Maybe stupid question, but where and what is the update sensor? Where can I find it to unable the node updates three times in two weeks, but still can update esphome, and other updates from HASS still show?
Itâs an entity that creates the notifications that felicitate the updates for a device. Disable the entity, remove the notification.
Update entities are the same as any other entity. You find them with the related device. If by chance you canât find the device itâs coming from, you can always look for entities in Developer Tools â States page.
everyone use this service call to skip all updates from esp home devices
service: update.skip
data: {}
entity_id: >
{{ states.update |
selectattr('state', 'eq', 'on') |
map(attribute='entity_id') |
select('in', integration_entities('esphome')) |
list }}
This approach made the most sense. I can skip with one click but still see that updates are available until I do. Thanks!
Thanks!
However, update sensor remains enabled, so i guess that at next esphome update sensor will again show tthe need for an update (or will it?). Would be possible to use some kind of a script which would change all esphome update entities to disabled? (automatically, if possible, of course⌠)
I made the following automation to skip all ESPHome and MQTT Updates. Just edit integrations List. @Protoncek
automation:
- id: 13b62e56-d3f1-47a2-a558-cec4660119e4
alias: skip selected Updates
description: ""
mode: restart
variables:
integrations:
- esphome
- mqtt
entities: >
{%- set ns = namespace(entities=[]) -%}
{%- for x in integrations -%}
{%- set entity = integration_entities(x)
| select('match', 'update.')
| list -%}
{%- set ns.entities = (ns.entities + entity) -%}
{%- endfor -%}
{% set list = ns.entities %}
{%- for x in list -%}
{% if states(list[loop.index-1]) in 'on' %}
{% set ns.entities = ns.entities + [x] %}
{% endif %}
{% endfor -%}
{{ ns.entities }}
# Trigger every Minute
- platform: time_pattern
minutes: "/1"
condition:
- alias: "update available?"
condition: template
value_template: "{{ entities|length > 0 }}"
- service: update.skip
entity_id: >
{{ entities }}
Wow, thanks a lot! So, if understand correct this should âdeleteâ update warnings for esphome (and mqtt) when they popup⌠nice!
Finally, no more EspHome device update notifications. Soo annoying- what were the devs thinking !?
Automation Editor:
alias: ESPHome Update Skip All
description: ""
minutes: /1
condition: []
data: {}
entity_id: |
{{ states.update |
list }}
mode: single
They were thinking to notify you about an update
Itâs the same when a new HA core is released for example - you get notified about the update (thatâs very common thing in the modern computer world - otherwise you just directly do auto-updates but thatâs not really that good for HA related stuff as things might break if you donât read change logs! )
You can also disable esphome updates notifications with a simple toggle switch instead creating an automation⌠but that might be to easy and not worth the rant
No. Embedded devices shouldnât be updated 3 times a month. Updates should only be for security or required features.
Theyre not designed for constant updates. Flash wears out; not a problem on a hdd with wear protection, but on an Embedded device its a no-no.
How can all esphone device update notifications be disabled with a simple toggle whilst leaving esphome addon update notifications on? If thats possible the solution should be mentioned here.
Disable the update entity for the device. The update entity for the addon is handled by the supervisors integration.
Youâre really blowing this out of proportion. In fact, this is the first time Iâve even tried it⌠by simply using the menus provided in home assistant. Sometimes it pays to click around to discover things.
Yeah, right⌠say that i have 50 or even 100 esphome modules. In this case i can only update these modules 24/7, no eating, sleeping, workingâŚ.
Donât fix if itâs not broken! The golden rule! I only update my espâs if i need some changes, fixes or if itâs breaking change.
Itâs like any other device in HA that has a firmware update. You can disable the firmware (update entity), see my previous post. Itâs very simple. Itâs so simple, thereâs no need for a debate.
And who is forcing you doing this updates? By default you get a notification - thatâs all. Same with HA (core) for example, what you do with this information is your own beer
You might have any link backing up your speculations with espâs dying like flies? Like in the esphome forums or discord maybe? Any one wearing out their flash?
Last knowledge I had saved was the flash chips used in espâs have minimum 100.000 (one hundred thousand) write cycles - Meaning you can flash a new firmware, every day for over 250 (two hundred fifty) years and it should still not be worn out.
You might confuse the type of flash cells with the ones commonly used in SSDâs! For example some MLC NAND only allows a few thousand writes
I know itâs hard, but the solution includes the search engine and a little bit of commitment - unsubstantial ranting on the other is much easier!
Itâs only a notification (which can be easily turned off), you are not forced to update. Also you donât need to stop eating, sleeping or even working. Itâs your own decision what to do with this notifications (same for HA). If you donât need them you can easily turn them off
Still running HA 0.78 - right?
Yeah, itâs only a notification⌠or 100 of them. And then i will quite easily find an important update notification among those 100 useless ones, right?
Iâm only saying that by default this notification should be disabled, not enabled. Yes, they can be turned off easily. But, as i already said: esp modules are not needed to be updated regularly, so it would be quite more productive and easier just to turn on a few ones which i do want a notification then turn off hundreds of them.
HmâŚyouâre comparing apples and hamburgersâŚ
Itâs no longer an issue, just add the above automation and the problem sorts itself out. No need to click around in Home Assistant every time a new device is added etc. Let the automation do that for you, whoop
I personally have around 40 ESPhome devices, so I know the situation described above.
My 2ct on this:
- Donât enable automatic updates of the add-on (donât do that for any add-on, they can having breaking changes in the update, make sure to check whatâs changed first), and if the update doesnât bring you any relevant changes, skip the update of the ESPHome add-on. Next time it will have a new update, you will get an update notification again, and you can decide again if you want to update.
- In case there are specific ESPHome devices you donât want to update at all, just disable the update entity for that device like @petro has shown above, or move the yaml config for the device to another subfolder in your
esphome
folder. If you really donât want to update it, you canât make changes to the configuration anyway, because flashing the new configuration will also update it. - If you do want to keep the add-on up to date, and you want to skip all update entities of the ESPHome integration. I would suggest to trigger on a state change of the ESPHome Add-on update entity going from
on
tooff
(indicating it has been updated) or to create a binary sensor indicating there are ESPHome devices with an update and trigger on that binary sensor turingon
. There is no need to trigger every minute and check if there might be any ESPHome devices with a pending update.
I personally have an indicator for pending updates on my dashboard. If I updated the ESPHome add-on, and donât feel like updating all entities (for example if there was an update for the voice component only relevant for my Atom Echo) I have a template button which skips all ESPHome update entities.
Yep, I do the same. Although I just have it as a service call to either update all or ignore all.
But arenât these updates necessary for the devices as well? Or are most of these updates only applicable to the addon itself? How do you tell the difference?
Most of the updates are fixes for particular issues with specific boards or sensors. You can read the release notes to figure out whatâs changed. They are as detailed as the HA releases.
