I’ve seen other posts about Aeotec Multisensor 6, but my question is once paired, 1 out of 5 of them showed a “Parameter 7” setting. This should be set to 22, I’m told. But why didn’t the other ones have it? Is it a firmware difference? And if so, how do I update either the old or new ones so they’re all the same firmware?
The Aeotec Multisensor 6 can enable a binary sensor for motion with parameter 5 (see config or this post from the linked thread). The parameter 7 mentioned in the specific post you linked is for a different brand and product, “Philio Tech Multisensor 3 in 1 Motion / Light / Temp”.
Interesting. Then HA mis-heard the node then. I deleted and re-added it and no parameter 7 was found. The issue I do have with these devices is if the device is originally added with a battery installed, it will sleep on the network most of the time. Even if I power it via USB.
There seems to be no command (or automatic sensing) to deal with “started as a battery but went to USB” scenario. Which sounds odd, because when started as USB I can query the node all the time. So there must be something exchanged during pairing that can’t be overriden.
