Can u share above code?
@ryci Thank you for this comprehensive explanation. I have installed the Octoprint plugins and the threedy card and everything works fine. I have the following question: how did you added the extra entities, webcamera feed, switches, buttons and temperatures to the standard threedy card?
Hi KixMan
The camera feed and the buttons are not included in the threedy card. The card only shows the percent finished and the temperatures.
For the buttons and camera feed I used the built in picture element card and the button card.
Hi Ryci! Thank you. It is clear now.
I got an error in the threedy-card > e is undefined
What does this mean?
I do not use the thrredy card anymore. Having a look at the developers git repo issues page shows that there is an open issue for e is undefined:
Disable the ETA or Time remaining function of the card should remove the error for now.
Hi:
Is it possible to see the octorelay entities in mqtt? I want to add the 4 relay board to the rpi to control the fan and LED.
I have the same question ?
I found another way to automate my relay via octoprint API and home assistant rest_command.
Here is the code:
3d_printer_internal_relay_on:
url: http://octopi.local/api/plugin/octorelay
method: POST
headers:
X-Api-Key: your_api_key
content-type: 'application/json'
payload: '{ "v": 2, "command": "update", "subject": "r2", "target": true }'
This is thanks to this doc: GitHub - borisbu/OctoRelay: OctoPrint / Octopi plugin to control relays
after migration from FHEM ( I think with API) to HA (with both MQTT and normal integration) I canât find a solution to just âpress the start buttonâ. I do this very often to just repeat the last print. It was possible with FHEM to just start.
Can anyone help how to do this now?
I have Octoprint configured and working in HA, I am wondering, is there any way to upload a gcode from HA and start printing it ?
This is awesome! One feature I miss is to set the temperature of the nozzle and bed. Why donât we have this feature and all of those axis-moving options in the standard integration?
Can we start a feature request or isnât it worth it? I mean modern 3d-printers have their own âOctoPrintâ-like system what connects them to the network, so they donât need a separate computer which does just that.
So might OctoPrint be slowly dying or what do you think?
