Confirmation dialog on switch/button UI actions
Thanks!! do you know if there is something similar for cover entities such as garage door?
i guess still with the workarounds & the lovelace lock - there is value in having it built in globally and natively inside HA
I assume this wish is still pending.
In the meantime, I am using the entity button card, and its hold action.
Instead of a quick click, you need to click and hold for about 3 seconds, to trigger the action.
Just saw this. Fantastic idea.
I was using @faisalqureshiā€™s solution, but then I found the lock feature natively supported by the button-entity custom cards. If you install this for lovelace, you can use the lock: true functionality which is designed for this use case. I implemented this for my garage door (cover) entity and it works really well. You can even limit the ā€œunlockā€ capability to only specific HA users!
screenshot:
custom card info:
My garage doorā€™s lovelace entity config:
entity: cover.garage_door_opener
        type: 'custom:button-card'
        tap_action:
          action: toggle
        show_name: true
        show_state: true
        lock: true
        state:
          - value: closed
            icon: 'mdi:garage'
            styles:
              state:
                - font-size: 12px
                - color: green
          - value: open
            icon: 'mdi:garage-open'
            styles:
              state:
                - font-size: 12px
                - color: red
Yes. I too discovered this custom card last week. It is amazing. Iā€™m slowly changing all my cards to this. The level of customisation is fantastic.
Have you tried the ā€œconfirmationā€ tag? It gives you a confirm prompt before triggering.
It also has tap_action, dbltao_action, and hold_action. Works very well for the situation in this thread.
Yep! I personally like the lock function, but that one also does the trick.
I still vote for this feature. I propose an update to persistent notifications component to also have ability to show lovelace dialogues.
For example you can specify if itā€™s persistent notification or a lovelace popup with buttons that can trigger actions. That way anyone can use notifications for whatever they want. So if i want to display confirmation to turn off a light or disable home alarm arming i can do it. This seems like a vary basic functionality thatā€™s missing.
  - double_tap_action:
      action: call-service
      confirmation:
        text: Are you sure you want to restart?
      service: script.1585358453646
This is here as an fyi for anyone who comes through here later. This yaml is in my picture elements, and pops up a confirmation dialog for me.
      confirmation:
fyi this is a thing now
This is implemented in Lovelace now. Closing
