Check out my post above
Yup I understand that the server is down, do you know of anywhere to check when it comes back up again?
Of course, when my L1 starts working again, thatāll be a good sign, but it would be handy if there was a status page somewhere.
Figured I find this after I flash 1 out of 3 sonoffs s31 switches for smart washer dryer and dishwasher
What to do now?
Continue flashing or stop
Ahhhh
I went Tasmota and never looked back. Working great, 16 S31ās and countingā¦
Thaks! It works
Thank for the update! Its Huge!
Iām not the sharpest knife in the drawer. I am trying to create a sensor for the current attribute on my S31. Reason is I want to use the Riemann sum integral integration to summarize the power used by that smart plug.
Thereās this in the Github doc.
Custom sensors
If you want some additional device attributes as sensors:
sonoff:
sensors: [staMac, bssid, host]
ā¦but I donāt know what to put in for staMac, bssid, host
Can anyone help my knife get sharper?
Eric
I have 11 existing lamps all working fine in Home Assistant.
I tried adding 2 more lamps and get this message in the logs
This error originated from a custom integration.
Logger: custom_components.sonoff.core.ewelink.cloud
Source: custom_components/sonoff/core/ewelink/cloud.py:323
Integration: Sonoff (documentation, issues)
First occurred: 13:21:30 (1 occurrences)
Last logged: 13:21:30
Cloud WS exception
File "/config/custom_components/sonoff/core/ewelink/cloud.py", line 323, in connect
raise Exception(resp)
Exception: {'error': 406, 'reason': 'Authentication Failed', 'apikey': '8335c1eb-ad52-4c25-bdd1-afa5fc9dff87', 'sequence': '1694866890684', 'actionName': 'userOnline'}
All existing lamps work okay, new lamps are working in the eWeLink app.
Any suggestions to fix this and add new lamps to Home Assistant thanks.
Just a little warning, SonoffLAN does not work well with HA 2024.1, wait before updating.
Also experiencing a host of issues that have been reported. Hoping for a quick fix to this one. Fingers as they are my majority of devices used.
A very basic question Iām afraid.
Iām setting up HA to (amongst other things) control several Sonoff relays and switches and I see that Sonoff have their own add-on for this which raises the question:-
What is the difference between Sonoffās eWeLink Home Assistant Add-on and this custom component?
Do they both actually provide the same functionality, or does either provide greater functionality or am I completely missing the point and they are 2 entirely different things and if so, what is the difference?
