Control a ceiling fan using Esphome and NodeMCU but only full speed working, speed 1,2 and 3 are not?
WTF! Do I see Dupont wires and a breadboard used for mains voltages and currents? The only parts here that are probably rated for that are the capacitors. Shouldn’t this whole thread be removed to save lives?
@Jpsy I have clearly mentioned this is only for testing purposes and doesn’t go into the wall, I have made actual PCBs and stuff to actually support this system, I am well aware using this can easily cause a fire while testing itself one of the resistors caught fire…
It can kill you without fire. The insulations are not rated for high voltages. Others might try to copy that. I do not recommend to show such experiments in public, even if I did them in private. And you did not expect the resistors catching fire yourself. It was not under control and it will not be for others. I am just afraid that we might injure people here.
@hussainimustafa325 - so were you able to take it to the wall with actual pcb or you had to adjust Hw?? i had a look at the youtube and looks like circuit worked for that guy…
