Control MCZ Maestro pellet stove via HACore trough MQTT
I understand how you use your stove. I use it in a different way. so I prefer my config. but I think this topic could help other people :slightly_smiling_face:
I use it in a different way :slight_smile: I use external sensors, as the MCZ wifi one eats battery like hell, ans I don’t find it very precise.
I’m using automations to turn it on and off depending of the Temperature from other sensors.
But thxs all for your help :slight_smile:
That’s the next step here as well…
I’m planning on using a Xiaomi BLE Hygrothermograph as the sensor instead of the stove’s sensor.
When this arrives I will change the desired temperature based on the BLE sensor trough an automation rule. This way I can still let the stove use it’s internal pellet/ventilation management.
I’m using as well Xiaomi sensors though zigbee2mqtt, they work like a charm
Here’s my final config:
Everything works like a charm, I can share my YAML files if needed
Nice!
As I only need an on/off switch and a way to send/receive temperature, my thermostat card will do just fine for now :slight_smile:
But it’s always interesting to see the yaml’s :slight_smile:
Wow! Great Job! can you share please?
I’ve updated the page:
Here’s the YAML for the page:
  - title: ''
    path: poele
    icon: 'mdi:fire'
    badges: []
    cards:
      - type: horizontal-stack
        cards:
          - type: 'custom:button-card'
            entity: switch.poele_on_off
            color: 'rgb(255, 165, 0)'
            state:
              - value: 'off'
                color: 'rgb(128, 128, 128)'
            entity: switch.silence_on_off
            color: 'rgb(152,251,152)'
            state:
              - value: 'off'
            entity: switch.chrono_on_off
            color: 'rgb(0, 255, 0)'
            state:
              - value: 'off'
                color: 'rgb(255, 0, 0)'
        cards:
            entity: switch.poele_p_1
            state:
              - value: 'off'
            entity: switch.poele_p_2
            state:
              - value: 'off'
            entity: switch.poele_p_3
            state:
              - value: 'off'
            entity: switch.poele_p_4
            state:
              - value: 'off'
            entity: switch.poele_p_5
            state:
              - value: 'off'
      - type: 'custom:scheduler-card'
        include:
          - switch.marche_arret_poele
          - switch.poele_on_off
        title: Calendrier
      - cards:
          - name: Ventilateur Ambiance
          - cards:
                entity: switch.fan_1_0
                state:
                  - value: 'off'
                entity: switch.fan_1_1
                state:
                  - value: 'off'
                entity: switch.fan_1_2
                state:
                  - value: 'off'
                entity: switch.fan_1_3
                state:
                  - value: 'off'
                entity: switch.fan_1_4
                state:
                  - value: 'off'
                entity: switch.fan_1_5
                state:
                  - value: 'off'
                entity: switch.fan_1_auto
                state:
                  - value: 'off'
        type: vertical-stack
      - cards:
          - name: Ventilateur Salle à Manger
          - cards:
                entity: switch.fan_2_0
                state:
                  - value: 'off'
                entity: switch.fan_2_1
                state:
                  - value: 'off'
                entity: switch.fan_2_2
                state:
                  - value: 'off'
                entity: switch.fan_2_3
                state:
                  - value: 'off'
                entity: switch.fan_2_4
                state:
                  - value: 'off'
                entity: switch.fan_2_5
                state:
                  - value: 'off'
                entity: switch.fan_2_auto
                state:
                  - value: 'off'
      - cards:
          - name: Ventilateur 2
          - cards:
                entity: switch.fan_3_0
                state:
                  - value: 'off'
                entity: switch.fan_3_1
                state:
                  - value: 'off'
                entity: switch.fan_3_2
                state:
                  - value: 'off'
                entity: switch.fan_3_3
                state:
                  - value: 'off'
                entity: switch.fan_3_4
                state:
                  - value: 'off'
                entity: switch.fan_3_5
                state:
                  - value: 'off'
                entity: switch.fan_3_auto
                state:
                  - value: 'off'
Here’s the sensors:
 - platform: mqtt
    state_topic: "PUBmcz"
    value_template: "{{ value_json.Mode }}"
  - platform: mqtt
    name: "Etat du poele"
    value_template: "{{ value_json['Etat du poêle'] }}"
  - platform: mqtt
    name: "Ventilateur Ambiance"
    value_template: "{{ value_json['Etat du ventilateur d\\'ambiance'] }}"
  - platform: mqtt
    unit_of_measurement: '°C'
    value_template: "{{ value_json['Température des fumées'] }}"
  - platform: mqtt
    value_template: "{{ value_json['RPM - Ventilateur fummées'] }}"
  - platform: mqtt
    name: "Vis Sans Fin"
    value_template: "{{ value_json['RPM - Vis sans fin - LIVE'] }}"
  - platform: mqtt
    name: "Mode Chronotermostato"
    value_template: "{{ value_json['Mode Chronotermostato'] }}"
  - platform: mqtt
    name: "Température - Carte mère"
    value_template: "{{ value_json['TEMP - Carte mère'] }}"
  - platform: mqtt
    value_template: "{{ value_json['Puissance Active'] }}"
  - platform: mqtt
    name: "Minutes avant extinction"
    value_template: "{{ value_json['Minutes avant extinction'] }}"
  - platform: mqtt
    value_template: "{{ value_json['Etat du ventilateur canalise 1'] }}"
  - platform: mqtt
    value_template: "{{ value_json['Etat du ventilateur canalise 2'] }}"
  - platform: mqtt
    value_template: "{{ value_json['Mode Silence'] }}"
  - platform: mqtt
    value_template: "{{ value_json['Etat de la bougie'] }}"
And the switches:
# Switch Poele On Off
    switches:
      poele_on_off:
        friendly_name: "Poêle"
        value_template: >-
          {% if is_state('sensor.etat_du_poele', 'Eteint') %}
          off
          {% else %}
          on
          {% endif %}
        turn_on:
          service: mqtt.publish
            topic: SUBmcz
            payload: 34,1
        turn_off:
            topic: SUBmcz
            payload: 34,40
        icon_template: >-
            mdi:fire-alert
          {% else %}
            mdi:fire
          {% endif %}
# Switch Chrono On Off
    switches:
      chrono_on_off:
        friendly_name: "Mode Chrono"
        value_template: >-
          {% if is_state('sensor.mode_chronotermostato', 'Marche') %}
          on
          {% elif is_state('sensor.mode_chronotermostato', 'Arrêt') %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 1111,1
        turn_off:
            topic: SUBmcz
            payload: 1111,40
        icon_template: >-
            mdi:clock
          {% else %}
            mdi:clock-alert
          {% endif %}
# Switch Silence On Off
    switches:
      silence_on_off:
        friendly_name: "Mode Silence"
        value_template: >-
          {% if is_state('sensor.mode_silence', 'Marche') %}
          on
          {% elif is_state('sensor.mode_silence', 'Arrêt') %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 45,1
        turn_off:
            topic: SUBmcz
            payload: 45,0
        icon_template: >-
            mdi:fan-off
          {% else %}
            mdi:fan
          {% endif %}
  - platform: mqtt
    unique_id: ecoonoff
    command_topic: "SUBmcz"
    payload_on: "41,1"
    payload_off: "41,0"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: ventilo1automatique
    name: "Ventilo 1 Auto"
    payload_on: "37,6"
    payload_off: "37,6"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_0
    name: "Ventilo 1 0"
    payload_on: "37,0"
    payload_off: "37,0"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_1
    name: "Ventilo 1 1"
    payload_on: "37,1"
    payload_off: "37,1"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_2
    name: "Ventilo 1 2"
    payload_on: "37,2"
    payload_off: "37,2"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_3
    name: "Ventilo 1 3"
    payload_on: "37,3"
    payload_off: "37,3"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_4
    name: "Ventilo 1 4"
    payload_on: "37,4"
    payload_off: "37,4"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_5
    name: "Ventilo 1 5"
    payload_on: "37,5"
    payload_off: "37,5"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_1_Auto
    payload_on: "37,6"
    payload_off: "37,6"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
# Ventilo 2
  - platform: mqtt
    unique_id: Ventilo_2_0
    name: "Ventilo 2 0"
    payload_on: "38,0"
    payload_off: "38,0"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_2_1
    name: "Ventilo 2 1"
    payload_on: "38,1"
    payload_off: "38,1"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_2_2
    name: "Ventilo 2 2"
    payload_on: "38,2"
    payload_off: "38,2"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_2_3
    name: "Ventilo 2 3"
    payload_on: "38,3"
    payload_off: "38,3"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_2_4
    name: "Ventilo 2 4"
    payload_on: "38,4"
    payload_off: "38,4"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_2_5
    name: "Ventilo 2 5"
    payload_on: "38,5"
    payload_off: "38,5"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_2_Auto
    name: "Ventilo 2 Auto"
    payload_on: "38,6"
    payload_off: "38,6"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
    # Ventilo 3
  - platform: mqtt
    unique_id: Ventilo_3_0
    name: "Ventilo 3 0"
    payload_on: "39,0"
    payload_off: "39,0"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_3_1
    name: "Ventilo 3 1"
    payload_on: "39,1"
    payload_off: "39,1"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_3_2
    name: "Ventilo 3 2"
    payload_on: "39,2"
    payload_off: "39,2"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_3_3
    name: "Ventilo 3 3"
    payload_on: "39,3"
    payload_off: "39,3"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_3_4
    name: "Ventilo 3 4"
    payload_on: "39,4"
    payload_off: "39,4"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_3_5
    name: "Ventilo 3 5"
    payload_on: "39,5"
    payload_off: "39,5"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
  - platform: mqtt
    unique_id: Ventilo_3_Auto
    name: "Ventilo 3 Auto"
    payload_on: "39,6"
    payload_off: "39,6"
    state_on: "ON"
    state_off: "OFF"
    optimistic: false
    qos: 0
    retain: true
# Switch Poele Puissance 1
    switches:
      poele_p_1:
        friendly_name: "Poêle Puissance 1"
        value_template: >-
          {% if is_state('sensor.etat_du_poele', 'Puissance 1') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 36,1
        turn_off:
            topic: SUBmcz
            payload: 36,1
        icon_template: >-
            mdi:fire
          {% else %}
            mdi:fire-alert
          {% endif %}
# Switch Poele Puissance 2
    switches:
      poele_p_2:
        friendly_name: "Poêle Puissance 2"
        value_template: >-
          {% if is_state('sensor.etat_du_poele', 'Puissance 2') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 36,2
        turn_off:
            topic: SUBmcz
            payload: 36,2
        icon_template: >-
            mdi:fire
          {% else %}
            mdi:fire-alert
          {% endif %}
# Switch Poele Puissance 3
    switches:
      poele_p_3:
        friendly_name: "Poêle Puissance 3"
        value_template: >-
          {% if is_state('sensor.etat_du_poele', 'Puissance 3') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 36,3
        turn_off:
            topic: SUBmcz
            payload: 36,3
        icon_template: >-
            mdi:fire
          {% else %}
            mdi:fire-alert
          {% endif %}
# Switch Poele Puissance 4
    switches:
      poele_p_4:
        friendly_name: "Poêle Puissance 4"
        value_template: >-
          {% if is_state('sensor.etat_du_poele', 'Puissance 4') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 36,4
        turn_off:
            topic: SUBmcz
            payload: 36,4
        icon_template: >-
            mdi:fire
          {% else %}
            mdi:fire-alert
          {% endif %}
# Switch Poele Puissance 5
    switches:
      poele_p_5:
        friendly_name: "Poêle Puissance5"
        value_template: >-
          {% if is_state('sensor.etat_du_poele', 'Puissance 5') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 36,5
        turn_off:
            topic: SUBmcz
            payload: 36,5
        icon_template: >-
            mdi:fire
          {% else %}
            mdi:fire-alert
          {% endif %}
Switches for Fan I paste only the 1st one, copy and paste for the other 2
# Switch Ventilo Principal Auto
    switches:
      fan_1_auto:
        friendly_name: "Fan 1 Auto"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Automatique') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,6
        turn_off:
            topic: SUBmcz
            payload: 37,6
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
# Switch Ventilo Principal 0
    switches:
      fan_1_0:
        friendly_name: "Fan 1 0"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Désactivé') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,0
        turn_off:
            topic: SUBmcz
            payload: 37,0
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
# Switch Ventilo Principal 1
    switches:
      fan_1_1:
        friendly_name: "Fan 1 1"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Niveau 1') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,1
        turn_off:
            topic: SUBmcz
            payload: 37,1
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
# Switch Ventilo Principal 2
    switches:
      fan_1_2:
        friendly_name: "Fan 1 2"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Niveau 2') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,2
        turn_off:
            topic: SUBmcz
            payload: 37,2
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
# Switch Ventilo Principal 3
    switches:
      fan_1_3:
        friendly_name: "Fan 1 3"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Niveau 3') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,3
        turn_off:
            topic: SUBmcz
            payload: 37,3
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
# Switch Ventilo Principal 4
    switches:
      fan_1_4:
        friendly_name: "Fan 1 4"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Niveau 4') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,4
        turn_off:
            topic: SUBmcz
            payload: 37,4
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
# Switch Ventilo Principal 5
    switches:
      fan_1_5:
        friendly_name: "Fan 1 5"
        value_template: >-
          {% if is_state('sensor.ventilateur_ambiance', 'Niveau 5') %}
          on
          {% else %}
          off
          {% endif %}
        turn_on:
            topic: SUBmcz
            payload: 37,5
        turn_off:
            topic: SUBmcz
            payload: 37,5
        icon_template: >-
            mdi:fan
          {% else %}
            mdi:fan-off
          {% endif %}
and thanks a lot for your shares. I just bought a MCZ stove, and i really want to control it with Home Assistant. I’m running with Hassio on RPI4 and i’am intersted to know how you received MQTT events from your stove ?
Thanks a lot.
For me it’s done using this setup on a seperate pi:
I’ve used a seperate Pi to connect to the MCZ servers. I’ve tried connecting to the stove directly but, the connection was too unstable.
I’ve used this package: https://github.com/pipolaq/maestro
Very nice project @Zeta38090! As I tend to buy a stove, that works the way you automated it, may i ask you what particular stove you´ve bought? And as I see it, the MCZ devices tend to have had addon wifi modules in different versions, maybe also the particular WiFi Module?
Other Hand: Do you or does anyone have an idea, if the MCZ devices always work via mqtt?
Thanks and regards,
Jakob
I’ve got a MCZ Philo 14kW, with integrated wifi. Most of the new ones have integrated wifi I guess nowdays.
Nicolas
Hi Zeta38090,
can you post a complete howto? That would help me a lot, unfortunately I just can’t get it to work :frowning:
Sure, I’ll do that as soon as I can promise :slight_smile: Gimme a couple of days
Thanks very much :slight_smile:
Hi - Just checking if you’d found the time to write a HowTo… ?
Hello :slight_smile:
Sorry for the long delay.
  • connect your stove through wifi to the MCZ servers, to be able to control it through their app.
  • On a another RPI (not the Hassio one), install this: https://github.com/pipolaq/maestro. Read all the requirements
  • modify config.py with your own MQTT info, and maestro.py, with your own serial and MAC
  • start the program. If you have a windows PC, you can check the MQTT messages using a free mqtt sniffer.
  • When everything is up and running, configure MQTT in Hassio.
  • Add the sensors I’ve listed on Jan 18 (Control MCZ Maestro pellet stove via HACore trough MQTT - #28 by Zeta38090), and restart Hassio.
Everything should be OK, if not, or if i’m not clear do not hesitate
For those who would be interested, I’ve created a small HA addon that embeds the python scripts from Chibald and Anthony-55 : ha-addons/maestro_gateway at main · SebLz/ha-addons · GitHub
Hello
Why install on a another RPI and not on a HASS ?
