Configuring Modbus-Integration for Remeha Qinta Ace gas heating device
Hi klakol!
starting from your very hepful work i managed to get infos in HA from my De Dietrich Alezio heat pump.
Now i have some troubles with DHW tank temperature…do you had any luck with this regisrer value? I got always or 0 or invalid value. Just tried all device_class (int16, uint16, float16, etc…). or maybe do you found this information (DHW tank temperature) from other register…
solved reading the equivalent register in Zone 2 so 1631 and 1632.
:wink:
Is there a place where the whole connection chain from Quinta/ Elga Ace - GWT-08 - … HA is described?
On tweakers (a Dutch site) there is some info.
https://gathering.tweakers.net/forum/list_messages/2099846 - perhaps using Google Translate you can manage? Otherwise feel free to drop me a line.
In my case i connected an esp wemos d1 to an RS485 interface which is linked in turn to the GTW-08. The gtw08 is connected to the Elga using the existing wiring (rbus?). Modbus implementation is complicated. Reading values works to a certain extent, changing settings is more difficult. Personally i am a bit underwhelmed by the end result
Thanks!
This helps a lot. In my case I am also planning to use an ESP32 Arduino processor to collect the data. Basically reading is the first priority.
I am using the Arduino IDE. If you cound provide the code (as a scetch) it would help for sure!
Cheers
p.s.
In case you are waiting for a reply - I am off for the next two weeks
I use esphome. Integrates nicely with HA
Hello! I’m Trying to do soemthing similar with Baxi and GTW-08 (Baxi uses same GTW) Someone has the complete Modbus code? With all parameters?
Thank you very much!
I was quite busy the last time; so I neglected the management of the Remeha interface. I just saw, that Home Assistent reports this error:
Invalid config for ‘modbus’ at configuration.yaml, line 578: remeha_FlowTemperatureReceived: count
illegal with data_type: int16 ‘modbus->0->sensors->0’,
got
{‘name’: ‘remeha_FlowTemperatureReceived’, ‘slave’: 100, ‘address’: 273, ‘count’: 1, ‘input_type’: ‘holding’, ‘data_type’: ‘int16’, ‘scan_interval’: 5, ‘unit_of_measurement’: ‘°C’, ‘state_class’: ‘measurement’, ‘scale’: 0.01, ‘precision’: 1},
please check the docs at Modbus - Home Assistant
Not sure, what caused this problem?
I found (my own :-)) repo, where I have stored the Modbus-Params in 2021:
I will have to recheck the interface.
Ok, got it. The modbus integration has evolved, the config entries retries and count have to be removed. The working config for me is now as such:
modbus:
  - name: waveshare_gateway
    type: tcp
    host: 192.168.1.224
    port: 502
    timeout: 10
    delay: 2
    sensors:
      - name: remeha_FlowTemperatureReceived
        slave: 100                 # GTW08 ModBUS-Adresse lt. Kodierrad Einstellung
        address: 273               # Modbus-Register-Adresse lt. Parameterliste, Decimal
        input_type: holding        # Holding register
        data_type: int16           # Modbus Datentpy lt. Parameterliste
        scan_interval: 5           # Der Master (also Homa Assistant) soll alle 10 Sekunden diesen Sensor abfragen
        unit_of_measurement: °C    # Erwartet wird eine absolute Temepratur in °C
        state_class: measurement   # Erwartet wird ein Wert mit Maß für eine Temperatur
        scale: 0.01                # Multiplikation mit 0.01
        precision: 1               # Eine Nachkommestelle (bei Int?)
      - name: remeha_ReturnTemperatureReceived
        slave: 100
        address: 274
        input_type: holding
        data_type: int16
        scan_interval: 5
        scale: 0.01
        precision: 1
      - name: remeha_ApWaterPressure
        slave: 100
        address: 409
        input_type: holding
        data_type: int16
        scan_interval: 5
        unit_of_measurement: bar
        scale: 0.1
        precision: 1
      - name: remeha_varApTOutside
        slave: 100
        address: 384
        input_type: holding
        data_type: int16
        scan_interval: 5
        scale: 0.01
        precision: 1
      - name: remeha_varChCtrBurnerStarts
        slave: 100
        address: 419
        input_type: holding
        data_type: int32
        scan_interval: 5
        scale: 1
        precision: 1
      - name: remeha_varChCtrBurnHours
        slave: 100
        address: 421
        input_type: holding
        data_type: int32
        scan_interval: 5
        unit_of_measurement: h
        scale: 1
        precision: 1
      - name: remeha_varApChEnergyConsumption
        slave: 100
        address: 433
        input_type: holding
        data_type: int32
        scan_interval: 5
        unit_of_measurement: kWh
        scale: 1
        precision: 1
Hey Ruben, i was trying to recreate your setup. What hardware did you use and how did you connect it ?
Hello!
Apart from making sensors and climate entities, have you managed to make switches or numerical entities to write on the thermos?
Thank you!
no, I am just monitoring some values, to see, if the system works
Ok. Thank you!
Is the red led on the GTW-08 only green when communicating with the waveshare? I have the waveshare RS485 TO POE ETH (B) connected to the GTW-08 on my Eria tower heatpump. But the light stays red. I can reach the waveshare via the IP and can config the waveshare. But thats all. Also no rx/tx flashing. Does anybody has some tips to continue?
Have you tried to change the wires? This was my first error. After connecting them as follows, it worked for me:
Bus A -> Bus B
Bus B -> Bus A
OV -> GND
Thanks for your reply, Yes I tried both ways. Without any result.
Hi All,
I finally get the setup working. with the folowing config
Model:
Remeha Eria Tower ACE S (8kW)
GTW-08 → RS458 to POE ETH (B) :
Bus A → Bus A
Bus B → Bus B
0V → GND
Settings in waveshare webpage:
RS458 to POE ETH (B):
GTW-08:
The dipswitches 1 ON 2 ON Baud rate: 57600 (photo is not reflecting the actual baud rate)
Example modbus.yaml code
I think it is a difference of the version of the GTW-08 board. look at https://kennisbank.remeha.nl/gateway-08-modbus-updates/
I have also a GTW-08 Modbus interface but for a brötje heat pump.
Everything works fine, expecting the timeouts which leads to charts like this:
Anyone facing the same issue?
My HA Modbus Configuration looks like this:
And this is my waveshare converter setup:
I have the latest Quinta 45 (without Ace or Pro), based on R-bus.
The Gateway 16/17 with the eTwist has very limited functionality, which is very disappointing… I have heard from Remeha that they will come with a new thermostat, replacing the eTwist for a new one with more functionality (like heating curves) within a few weeks. My installer is now waiting for it. I hope the Gateway 16/17 can pull more data from the R-bus and communicate to the new thermostat.
For now, I need to live with the possibilities there are.
I understand to read the temperature flow and return and to determine the delta, I need the Modbus Gateway 08 (article 7721982). This is not delivered with RJ45 or WiFi, I need the Waveshare or something similar as I don’t have ethernet cable at my loft.
Isn’t there any other possibility nowadays for these new and modern heating system? I did not expect there would be no integration of IoT for a standard Remeha Quinta as per today. To read these simple values it’s quite an additional investment and time to monitor things. In the menu Overview at my Quinta many interesting information is readable.
Any help is appreciated.
