install on Ubuntu, using the ConbeeII
Using the extender cable as suggested. Tried the /dev/tty ACM0 path and “by-id” path with no luck.
Anything obvious that I could be missing?
Hi Grant
Did you ever work this out? I’m having the same problem.
Hi, TBH, not sure what I did in the end - from memory I switched over to ZHA and worked. A lot has happned since then and sorry I cannot be more helpful.
No problem, thanks for responding. I move my extender cable and it started working. It’s a little flakey for my liking TBH.
