šŸ“² Contact Sensor (Door or Window) Left Open Notification
Thatā€™s an option but with this blueprint I did intend to not have any helpers that need to be configured. I think for beginners these kinds of options are just a little confusing. Hopefully automations in HA get changed in a way that allows for definition of helper variables in the automation itself without the need to manually define a helper.
Would it be possible to trigger the automaton with an NFC tag scan instead of a timer? We often leave windows open throughout the house most of the day, so the timer wouldnā€™t help me much, but I would like to integrate open window warnings into a bedtime routine triggered by an NFC tag.
I still do not get the point to not have a Ā« end of alert Ā» event. I mean, there is a Ā« alert removal delay Ā», so at least you can user implement their own logic.
At the very least would it be possible to have a custom action Ā« alert trigger Ā», for the moment we can only send a notification, but for instance I would like tower my own actions.
Hi @Malte
thx for this great blueprint. I tested it and basically it works fine and I get some notifications.for my 3 doors (2 Sonoff sensors, 1 aqara sensor)
However sometimes (not every time) when looking at the traces I see there is an error and it is stopped
Template rendered invalid service: ā†’ see also screenshot (sorry it is in german)
Did I something wrong or do I have to change something?
thx for your work :grinning:
Would you mind adding a version number to the BP itself? This would help to determine if you are running the latest version, what his changed from the currently used version to latest.
Thanks for the report. German is perfectly fine for me :slight_smile:
Can you go through the different tabs and does it say somewhere which service it is trying to run? Or is it just empty. Can you also try to reproduce it and describe when exactly this happens. Thanks in advance!
Iā€™ll add it to my to do list!
Hard to say what triggers the error. For me it seems the error happens when the script tries to make a second Iteration ā†’ see screenshot below
Today HaustĆ¼re worked perfetct with no error while GartentĆ¼re has shown the same error again todayā€¦
HaustĆ¼re
vs GartentĆ¼re
In the different tabs I could not find any more information about the service it trys to runā€¦ is there any special tab to look into?
Good blueprint, but i am also one of those that needs multiple entity support. Doing that single entity over and over wont work for me either. I pretty much have this running now with actionable notifications and clickAction as well so it would be more of the same single use work that I already have in place
Great job though and it looks well put together!
The only difference I spot is that the tag in the failing iteration ends with ā€œ,ā€ which the first one does not. Can you send the YAML config of your blueprint you get to via editing the blueprint and then clicking the three dot menu and in German it says ā€œAls YAML bearbeitenā€. This could probably help best at investigating the problem further.
:rocket: Update 2024.04.23 has been released
See the changelog in the initial post for details.
@schlomm, @gyle, @chris400, @hazio, @aelsharawi, @mefistofelis and @danktankk: Your request about supporting binary_sensor group has been implemented. As of now input_boolean that are grouped like described here are not supported.
@chris400 Version number has been added. Thanks for the idea!
If you notice something not working as expected please let me know!
here is my YAML config
Blueprint config
alias: NOTIFICATION GartentĆ¼re offen
description: Nach 10 Minuten erfolgt eine Notification, dass die GartentĆ¼re offen ist
use_blueprint:
  path: Raukze/contact-sensor-left-open-notification.yaml
  input:
    trigger_entity: binary_sensor.tursensor_werkstatt_contact
    friendly_name: GartentĆ¼re
    notify_services_string: "notify.telegram_roland, "
    notification_title: NOTIFICATION {{ friendly_name }}
    notification_message: >-
      {{ friendly_name }} steht offen {{ as_timestamp(now()) |
      timestamp_custom('%T', True) }}.
and
automation config
mode: restart
max_exceeded: silent
variables:
  issue_state: 'on'
  duration_issue_state:
    minutes: 10
  condition_send_notification: []
  delete_notification: true
  duration_from_issue_state:
    seconds: 5
  notify_services_string: 'notify.telegram_roland, '
  notification_click_url: /lovelace/ROOM
  repeat_notification: false
  time_between_repeat_notification:
    minutes: 10
  notification_icon_warning: alert
  notification_color: red
  notification_interruption_level: active
  custom_action_issue_state: []
  custom_action_from_issue_state: []
  - platform: state
    entity_id: binary_sensor.tursensor_werkstatt_contact
    to: 'on'
    for:
      minutes: 10
  - platform: state
    for:
      seconds: 5
  - variables:
      notify_services_list: '{{ notify_services_string.split('','') }}'
      number_of_notify_services: '{{ notify_services_list | count }}'
      notification_tag: >-
        {{ trigger_entity[-20:] }}-{{ friendly_name[-20:] }}-{{
        notify_services_string[-20:] }}
  - choose:
      - conditions:
          - condition: trigger
          - condition: []
        sequence:
          - repeat:
              sequence:
                - parallel:
                    - repeat:
                        count: '{{ number_of_notify_services }}'
                        sequence:
                          - service: '{{ notify_services_list[repeat.index-1] }}'
                              message: >-
                                as_timestamp(now()) | timestamp_custom('%T',
                                True) }}.
                                clickAction: /lovelace/ROOM
                                url: /lovelace/ROOM
                                tag: '{{ notification_tag }}'
                                color: red
                                notification_icon: mdi:{{ notification_icon_warning }}
                                push:
                                  interruption-level: active
                                persistent: false
                                sticky: false
                    - choose: []
                      default: []
                - if:
                    - '{{ repeat_notification }}'
                  then:
                    - delay: '{{ time_between_repeat_notification }}'
              until:
                - '{{ not repeat_notification }}'
      - conditions:
          - '{{ delete_notification }}'
        sequence:
          - parallel:
              - repeat:
                  sequence:
                        message: clear_notification
              - choose: []
                default: []
The value should just be notify.telegram_roland without the comma and space characters. This might be the issue.
Thx for your help :+1:, I just changed it. Hope this fixed it :grinning:
Hello Malte
Sorry but I canā€™t make it works.
And I donā€™t see why:
My yaml
mode: single
variables:
  custom_friendly_name: ''
  trigger_entity: binary_sensor.porte_et_fenetres
  issue_state: 'on'
    hours: 0
    minutes: 0
    seconds: 10
    days: 0
    - condition: state
      entity_id: person.corinne
      state: not_home
    - condition: state
      entity_id: person.philippe
      state: not_home
  delete_notification: false
    seconds: 5
  notify_services_string: notify.notify
  notification_title: The {{ friendly_name }} was left open
  repeat_notification: true
    hours: 0
    minutes: 1
    seconds: 0
    days: 0
  - platform: state
    entity_id: binary_sensor.porte_et_fenetres
    to: 'on'
    for:
      hours: 0
      minutes: 0
      seconds: 10
      days: 0
  - platform: state
    for:
      seconds: 5
  - variables:
        {{ trigger_entity[-20:] }}-{{ custom_friendly_name[-20:] }}-{{
      initially_triggered_at: '{{ now() }}'
  - choose:
      - conditions:
          - condition:
              - condition: state
                state: not_home
              - condition: state
                state: not_home
        sequence:
          - repeat:
              sequence:
                - variables:
                    friendly_name: |
                      {% if custom_friendly_name != '' %}
                        {{ custom_friendly_name }}
                      {% else %}
                        {% set expanded_trigger_entity_list = expand(trigger_entity) | selectattr('state', 'eq', issue_state) | map(attribute='name') | join(', ') %}
                        {{ ' & '.join(expanded_trigger_entity_list.rsplit(', ', 1)) }}
                      {% endif %}
                - parallel:
                    - repeat:
                        sequence:
                              message: >-
                                The {{ friendly_name }} was left open at {{
                                as_timestamp(initially_triggered_at) |
                                url: /lovelace/ROOM
                                color: red
                                push:
                                persistent: true
                                sticky: true
                    - choose: []
                      default: []
                - if:
                  then:
              until:
      - conditions:
        sequence:
          - parallel:
              - repeat:
                  sequence:
              - choose: []
                default: []
alias: šŸšŖ Contact Sensor Left Open Notification by Malte
description: ''
trace:
  stored_traces: 20
Every try leads to this issue.
An idea of what I am doin wrong?
Looking at the screenshot of the execution attempt, Iā€™m wondering if you triggered the automation manually or if the sensor status change actually triggered the automation? To me it looks like a manual trigger, which definitely doesnā€™t work but is intentional.
Okey. Thanks for having replied. Iā€™m going to test it IRL. :smiley:
Iā€™m pretty new to Home Assistant so forgive me if thereā€™s an obvious answer to this, but Iā€™ve configured an automation using the blueprint and when I manually run it Iā€™m not getting a notification and am seeing the below error in my logs.
Template variable warning: ā€˜friendly_nameā€™ is undefined when rendering ā€˜The {{ friendly_name }} was left openā€™
Iā€™ve used the default settings in the blueprint and updated the Entity ID for my DW sensor group (Door & Window Sensors) and updated my device id for my phone (notify.mobile_app_pixel_7).
What am I missing?
Thanks for trying out my blueprint. Manual trigger does not work due to the implementation of the blueprint. Easiest way to try or debug is to just set the intervals to a couple of seconds or just 0 and the notification should arrive immediately when the state of the sensor changes. Hope that my answer is helpful!
This blueprint is great! Itā€™s replacing a custom written AppDaemon app I had for this purpose. Thanks for sharing it.
Thereā€™s one thing I donā€™t see how to set up. Triggering on contact sensors works fine. But, is there a way it can trigger when people become away, or a zone state changes? For example, letā€™s say:
  1. I open a window before bed.
  2. I leave the next morning for work, and forget to close the window.
  3. ???
For my custom automations, I have a separate automation that triggers on a Person group becoming not_home, and then checking the state of doors and windows. Iā€™d love to be able to replace that with this blueprint!
