Yes, what is the problem? You need to subscribe the mqtt topic, after instaling the MQTT integration:
Please, PM me if you’ve some trouble.
Best Regards,
Fernando Gomes
Best Regards,
Fernando Gomes
Hi @fapg,
I am not able to run the python script.
apk add py3-paho-mqtt
to my HAOSDEBUG:root:Starting owl2mqtt on ip: 10.0.1.200
DEBUG:root:Connected to broker with the result code: 0
DEBUG:root:Connected: 1
2024-01-11 00:56:39: New client connected from 10.0.1.200:46643 as owl2mqtt client (p2, c1, k60, u'XY').
2024-01-11 00:58:12: Client owl2mqtt client has exceeded timeout, disconnecting.
Maybe you could help me to get it run. Thanks. Here is the owl2mqtt.conf (XY=I have changed here)
[global]
debug = 1
[owl]
owl_port = 22600
owl_group = 224.192.32.19
owl_listen_ip = 10.0.1.200
owl_multicast = 0
[mqtt]
address = 10.0.1.200
port = 1883
username = XY
password = XY
Thanks for helping
Sorry for the delay. Do you try to activate multicast option? Can you provide a sample of the command (let it run for 5 or 10 minutes):
tcpdump -nn port 22600
