To give some context, I am in the middle of troubleshooting the loss of my connexion to my Conbee II stick : it suddenly stopped working and now shows the infamous “Not connected” firmware error
(with flashes of connectivity every 15 seconds or so then dropping again)
I even reflashed it manually on Windows (even though it was already set to the latest 2.17.1 firmware)
Current configuration :
Home Assistant 2022.8.7
Supervisor 2022.08.5
Operating System 8.5
Frontend 20220802.0 - latest
Here is the log from https://blahblahblah.duckdns.org:8123/hassio/addon/core_deconz/logs after restarting the Deconz add-on
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/firmware.sh
[09:26:00] INFO: GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
Path | Vendor | Product | Serial | Type
/dev/ttyACM1 | 0x1CF1 | 0x0030 | DE2254892 | ConBee II
/dev/ttyUSB0 | 0x0403 | 0x6001 | A12IXWP0 | Generic FTDI
/dev/ttyAMA0 | 0x0000 | 0x0000 | | RaspBee
cont-init: info: /etc/cont-init.d/firmware.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
cont-init: info: running /etc/cont-init.d/novnc.sh
cont-init: info: /etc/cont-init.d/novnc.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun deconz (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
services-up: info: copying legacy longrun otau-deconz (no readiness notification)
services-up: info: copying legacy longrun otau-ikea (no readiness notification)
services-up: info: copying legacy longrun otau-ledvance (no readiness notification)
services-up: info: copying legacy longrun websockify (no readiness notification)
s6-rc: info: service legacy-services successfully started
09:26:07:959 COM: use stable device path /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00
09:26:08:022 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00 / serialno: DE2254892, ConBee II
09:26:08:022 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
09:26:08:242 DDF enabled for Gold status
09:26:08:618 parent process s6-supervise
09:26:08:618 gw run mode: docker/hassio
09:26:08:618 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
09:26:08:618 sd-card cid: 035344535236344780ffffffff014400
09:26:08:620 DB sqlite version 3.27.2
09:26:08:621 DB PRAGMA page_count: 55
09:26:08:621 DB PRAGMA page_size: 4096
09:26:08:621 DB PRAGMA freelist_count: 0
09:26:08:621 DB file size 225280 bytes, free pages 0
09:26:08:621 DB PRAGMA user_version: 9
09:26:08:621 DB cleanup
09:26:08:623 DB create temporary views
09:26:08:645 DB skip loading sensor Motion Sensor 22, handled by DDF Aqara motion sensor RTCGQ11LM
09:26:08:646 DB skip loading sensor LightLevel 23 23, handled by DDF Aqara motion sensor RTCGQ11LM
09:26:08:655 [INFO] - Timezone read is 'Etc/UTC'
09:26:08:655 [INFO] - Environment variable TZ found: Europe/Paris...
09:26:08:658 Started websocket server on 0.0.0.0, port: 8081
09:26:08:665 [INFO] - Found file containing button maps. Parsing data...
09:26:08:681 [INFO] - Button maps loaded.
09:26:08:682 found node plugin: libde_rest_plugin.so - REST API Plugin
09:26:08:683 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
09:26:17:085 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
09:26:17:259 LightNode 1: Configuration tool 1 added
09:26:17:282 SensorNode 5 set node 0x00158d000678ecb0
09:26:17:287 SensorNode 16 set node 0x90fd9ffffe92bdf1
09:26:17:293 SensorNode 25 set node 0xb4e3f9fffe67d983
09:26:17:297 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:fe:19:61:45%' COLLATE NOCASE: LIDL Livarno Lux
09:26:17:299 LightNode 6: Study 1 added
09:26:17:312 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:fe:19:61:45%' COLLATE NOCASE: LIDL Livarno Lux
09:26:17:313 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:fe:19:61:45%' COLLATE NOCASE: LIDL Livarno Lux
09:26:17:314 SensorNode 11 set node 0x00158d0001b70861
09:26:17:320 SensorNode 3 set node 0x00158d00067c06e8
09:26:17:323 SensorNode 6 set node 0xccccccfffe6b5f03
09:26:17:327 SensorNode 14 set node 0x00158d000201993c
09:26:17:330 DB SELECT manufacturername FROM nodes WHERE mac LIKE 'bc:33:ac:ff:fe:70:38:e9%' COLLATE NOCASE: _TZ3000_wamqdr3f
09:26:17:337 LightNode 3: Smart plug LIDL added
09:26:17:394 DB SELECT manufacturername FROM nodes WHERE mac LIKE 'bc:33:ac:ff:fe:70:38:e9%' COLLATE NOCASE: _TZ3000_wamqdr3f
09:26:17:396 DB SELECT manufacturername FROM nodes WHERE mac LIKE 'bc:33:ac:ff:fe:70:38:e9%' COLLATE NOCASE: _TZ3000_wamqdr3f
09:26:17:399 SensorNode 12 set node 0x00158d00041cc630
09:26:17:402 SensorNode 17 set node 0xd0cf5efffe412728
09:26:17:407 SensorNode 2 set node 0x00158d000421f207
09:26:17:414 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:fe:1b:9b:f6%' COLLATE NOCASE: LIDL Livarno Lux
09:26:17:415 LightNode 4: Study 2 added
09:26:17:430 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:fe:1b:9b:f6%' COLLATE NOCASE: LIDL Livarno Lux
09:26:17:431 DB SELECT manufacturername FROM nodes WHERE mac LIKE '84:2e:14:ff:fe:1b:9b:f6%' COLLATE NOCASE: LIDL Livarno Lux
09:26:17:432 SensorNode 13 set node 0x00158d00020194b2
09:26:17:437 LightNode 5: Porch light added
09:26:17:439 SensorNode 7 set node 0x00158d00067c191e
09:26:17:442 SensorNode 15 set node 0x00158d0002019564
172.30.32.2 - - [01/Sep/2022:09:26:17 +0200] "GET /api/6519DFD64A/config?_=1662016701365 HTTP/1.1" 404 151 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:26:17:767 DEV no DDF for 0xB4E3F9FFFE67D983, modelId: TRADFRI SHORTCUT Button
09:26:17:767 DEV create on-the-fly DDF for 0xB4E3F9FFFE67D983
09:26:17:769 DEV no DDF for 0x90FD9FFFFE92BDF1, modelId: TRADFRI remote control
09:26:17:769 DEV create on-the-fly DDF for 0x90FD9FFFFE92BDF1
09:26:17:770 DEV found DDF for 0xD0CF5EFFFE412728, path:
09:26:17:771 DEV found DDF for 0xCCCCCCFFFE6B5F03, path:
09:26:17:772 DEV no DDF for 0x00158D0002019564, modelId: lumi.sensor_magnet.aq2
09:26:17:773 DEV create on-the-fly DDF for 0x00158D0002019564
09:26:17:818 DEV Tick.Init: booted after 8000 seconds
09:26:17:840 dlg action: Read binding table
09:26:17:890 DEV no DDF for 0x00158D00067C06E8, modelId: lumi.remote.b1acn01
09:26:17:890 DEV create on-the-fly DDF for 0x00158D00067C06E8
09:26:17:892 DEV no DDF for 0x00158D000421F207, modelId: lumi.remote.b286acn01
09:26:17:892 DEV create on-the-fly DDF for 0x00158D000421F207
09:26:17:893 DEV found DDF for 0x00158D0001B70861, path:
09:26:17:894 DEV found DDF for 0x00158D00020194B2, path:
09:26:17:895 DEV found DDF for 0x00158D00067C191E, path:
09:26:17:895 DEV found DDF for 0x00158D00041CC630, path:
09:26:17:896 DEV found DDF for 0x00158D000678ECB0, path:
09:26:17:896 DEV found DDF for 0x00158D000201993C, path:
09:26:17:969 New websocket 127.0.0.1:47090 (state: 3)
09:26:17:997 DEV no DDF for 0x842E14FFFE196145, modelId: HG06106B
09:26:17:998 DEV create on-the-fly DDF for 0x842E14FFFE196145
09:26:18:006 DEV found DDF for 0x00158D000774D6E0, path: /usr/share/deCONZ/devices/xiaomi/xiaomi_rtcgqq11lm_presence_sensor.json
09:26:18:008 DEV no DDF for 0xBC33ACFFFE7038E9, modelId: TS011F
09:26:18:010 DEV create on-the-fly DDF for 0xBC33ACFFFE7038E9
09:26:18:011 DEV found DDF for 0x842E14FFFE1B9BF6, path:
09:26:18:011 DEV no DDF for 0x90FD9FFFFE769133, modelId: TRADFRI bulb E27 WS opal 980lm
09:26:18:012 DEV create on-the-fly DDF for 0x90FD9FFFFE769133
172.30.32.2 - - [01/Sep/2022:09:26:18 +0200] "GET /api/6519DFD64A/config?_=1662016701366 HTTP/1.1" 200 11549 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:26:18:172 Announced to internet https://phoscon.de/discover
09:26:18:173 discovery server date: Thu, 01 Sep 2022 07:26:18 GMT
09:26:18:173 local time seems to be ok
[09:26:18] INFO: Successfully send discovery information to Home Assistant.
09:26:18:542 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00 / serialno: DE2254892, ConBee II
09:26:20:485 APS request version 1
09:26:20:631 Device firmware version 0x26780700 ConBee II
09:26:20:967 unlocked max nodes: 512
09:26:22:508 Device protocol version: 0x010E
09:26:22:896 New websocket 172.30.32.1:34072 (state: 3)
09:26:23:281 Current channel 15
09:26:23:631 CTRL ANT_CTRL 0x03
09:26:23:641 CTRL ZDP_RESPONSE handler 0x0001
09:26:23:676 Device protocol version: 0x010E
09:26:23:770 CTRL ANT_CTRL 0x03
09:26:23:772 CTRL ZDP_RESPONSE handler 0x0001
172.30.32.2 - - [01/Sep/2022:09:26:28 +0200] "GET /api/6519DFD64A/config?_=1662016701368 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:26:28:306 GW update firmware found: /usr/share/deCONZ/firmware/deCONZ_ConBeeII_0x26720700.bin.GCF
09:26:28:307 GW firmware version is up to date: 0x26780700
172.30.32.2 - - [01/Sep/2022:09:26:33 +0200] "GET /api/6519DFD64A/config?_=1662016701369 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:26:38 +0200] "GET /api/6519DFD64A/config?_=1662016701370 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:26:43 +0200] "GET /api/6519DFD64A/config?_=1662016701371 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:26:48 +0200] "GET /api/6519DFD64A/config?_=1662016701372 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:26:53 +0200] "GET /api/6519DFD64A/config?_=1662016701373 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:26:53:808 ZCL attribute report 0x00158D00041CC630 for cluster: 0x0000, ep: 0x01, frame control: 0x1C, mfcode: 0x115F
09:26:53:809 0x00158D00041CC630 extract Xiaomi special attribute 0xFF01
09:26:53:809 01 battery 3025 (0x0BD1)
09:26:53:809 03 Device temperature 28 °C
09:26:53:810 04 unknown 17320 (0x43A8)
09:26:53:810 05 RSSI dB (?) 28 (0x001C)
09:26:53:810 06 LQI (?) 38654705664 (0x0900000000)
09:26:53:811 0a Parent NWK 26213 (0x6665)
09:26:53:811 64 on/off 0
09:26:56:852 ZCL attribute report 0x842E14FFFE196145 for cluster: 0x0300, ep: 0x01, frame control: 0x18, mfcode: 0x0000
09:26:56:863 Bind response success for 0x842e14fffe196145 ep: 0x01 cluster: 0x0006
09:26:56:916 ZCL configure reporting rsp seq: 8 0x842E14FFFE196145 for ep: 0x01 cluster: 0x0006 attr: 0x0000 status: 0x00
09:26:56:957 Bind response success for 0x842e14fffe196145 ep: 0x01 cluster: 0x0008
09:26:56:958 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x842E14FFFE196145 (wait reading or unsupported)
09:26:57:948 Bind response success for 0x842e14fffe196145 ep: 0x01 cluster: 0x0300
09:26:57:949 skip configure report for cluster: 0x0300 attr: 0x0007 of node 0x842E14FFFE196145 (seems to be active)
09:26:57:950 skip configure report for cluster: 0x0300 attr: 0x0003 of node 0x842E14FFFE196145 (seems to be active)
09:26:57:950 skip configure report for cluster: 0x0300 attr: 0x0004 of node 0x842E14FFFE196145 (seems to be active)
09:26:57:953 skip configure report for cluster: 0x0300 attr: 0x0008 of node 0x842E14FFFE196145 (seems to be active)
172.30.32.2 - - [01/Sep/2022:09:26:58 +0200] "GET /api/6519DFD64A/config?_=1662016701374 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:01:864 Bind response success for 0xbc33acfffe7038e9 ep: 0x0B cluster: 0x0006
09:27:01:910 ZCL configure reporting rsp seq: 12 0xBC33ACFFFE7038E9 for ep: 0x0B cluster: 0x0006 attr: 0x0000 status: 0x00
09:27:07:527 ZCL attribute report 0x842E14FFFE196145 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
172.30.32.2 - - [01/Sep/2022:09:27:08 +0200] "GET /api/6519DFD64A/config?_=1662016701376 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:09:147 Device TTL 560 s flags: 0x7
09:27:09:148 Device reset watchdog 7200 s
172.30.32.2 - - [01/Sep/2022:09:27:13 +0200] "GET /api/6519DFD64A/config?_=1662016701377 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:15:003 Bind response success for 0x842e14fffe196145 ep: 0x01 cluster: 0x0006
09:27:15:004 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x842E14FFFE196145 (seems to be active)
172.30.32.2 - - [01/Sep/2022:09:27:18 +0200] "GET /api/6519DFD64A/config?_=1662016701378 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:19:612 device state timeout (handled)
09:27:19:693 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:27:19:805 start reconnect to network
09:27:19:925 0x842E14FFFE1B9BF6 error APSDE-DATA.confirm: 0xA7 on task
172.30.32.2 - - [01/Sep/2022:09:27:23 +0200] "GET /api/6519DFD64A/config?_=1662016701379 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:25:055 failed to reconnect to network try=1
172.30.32.2 - - [01/Sep/2022:09:27:28 +0200] "GET /api/6519DFD64A/config?_=1662016701380 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:30:304 failed to reconnect to network try=2
172.30.32.2 - - [01/Sep/2022:09:27:33 +0200] "GET /api/6519DFD64A/config?_=1662016701381 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:34:370 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00 / serialno: DE2254892, ConBee II
09:27:35:305 failed to reconnect to network try=3
09:27:35:992 Device firmware version 0x26780700 ConBee II
09:27:35:994 unlocked max nodes: 512
09:27:36:087 Device protocol version: 0x010E
09:27:36:334 CTRL ANT_CTRL 0x03
09:27:36:343 CTRL ZDP_RESPONSE handler 0x0001
09:27:36:385 Device protocol version: 0x010E
172.30.32.2 - - [01/Sep/2022:09:27:38 +0200] "GET /api/6519DFD64A/config?_=1662016701382 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:38:485 device state timeout (handled)
09:27:38:564 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:27:38:565 device state timeout (handled)
09:27:40:304 failed to reconnect to network try=4
172.30.32.2 - - [01/Sep/2022:09:27:43 +0200] "GET /api/6519DFD64A/config?_=1662016701383 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:45:305 failed to reconnect to network try=5
172.30.32.2 - - [01/Sep/2022:09:27:48 +0200] "GET /api/6519DFD64A/config?_=1662016701384 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:50:304 failed to reconnect to network try=6
172.30.32.2 - - [01/Sep/2022:09:27:53 +0200] "GET /api/6519DFD64A/config?_=1662016701385 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:53:365 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00 / serialno: DE2254892, ConBee II
09:27:55:305 reconnect network done
09:27:55:463 Device firmware version 0x26780700 ConBee II
09:27:55:465 unlocked max nodes: 512
09:27:55:559 Device protocol version: 0x010E
09:27:55:801 CTRL ANT_CTRL 0x03
09:27:55:812 CTRL ZDP_RESPONSE handler 0x0001
09:27:55:853 Device protocol version: 0x010E
09:27:56:265 CTRL ANT_CTRL 0x03
09:27:56:267 CTRL ZDP_RESPONSE handler 0x0001
09:27:56:513 Bind response success for 0x842e14fffe1b9bf6 ep: 0x01 cluster: 0x0006
09:27:56:568 ZCL configure reporting rsp seq: 33 0x842E14FFFE1B9BF6 for ep: 0x01 cluster: 0x0006 attr: 0x0000 status: 0x00
172.30.32.2 - - [01/Sep/2022:09:27:58 +0200] "GET /api/6519DFD64A/config?_=1662016701386 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:27:59:793 Bind response success for 0x842e14fffe1b9bf6 ep: 0x01 cluster: 0x0006
09:27:59:794 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x842E14FFFE1B9BF6 (seems to be active)
09:28:00:482 ZCL attribute report 0xB4E3F9FFFE67D983 for cluster: 0x0001, ep: 0x01, frame control: 0x08, mfcode: 0x0000
172.30.32.2 - - [01/Sep/2022:09:28:03 +0200] "GET /api/6519DFD64A/config?_=1662016701387 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:28:08 +0200] "GET /api/6519DFD64A/config?_=1662016701388 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:28:10:349 device state timeout (handled)
09:28:10:429 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:28:10:429 device state timeout (handled)
172.30.32.2 - - [01/Sep/2022:09:28:13 +0200] "GET /api/6519DFD64A/config?_=1662016701389 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:28:18 +0200] "GET /api/6519DFD64A/config?_=1662016701390 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:28:23 +0200] "GET /api/6519DFD64A/config?_=1662016701391 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:28:25:383 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00 / serialno: DE2254892, ConBee II
09:28:26:999 Device firmware version 0x26780700 ConBee II
09:28:27:003 unlocked max nodes: 512
172.30.32.2 - - [01/Sep/2022:09:28:28 +0200] "GET /api/6519DFD64A/config?_=1662016701392 HTTP/1.1" 200 11553 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:28:29:277 device state timeout (handled)
09:28:29:356 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:28:29:357 device state timeout (handled)
09:28:29:365 0x842E14FFFE196145 error APSDE-DATA.confirm: 0xA7 on task
09:28:29:524 0xBC33ACFFFE7038E9 error APSDE-DATA.confirm: 0xA7 on task
09:28:29:685 0x842E14FFFE1B9BF6 error APSDE-DATA.confirm: 0xA7 on task
172.30.32.2 - - [01/Sep/2022:09:28:33 +0200] "GET /api/6519DFD64A/config?_=1662016701393 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:28:38 +0200] "GET /api/6519DFD64A/config?_=1662016701394 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:28:43 +0200] "GET /api/6519DFD64A/config?_=1662016701395 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
09:28:43:379 COM: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2254892-if00 / serialno: DE2254892, ConBee II
09:28:45:151 Device firmware version 0x26780700 ConBee II
09:28:45:154 unlocked max nodes: 512
09:28:47:380 device state timeout (handled)
09:28:47:460 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:28:47:461 device state timeout (handled)
172.30.32.2 - - [01/Sep/2022:09:28:48 +0200] "GET /api/6519DFD64A/config?_=1662016701396 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
172.30.32.2 - - [01/Sep/2022:09:28:53 +0200] "GET /api/6519DFD64A/config?_=1662016701397 HTTP/1.1" 200 11554 "https://blahblahblah.duckdns.org:8123/api/hassio_ingress/_BGk5OJbCkYq6XejSKIkr-PFQUaUyBoJuEqvKpKmvo8/pwa/settings-gateway2.html?_v=42f07f6c21c01a17be6c5c9163804cfd6437609d,8,4,9&gwid=00212EFFFF0661C4" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/104.0.0.0 Safari/537.36"
