Well you should bloody ask then!!
Here is my config…
"username": "my-user-name-here",
"password": "my-password-here",
"ssl": false,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"allowed_networks": [
"172.30.0.0/16"
"banned_ips": [
"banlimit": 5,
"ignore_pattern": [
"__pycache__"
"dirsfirst": true,
"enforce_basepath": false,
"notify_service": "persistent_notification.create",
"sesame": "secret-sesame-here"
Then it’s accessed like this:
https://domain.duckdns.org:3218/secret-sesame-here
If you want to, I have a blog entry here on using the Caddy add-on and securing Home Assistant and configuring this. Take a look.
tbar05
November 25, 2018, 12:40am
22
sweet, got Sesame all up and running too.
now to get stuck into making some of this stuff actually work
thanks David so much for all your help getting me set up!
ThaNerd
(Turbo Tronix)
April 10, 2019, 5:20pm
23
Something happened to my Configurator since last update, I can only access it via the Add-On “Open WebUI” link, but when I click on the shortcut in the left pan menu I get an error: myplace.duckdns.org refused to connect.
Did you have a look at the numerous threads regarding the configurator with recent activity? You’ll find explanations and solutions there.
# Home Assistant Add-on: File editor
Browser-based configuration file editor for Home Assistant.
![Supports aarch64 Architecture][aarch64-shield] ![Supports amd64 Architecture][amd64-shield] ![Supports armhf Architecture][armhf-shield] ![Supports armv7 Architecture][armv7-shield] ![Supports i386 Architecture][i386-shield]
![Configurator in the Home Assistant Frontend][screenshot]
## About
The File editor, formerly known as Configurator, is a small web-app (you access it via web browser) that provides a
filesystem-browser and text-editor to modify files on the machine the File editor is
running on.
It is powered by Ace editor, which supports syntax highlighting for various
code/markup languages. YAML files (the default language for Home Assistant
configuration files) will be automatically checked for syntax errors while editing.
## Features
This file has been truncated. show original
The Configurator add-on now has Ingress suppport. You now can edit files remotely from within Home Assistant!
