I got it working on a esp8266. it works great. I wounder if the # out key functions works?
# - platform: uart
# name: "W auto key"
# data: [0x0F, 0x80, 0x5F, 0x00, 0x0E]
# - platform: uart
Yes for most of them if l remember well. But it is probably not a good idea to mix them with the custom component. I think they was nothing very interesting that is not in custom component, it was just some first test.
Something useful/fun would be to drive the motors but I didn’t found the commands to send. It seems to be possible because some people did it but they didn’t share the code (or I didn’t found…)
Hi
I found this github that have the motor codes
Excellent
thanks!
I thought there was HACS integration for Husqvarna mowers with Automower® Connect, like the 305. How come the above is needed?
Oh NVM, just needed to RTFM ![]()
“ Automower® Connect comes standard on all X-line models, and it’s an optional add-on for other 300 and 400-series models. ”
I have a 220ac
bought myself a husqvarna aspire r4, after watching this
Only bug I’ve encountered so far is throws an error and fails to load if there is no schedule defined in the cloud
I updated my code to add buttons in HA for motors but it seems not working well. I just added keys and software stop (not tested for now) (+ 0D 9A 99 modes ??? )
Aspire R4 is a good entry level robot mower, has wifi and Bluetooth, has HA integration (via developer API) and is good for up to a 600sqm lawn. It works well, only downside is the error messages (if any) reading via flashing lights is annoying. But a good mower for the price vs others I’ve researched.
Also wanted to display the next time the mower was scheduled to start (on my
magic mirror and nspanel) in a nicer format than the entity that comes with the mower integration, so created a template helper as follows
{% if states('switch.automower_aspire_r4_enable_schedule') == "off" %}
Schedule Disabled
{% elif states('sensor.automower_aspire_r4_next_start') == "error" %}
Error
{% elif states('lawn_mower.automower_aspire_r4') == "mowing" or states('lawn_mower.automower_aspire_r4') == "returning" %}
In Use
{% elif states('sensor.automower_aspire_r4_next_start') == "unknown" %}
{% if states('lawn_mower.automower_aspire_r4') == "docked" %}
Recharging
{% else %}
{{ states('lawn_mower.automower_aspire_r4') }}
{% endif %}
{% else %}
{%- set time = (as_timestamp(states('sensor.automower_aspire_r4_next_start')) - as_timestamp(now())) | int %}
{%- set minutes = ((time % 3600) // 60) %}
{%- set minutes = '{}mins'.format(minutes) if minutes > 0 else '' %}
{%- set hours = ((time % 86400) // 3600) %}
{%- set hours = '{}hrs '.format(hours) if hours > 0 else '' %}
{%- set days = (time // 86400) %}
{%- set days = '{}days '.format(days) if days > 0 else '' %}
{{ 'Less than 1 minute' if time < 60 else 'In ' + days + hours + minutes }}
{% endif %}
EDIT: updated helper
Hi I read all your discussion, I wanted to ask if you ever retrieved serial code to “TEST EXIT” option, due to a modification i need to manually say to robot to make it work (it’ s a long story)
Thank you in advance
Hi! This is the year when im connecting my Automower
is there any yaml out there that i can copy paste to an esp connected to my Automower to get it integrated to home assistant? /Carl
Are you using the husqvarna integration? Just add the integration then under the husqvarna device add it to your dashboard.
You mention esp… are you using a automower that can integrate to the cloud?
Your post isn’t that specific…?
Sorry! I’ve got an acx 230 that I want to connect! Bought wires and the contact, and I have both a wemos and an esp32 for the firmware.
try this thread Control husqvarna automower with esphome - #3 by smitec11
Funny, you know you directed me to this thread…![]()
DOH! Posted wrong URL. This is the one I meant… lol.
We’re you able to control the motors?
I made a quick refactoring from a fork to remove custom, haven’t tried it yet. I’ll integrate my mower to hass this summer ![]()
After I tested, should I pr your repo?
I tested your fork but I seem to be missing something in my configuration, would you mind enabling issues in your fork so I can provide more information?
That would be on github.
I think i found out the problem, the orrpan fork was missing the base.yaml file in the config. When I added it it built without any problems.
So the config should look like this in the packages section.
packages:
remote_package:
url: https://github.com/orrpan/esphome-hqam
ref: main
refresh: always
files:
components/confs/base.yaml,
components/boards/esp32dev.yaml,
components/confs/button.yaml,
components/confs/select.yaml,
components/confs/sensor.yaml,
components/confs/textsensor.yaml,
components/confs/switch.yaml,
