also to chime in here for those wanting to use Emulated Hue with the Logitech Remote
this was my code:
emulated_hue:
host_ip: 10.10.10.11
listen_port: 8300
expose_by_default: false
exposed_domains:
- light
- cover
entities:
light.controller_rgb_w_rf_f696a8:
name: Drinks Cabinet Lights (Hue)
hidden: false
light.controller_rgb_ir_96b051:
name: Lantern Lights (Hue)
hidden: false
cover.lantern:
name: Lantern Window (Hue)
hidden: false
i added the above code to the bottom of the configuration.yaml (obviously edit the IP for your HA)
i have the app running on iOS, just went to Settings > Devices > Add a Device > Phillips Hue
Then it scanned for it, once it found it, I connected, it briefly said to press the pairing button then skipped through to “done” whithout doing anything
Go to Remote and Hub > Button Customisation > Customise Buttons > Home Control Buttons > and assign in there
I also managed to add a ‘cover’ which is a motor control, i can select the device with the top ‘plug’ and then use the ‘dimmer +/-’ to open and close it
Enjoy
